40% (3gb) of 8gb RAM being used by nothing- help!
75 (0.02/day)
so yesterday i was just using my pc normally, normal ram usage, then towards the end of the night after i closed all programs my pc was using 30-40% of my ram from nothing (nothing showing in task manager either) the highest program that was open was using 400mb. so i thought the problem would fix itself after restart, but i turn on my PC today to find out that the problem is still there- 40% of my 8gb ram being used by literally nothing. heres my task manager tab-
18,584 (2.69/day)
System Name AlderLake
Do you use hibernate?
18,584 (2.69/day)
no, could that be whats causing it?
I had a memory eating problem a while ago, that was because I was using hibernate.
I don't use it anymore and my memory eating problem was gone.
Kursah
Super Moderator
14,724 (2.22/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Don't worry so much, the more RAM you toss in the more Windows will load it. You actually WANT more things in memory (within reason), that's where good system response comes from. Everything that is ran (your OS, programs, games) need to run in memory. Windows 8 does a fine job of handling memory utilization.
I would be more concerned if you were using 6-7GB with just that stuff running (not including what is cached in preparation for what you normally do throughout your logged in sessions) than seeing the utilization you have now.
What do you have running right now? What starts up with your system?
I see you have at least have a dozen Chrome tabs open, those use quite a bit of memory depending on what's being ran in each tab, Skype uses memory. There is also a difference between the memory being used that you posted in your screenshot and the actual memory utilized for that process, which is going to be a larger number.
Many people worry too much about memory utilization, it is actually a good thing...I would much rather see my RAM utilized than my page file, which is so much slower even with SSD's in RAID 0 it is frustrating.
I wouldn't worry about it, I don't see any problems here. You have Windows 8.1 x64 with other programs, drivers and objects open, it's using upwards of 4GB ram. Looks fine to me in all honesty.
I have 16GB of RAM on my personal workstation at home, and with Windows, Chrome + tabs, Foobar, I'm using ~4.5GB RAM, sometimes more, sometimes less. I've chased this stuff down before, and if you are truly concerned, then we need to look and see what you're running that is bleeding into memory, it's likely not Windows, as I said before 8 handles memory very well.
75 (0.02/day)
yeah when i play gta 5 it uses almost all my memory with another game client open, almost 7gb ram, and it lags a bit because of the insane ram usage, but im upgrading to 16gb ram in a couple days so i guess its not that big of a problem
1,618 (0.28/day)
well my first idea was that windows uses some caching when there is a lot of drive activity... but are you saying on a FRESH BOOT that it's 3gb usage?
Kursah
Super Moderator
14,724 (2.22/day)
Missoula, MT, USA
It's a huge game, I would expect it to use a lot of RAM. When I run Star Citizen with my 16GB of RAM I have to close my 40+ tabs of Chrome (when I have that many open) or it'll start hitting the page file hard.
The lag isn't the insane RAM usage, it's the items in memory or going to memory being redirected to your much slower page file (area reserved on hard drive/solid state storage as a RAM store or overflow space in a sense). Upgrading to 16GB should handle the issue for you. Keep us posted though. Odds are you're fine.
If you do get concerned there are some utilities out there you can run to analyze what's going on further in depth...honestly if you're malware free and have a few programs running, odds are Windows has stuff loaded for what you are running and what you will run.
Many fail to realize, especially with Windows 8 that a fresh boot will still cause loading and caching of commonly used items into RAM, this has happened since the Vista days it's just more pronounced and efficient now. Again I wouldn't worry too much.
:toast:
OneMoar
There is Always Moar
8,797 (1.64/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
thats pretty avg .... my system uses 2.5GB with chrome open + you are running skype and god knows what else
7,585 (1.48/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Free RAM = wasted RAM.
Every thing looks ok, especially cached part. Browser is usually the biggest hog with that many windows. But what exactly runSW executes... That's fishy.
Skype? I stopped use it as a plague just as they sold out. It has newer worked properly on any platform. I could say the same about any AV, it is more like a double edged sword.
Mussels
Freshwater Moderator
58,413 (7.92/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
chrome has its own task manager within the program itself to make it easier to see its total ram usage, start there. most of the adblockers for chrome are memory hogs as well, i moved to ublock and saved about 1GB of ram.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
As others have said it's nothing to worry about and it's more of plus than a negative that the OS is using the ram of not paging, and that lag could be very well it caching to HDD.
16GB will surly help.
159 (0.02/day)
Chilliwack, BC
Processor AMD FX-8350 Black Edition
Motherboard ASUS Sabertooth 990FX 1.01
Cooling Zalman 9900NT
Memory 16GB G Skill TridentX DDR3 2400 @2133 CL9-11-11-31 F3-2400C10-8GTX
Video Card(s) XFX Double D R9-390-TDFD 8GB 512-Bit GDDR5
Storage Samsung 850Pro 128GB, WD VelociRaptor 600GB, Seagate 7200.14 500GB
Display(s) HP LP2065 IPS x2
Case Coolermaster Elite RC-330 ATX
Audio Device(s) HT Omega Claro Plus
Power Supply Corsair TX850W V2 Single 70A Rail
Mouse Asus 0K100-00030200
Keyboard IBM KB-9930
Benchmark Scores 1.21GW @88MPH
74 (0.02/day)
Quebec City
System Name Orion
Processor Intel I7 3770K Ivy Bridge @4.6GHz
Motherboard Asus Sabertooth Z77
Cooling Corsair H100i
Memory 16GB Corsair Vengeance Dual/Quad Channel DDR3 CMZ16GX3M4A1600C9
Video Card(s) EVGA 780Ti Superclocked 3GB (OC +130MHz/248MHz)
Storage 1x 240GB Kingston Hyper-X 3K, 3x 3TB Seagate ST3000DM001
Display(s) Sony Bravia 55" KDL-55HX800 / Oculus DK1 / Oculus DK2
Case CoolerMaster HAX
Audio Device(s) OnBoard
Power Supply CoolerMaster Silent Pro M2 850W
Benchmark Scores UniEngine Valley 1.0 : 5539 3dMark Firestrike: 11468
Sysinternals RAMMap will show you where it is allocated.
Windows has alot of mecanisms regarding to RAM, most of the are less known. Most often, there is a metafile pool that is used mainly for the system file cache. It would gobble up memory in a scenario much like yours, but it would readily be handed over to other processes if need be.
If you really want to avoid the metafile, there is a registry key you can set to limit the file cache.
But all in all, it is harmless.
13,282 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
While I agree with all of the above, you should still scan for malware - just to be sure.
And your shot of Processes doesn't show much - what do you see in Resource Monitor?
And what happens after a reboot?
268 (0.06/day)
Europe/Norway
System Name Lava Kitty
Processor intel i7 4930k http://valid.x86.fr/lht7hh
Motherboard Asus x79 deluxe
Cooling H20 Parallel EK D5. Radiator: 480 Monsta 80mm pushpull
Memory Gskill-trident-X 2666mhz 16gb 4x4gb
Video Card(s) MSI GTX Titan X
Storage Samsung 850 pro 512GB. 3GB seagate storage. 1GB storage drive. 4# 300-500 GB storage drives
Display(s) Asus PA279Q, and Asus VG278HR
Case Lian Li PC-343B-XT
Audio Device(s) Asus Essence STX. and. Creative Soundblaster ZxR
Power Supply corsair 1200i
Mouse Corsair M65 RGB
Keyboard Razer black widdow 2013
Software windows 8.1 and soon windows 10
Benchmark Scores ask if u want to see http://valid.x86.fr/lht7hh
I'm considering getting 32gb kit version of my ram. I use almost all 16gb daily with the programs I use
brandonwh64
19,542 (3.50/day)
End task on all the chrome and you will see it go down. Why you have many open chrome tabs it uses its own process. Also any browser add ons run without chrome even been launched.
