70 pounds to water cool 2 290 cards
106 (0.03/day)
System Name Mean
Processor 2700k @ Modest 4.85Ghz,1.38V
Motherboard Asus maximus V formula
Cooling Sealed intel water loop
Memory 16 Gig Corsair red @2133 Mhz @ 11,10,11,27,2T timings 1.55V
Video Card(s) 2 X XFX 290 In crossfire 4 gig memory
Storage Intel 520 Ssd 520 read 500 write 120 gig system drive 3 x Wd 750 gig drives
Display(s) BenQ BL3201PT 32" 4k 60Hz Professional Widescreen LED Monitor
Case Lian li Tall tower
Power Supply enermax revolution 87+ 650w '80 plus gold X 2
Software Win 7
Benchmark Scores http://www.3dmark.com/3dm11/7671243 http://www.passmark.com/baselines/V8/display.php?id=17224737452
106 (0.03/day)
System Name Mean
Software Win 7
Yes ive seen it but cutting of 3 corners and drilling 4 holes right up to the edge of the plate saved me 60 pounds.
Money is tight here so no point if I can do the same thing by drilling the plate I already had but thx for letting me know.
xD3aDPooLx
NZXT Rep
144 (0.03/day)
So Cal
Oh how I know about the money aspect of it all. You modded it to fit your budget and thats the best part of it. Good work though.
106 (0.03/day)
System Name Mean
Software Win 7
cheers :)
43,609 (6.50/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
What coolers are you using with the Kracken adapters? :)
manofthem
WCG-TPU Team All-Star!
10,960 (2.16/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Congrats on the setup, very nice work. :toast:
106 (0.03/day)
System Name Mean
Software Win 7
106 (0.03/day)
System Name Mean
Software Win 7
106 (0.03/day)
System Name Mean
Software Win 7
hope you all like
manofthem
10,960 (2.16/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Thanks for the pictures, as they are much cleared than in the video. You can tell it took some work, but it looks pretty awesome. Great work :respect:
106 (0.03/day)
System Name Mean
Software Win 7
That X spring below the gpu from the stock cooler took some drilling to open up the holes.
I think it was nickel plated because I burned out 2 hss drills.
11,988 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
This gentlemen, is why we are here.
Bravo sir. You have balls of steel.
6,270 (0.91/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
freeleacher, Nice, job! seems they keep up well for you.
106 (0.03/day)
System Name Mean
Software Win 7
248 (0.04/day)
Netherlands
Processor i7 2700K @ 4.8 Ghz
Motherboard Asus Maximus IV Extreme-Z
Cooling Zalman CPNS9900-A LED
Memory Corsair Dominator GT CMT16GX3M4X2133C9 (4x4 Gb)
Video Card(s) 2 x (Sapphire) AMD Radeon HD7970 [Ref] -(crossfire) [out via DVI-D]
Storage 4 x WDC WD1002FAEX
Display(s) Dell U3011 @ 2560x1600 [in via DVI-D]
Case Coolermaster Stacker STC T01
Audio Device(s) Creative X-Fi Titanium Fatality Pro [PCI-E]
Power Supply Corsair AX 1200W
Software Windows 7 Ultimate x64 SP1
Good stuff! Nice. Very well done.
Enjoy your rig freeleecher.
Which camera did you use for these photos?
106 (0.03/day)
System Name Mean
Software Win 7
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
I was like dayum those are some heavy GPU blocks.
106 (0.03/day)
System Name Mean
Software Win 7
3,625 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Nice work. I would suggest adding plastic thread sleeve inserts through the pcb where you have the bolts going through. Stock bolts are anodized with a non-conductive paint. I am not sure if your bolts are but would consider doing it just to protect your investment. http://p.globalsources.com/IMAGES/PDT/B1044804630/Threaded-Spacer.jpg something like these.
Or maybe you have, can't tell from the picture for sure..but on zooming in it does look like there is something white there?
