hi
ive been trying to fix my pc for weeks now and there has been no progres at all, only a £180 bill this is how it started...
i did a fresh install off my pc a few weeks ago to clean up the hard drive but once i had installing vista and the drivers my pc randomly froze up after a few hours and wont load up properly. the pc turns on for 5-10 secs then just turns off again and just contnous to go in this loop of restarting on and off, with nothing comming up on the screen. so i tested some of the hardware to find out what the problem was and found out my Intel Core 2 duo 2.66 GHz had just blown so i thought buying a new cpu would solve the problem but soon as i put a brand new intel core 2 quad 2.66 GHz the same problem happened again...
should i just buy a new motherbord or is there another way to fix this?
please can somone help me its driving me nuts
pc spec
abit 35 pro motherbord
320 gb harddrive
6 gb of ram (2x1gb 2x2gb)
GTX 8800 geforce
600watt psu
intel core 2 quad 2.66 GHz which has probs blown like the last one
pc spec
320 gb harddrive
GTX 8800 geforce
600watt psu
