- Aug 13, 2009
- 3,464 (0.61/day)
- Czech republic
Processor | Ryzen 5800X |
Motherboard | Asus TUF-Gaming B550-Plus |
Cooling | Noctua NH-U14S |
Memory | 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC |
Video Card(s) | Sapphire AMD Radeon RX 7900 XTX Nitro+ |
Storage | HP EX950 512GB + Samsung 970 PRO 1TB |
Display(s) | Cooler Master GP27Q |
Case | Fractal Design Define R6 Black |
Audio Device(s) | Creative Sound Blaster AE-5 |
Power Supply | Seasonic PRIME Ultra 650W Gold |
Mouse | Roccat Kone AIMO Remastered |
Software | Windows 10 x64 |
I just came by a post by The Stilt over at Litecointalk saying
Interesting. Is it true?
Higher stock VDDC = less leakage, lower stock VDDC = higher leakage.
Lower the leakage the better.
The scale displayed by GPU-Z has gotten people thinking that higher "ASIC Quality" the better.
Actually it is completely the opposite, the value which is actually interpreted by GPU-Z is called "LeakageID".
Higher the value, higher the leakage.
So actually you want as low ASIC quality as possible.
Parts with low leakage require higher VDDC to operate, but their current draw is much lower because of the lower leakage.
It is not the dissipated power alone which heats up your graphics cards (GPU, VRM) it's the current too.
You can try what happens if you put 100A @ 1V thru an 18AWG cable compared to 1A @ 100V.
