BenQ Announces XR3501 Curved Cinematic-Widescreen Monitor for Gaming
47,166 (7.56/day)
BenQ announced the XR3501, a 35-inch curved, cinematic-widescreen monitor, which it recommends for motorsport gaming. The monitor packs a curved 21:9 aspect-ratio panel, with 2560 x 1080 pixels resolution, 144 Hz refresh-rate, 4 ms response time (GTG), 300 cd/m² maximum brightness, and 2000:1 static contrast ratio. It offers 178°/178° viewing angles. Its racy looking chrome stand suspends the monitor over a hinge, letting you tilt it vertically by 15°. Inputs include DisplayPort 1.2, mini-DisplayPort, two HDMI 1.4, and an analog audio input. Other features include 3 game mode display setting presets. The XR3501 will be generally available some time in August, 2015.
857 (0.18/day)
Oregon
System Name Red 101
Processor 9th Gen Intel Core i9-9900k
Motherboard EVGA Z370 Classified
Cooling Custom Primochill and Heatkiller water cooling loop
Memory 16GB of Gskill 3200Mhz CL14
Video Card(s) EVGA GeForce GTX 1080 FTW2 with Heatkiller block @2114Mhz
Storage 4- Samsung Evo 250GB, 1- Pro 512GB and 1-512GB M.2
Display(s) LG 38" UW
Case In Win 101 customized a lot and painted red
Audio Device(s) Razer Kraken 7.1 Chroma
Power Supply EVGA 850w G2
Mouse Razer DeathAdderv2
Keyboard Razer Ornata Chroma
Software Win10Pro and games
Benchmark Scores NA
3440x1440 and I would be in
Waiting for ASUS to release a 34" 3440x1440 144hz 21:9 G-Sync
1,010 (0.23/day)
Belgrade, Serbia
Memory CMD16GX4M4A2666C15
Display(s) Samsung P2450H
Case Lian Li PC-O11 WXC
Mouse Logitech G900 / SS QCK
Keyboard Deck 87 Francium Pro
Me to, ROG 3800R. But I have nothing against 60fps. Better 60fps with MSAA x4 than 120fps MSAA Disabled.
But I'm glad that other manufacturers start with Curved Screen.
This is now nice improvements compared with flat screen.
ASUS will mostly offer 3440x1440p resolution... That's little harder for hardware than 2560x1440p but not as 4K.
Or people could play on 2560x1080p.
4,277 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
I would like this if they had variations with Gsync/Freesync. It really is needed especially at the 144hz and with naming itself a "gaming monitor". Personally I like the idea and I love this monitor but wish it had just a bit more.
1,700 (0.27/day)
Only thing I want to add, (and the reason I have fought to park my car into either the green or red camp) is if I am aiming for 144+ FPS, why even bother with g-sync or Freesync? My goal is not sub 100 FPS.... So, I, personally, like not being tied to either side and in keeping my monitor camp agnostic, I am free to run AMD or Nvidia cards :)
4,277 (1.11/day)
Texas
Mouse Logitech G5
True, but running at that high range is pretty hard even down to a mere 1080p resolution mostly because games are just not optimized for that range. The power required even with something crazy sometimes still causes some skipping around which is noticeable on a high level in those ranges (At least to me). But I agree on the whole "Not being tied down to one side argument" as that is a problem with both these techs (Albeit the Freesync cost is not much). Plus with the Ultra wide its going to require a bit more GPU power as it is.
Its hard to choose a monitor in this day and age ain't it?
1,700 (0.27/day)
Sure is
4 (0.00/day)
Seems interesting if used just for gaming even with the 2560x1080 resolution. I have a 27" 1080p IPS monitor (with a similar ppi I imagine) that my son uses and games actually look real good on it, even though it is borderline for other uses due to the sad ppi. However I just saw this bad boy is $1000 for pre-order at NewEgg. Yowza......................about 30-40% to expensive for that resolution
14 (0.00/day)
You're going to be waiting a long time then (2+ years). In order to get to 144Hz you are going to NEED Display Port 1.3.
Display Port 1.2 = HBR2 = 17.28Gb/s, Display Port 1.3 = HBR3 25.92Gb/s
http://en.wikipedia.org/wiki/DisplayPort
Forward link channel with 1 to 4 lanes; effective data rate 1.296 (reduced bit rate), 2.16 (high bit rate), 4.32 (HBR2), or 6.48 Gbit/s (HBR3) per lane (total 5.184, 8.64, 17.28, or 25.92 Gbit/s for a 4-lane link)
Maths:
3440 x 1440 = 4,953,600 pixels / frame
4,953,600 x 144 (FPS/Hz) = 713,318,400 pixels per sec
---using 8/10bit encoding per channel x 3 channels, ie 30 bits sent per 24
713,318,400 x 10 (bits) x 3 (channels) = 21399552000 = 21.40Gb/s
at 10bit color would be well over 25.6Gb/s, nearly capping DisplayPort 1.3 !!!
9 (0.00/day)
Australia
System Name Project: n3m3515 (http://forums.overclockers.com.au/showthread.php?t=991131)
Processor i7 5820K
Motherboard MSI X99S Gaming 7
Cooling Koolance liquid cooling
Memory Kingston HyperX Predator 16GB (4x4GB) DDR4
Video Card(s) AMD R9 295x2
Storage 2x OCZ 120GB SSD in RAID 0 and 2x Samsung EVO 500GB SSD in RAID 0
Display(s) 3x ACER GD245HQ 120HZ 3D Gaming monitors
Case Thermaltake Level 10 GT
Audio Device(s) Xonar Xense with Sennheiser PC 350 headset
Power Supply Thermaltake Tough Power 1350W
Mouse Logitech G502, G900, and Cyborg R.A.T.9
Keyboard Kinesis Advantage Pro and Microsoft Natural
Keep in mind that Freesync is not proprietary, it is just part of the new DisplayPort VESA 1.2 (Adaptive Sync) implementation standard. Whether you buy a monitor with Freesync or Gsync it doesn’t dictate what hardware you use with it. Of course, paying extra for Gsync hardware in a monitor isn’t the ideal way to go when you are going to run AMD graphics cards. And yes, Freesync monitors cost a little more but that is probably more related to paying extra for the new technology just the same as when they implement HDMI 1.3 to 1.4 VESA changes. Eventually it just becomes the norm.
47,166 (7.56/day)
I don't think current DisplayPort has enough bandwidth for 3440x1440@144Hz. You probably have to plug in two DP connections and cope with the synchronization issues between the two halves of your screen.
857 (0.18/day)
Oregon
System Name Red 101
Benchmark Scores NA
Why do people say that... No duh!!! But they can put 1.3 on the monitor and boom
47,166 (7.56/day)
And boom...nothing happens. No current GPU supports DP 1.3.
NVIDIA won't support DP1.3 until a new resolution that needs that bandwidth, takes mainstream, because DP1.3 would automatically enable AMD FreeSync (since 1.2a would become a subset).
5,228 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
depending on the price, might snag one of these
1,964 (0.42/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard Womier SK75 (Green) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
There is a review already done by NCIX here;
Seems to be an AMVA panel with a 2000R curve (the most curved monitor available). This would be sooo good for racing setups imo, despite the relatively low resolution.
13,791 (1.88/day)
How about pairing DP cables to power a single massive monitor? Graphic cards already have bunch of outputs, you just have to provide a monitor that can accept signal from 2 DP cables simultanously and a graphic card driver that ouhtputs image through 2 cables. Then you can use similar techniques as for SLi/Crossfire. Each cable carries half of the screen signal. Or every other line of pixels. Or something like that...
This way you could double or triple the bandwidth of DP (for example my GTX 980 has 3x DP ports)...
6,684 (1.39/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
sprsk
4 (0.00/day)
35-inch curved, with 2560 x 1080 ... you'll be able to count the pixels from 1 meter ... lol ...
pathetic ...
For Cinema and game ... OK , But do not try to read ... danger .. lol
14,053 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Bit of an exaggeration :slap:
I've got a bigger Full H.D. TV that has a lower resolution, and I can't see pixels from a meter away.
