Best possible Graphics card for a Core i3
6 (0.00/day)
Barcelona (CATALONIA)
Processor Intel Core i7 4770 @ 3.4GHz
Motherboard ASUS B85M-E
Cooling Stock Cooler
Memory 16GB RipjawsX 1333 CL9
Video Card(s) NVIDIA GeForce RTX 2070
Storage Samsung SSD 850 EVO 250GB
Display(s) BenQ RL2455 (1920x1080)
Case Cooler Master Elite
Audio Device(s) Realtek High Definition Audio
Power Supply Cooler Master GX 750W
Mouse Dell M-BAC-DEL5
Keyboard Compaq KU-0133
Hello, I need some expert opinion about which graphics card to buy.
My current CPU is a Core i3 4330 @ 3.5GHz, I've 16GB of RAM and a 1920x1200 screen.
I know that mine is a mainstream CPU, so I would like to know which is the most powerful graphics card I can use with my system which doesn't get bottlenecked by my weak CPU.
My guess is a R7 260X, but I'm not sure. Is there any formula to calculate it?
Many thanks.
Easy Rhino
Linux Advocate
15,684 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
I do not believe a new i3 will put any limitations on even the most powerful gaming gpu.
926 (0.15/day)
Akron, OH
System Name Main Rig
Processor Athlon 5350
Motherboard AsRock mITX
Memory 4gb
Storage 120gb Kingston HyperX SSD
Display(s) Samsung Syncmaster 740N
Power Supply Corsair 430 watt
Agreed. I3 is not going to bottleneck any single graphics card.
manofthem
WCG-TPU Team All-Star!
10,960 (2.10/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Right now, my i3 2100 is paired with an R9 290, and it plays very well at 1920.1080. You'll see differences in benches, but for actual gaming, I don't think I have seen any real issue.
cadaveca
My name is Dave
17,238 (2.48/day)
Many thanks.
1920x1200 is R9280X/GTX770 or better territory, to use most games with maxed settings. You can use less GPU for lowered graphical settings.
CPUs don't paly a large role in gaming performance, but in some instances, can be totally critical, for example, with RTS games like Total War, where the extra threads offered by "better" CPUs are fully put to use. So to truly be able to answer your question directly does require more information in order to provide the very best answer. If you want to paly everything...an i3 is definitely going to be a bottleneck for ANY GPU expect for those with the most meager performance.
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
Id also put a gtx760 in that list. Solid card, at good price point for ~1080p gaming.
cadaveca
My name is Dave
17,238 (2.48/day)
BF3, Tomb Raider, Assassin's Creed Black Flag, and a few other apps don't agree with that. the ~$30 difference to go 770 over 760 is worth it.
Personally, nothing less than a GTX780 will do.
At the same time, the lack of real threads on the i3 chip also hampers performance a bit too in most modern games, so there's that to consider as well. I pick GPUs based on chosen resolution, and then CPU based on demands in that aspect. To me, the GTX760 is a worthless part simply filling a price gap.
If not gaming, the built-in GPU is all that is needed, anyway.
Of course, I do run GTX780 Ti in Tri-Sli, and have been running multiple cards for years now. I just might be a bit snobbish about hardware performance, and don't settle for "good enough".
926 (0.15/day)
Akron, OH
Memory 4gb
Cadaveca makes a good point. OP, you should find and read reviews of the Pentium 3220. That is a low end Haswell processor. In those reviews, they often show the FPS for games on that CPU along with the FPS on the same game with a 4770k using the same video card. In many games, there are no differences in the FPS. In a few games, the 4770k has a big lead. It just depends on how much the game relies on the CPU.
6 (0.00/day)
Thanks to everybody for the fast answer.
I was not aware that my i3 was so capable for gaming, in most benchmarks I've seen high-end card are always paired with i7s so I did conclude that an i3 was not suitable for them.
I think that a R9280X would be a great choice, I've seen lots of people selling them on ebay, I can try to get an used one for cheap. I've read that NVIDIA cards run cooler than AMD ones and are more energy efficient, but they're more expensive as well.
My objective is to be able to play games like Starcraft II, FarCry 3 or BF4 at decent framerates.
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Many thanks.
What is your budget for a GPU? That sounds like it might be the biggest thing might limit your options based on what people are saying about how well your i3 performs.
6 (0.00/day)
My budget is about 200 Euro, I can spend a little bit more if the card really worth it.
I know that this is a tight budget so I'm looking for a good deal on the pre-owned market.
44,273 (6.80/day)
270.270X,280,280X, maybe a 290, or
6970,6990,7770, 7850,7870,7950,7970,7990
2,098 (0.51/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Also, consider that you could, someday, if needed, upgrade your CPU to an i5 or i7, so get the best GPU you can afford. On the value side, don't overlook the 7950 and GTX 670.
394 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
Paired an i3-4330 with an GTX 770 for a costumer, works fine all games are running nice and smooth.
134 (0.03/day)
Hà Nội, Việt Nam
System Name Acer Aspire V3-571G
Processor Core i3 3110M Dual Core 2.4 GHz Ivy Bridge
Motherboard Intel HM77
Memory 4Gb DDR3 1333 MHz Dual Channel
Video Card(s) Intel HD Graphics 4000/NVIDIA GeForce GT630M
Storage Kingston V300 120Gb SATA3 SSD
Display(s) Asus VS239H 23-inch AH-IPS Monitor
Audio Device(s) Realtek HD with Dolby™ Digital Plus
Mouse Logitech G502 Proteus Core Tunable Gaming Mouse + Corsair MM400 Hard Plastic Gaming Mouse Mat
Keyboard Logitech G310 Atlas Dawn Mechanical Gaming Keyboard | Romer-G Switches by Omron and Logitech
Benchmark Scores Nah, nevermind me then xD
I'm about on the same road, my family desktop is running a Core i3-2130, and I've been looking for a nice graphics card to run with it. Just moderate 1080P gaming most of the time. So maybe a R9 270/270X ?
519 (0.13/day)
UK
System Name Daedalus
Processor AMD FX 6300
Motherboard ASUS M5A97 EVO R2.0
Cooling Coolermaster Hyper 212 EVO
Memory 8GB Kingston HyperX Genesis (2x4GB)
Video Card(s) MSI R9 270X Gaming 2GB
Storage 1TB Seagate Barracuda
Display(s) LG Flatron E2442 (main - 24in 1080p)
Case NZXT Phantom 410 (Gunmetal Edition)
Power Supply XFX Pro 650W
Mouse Steelseries Siberia [RAW]
For moderate 1080p gaming, I think you would be better off with a GTX 750 Ti or an R7 260x. I have an R9 270x and it consumes quite a bit of power, so you can save on electricity bills and the such with those lower power cards.
Layton
134 (0.03/day)
Hà Nội, Việt Nam
Hmm, I thought the R9 270 doesn't consume that much more power comparing to GTX 750 Ti/R7 260X ?
Somehow I feel 750 Ti/260X lacks a bit of power, I just want some more futureproof
519 (0.13/day)
UK
Somehow I feel 750 Ti/260X lacks a bit of power, I just want a bit more futureproof
Futureproofing is understanding what your current needs are, assessing what money is available, working out how much to spend for the here and now (if any money at all), and then leaving the rest of the money to upgrade in the future when you really need it.
Do you really need the extra performance? Do you play games often enough for it to be worth it? Could you live with not having the highest settings when you play the odd game now and again?
Layton
187 (0.04/day)
Processor Intel® Celeron® Processor G1101
Motherboard Supermicro® MBD-C7SIM-Q-B
Memory 8 GB Silicon Power SP004GBLTU133N02/W02
Video Card(s) Sapphire FirePro™ 2270 + AMD Radeon™ HD 8740
Storage 1000 GB Toshiba P300 HDWD110UZSVA
Display(s) 29" LG 29UM57-P
Case Chieftec LBX-02B-U3
Power Supply 650W XFX XXX Edition (P1-650X-XXB9)
Software Windows Server 2016
Well, there's something you have to think of before you make any decision.
GTX 760 is great for sub 250 USD price tag. Actually, you can find it for something like 220 USD (Gigabyte Windforce 3X goes a bit pricey but it has fantastic OC potential, runs 1200/7400 MHz at friend's machine and unbelievably cool and silent), while R9 270X currently saves you 25 USD and it performs only 3-4% slower in most games. So choose carefully. I've been waging a war with AMD for 6 months now (because of Mobility products support, nothing against their desktop stuff), so I'd personally go with GTX 760.
134 (0.03/day)
Hà Nội, Việt Nam
Yep, thanks for reminding me that. :toast:
Interesting point right there, I'll definitely consider it carefully. Cheers from Viet Nam !
187 (0.04/day)
Well, 750 Ti & 260X DO lack some power because of the silicone design, so it's totally OK for you to consider them just a bunch of budget cards without any "future potential". For example, GTX 750 Ti is desktop packaging of mid-range mobile GPU known as GTX 860M (1500 USD price tag). They won't be able to handle Ultra Settings/1080P preset, the reviews clearly state that they can only give you something like 28 FPS Average, which is not nearly "smooth". Interesting options are R7 265 (3.5 Million VND) and GTX 660 (3.7 Million VND): they're not as power hungry as ones that we were talking about (GTX 760/R9 270X), while they can still perform pretty good in Ultra/1080P. And of course they cost 15-20% less (which is great).
134 (0.03/day)
Hà Nội, Việt Nam
519 (0.13/day)
UK
Those are quite bold, and perhaps unsupported statements. For example "28 FPS average" at what settings? Which game? At what resolution? My old ATI laptop GPU could do 300FPS on something like Garry's Mod, but that old ATI GPU is outperformed even now by a HD 7750. It would be nice for some context, maybe some links to the websites your getting information from, so a better conclusion can be made. I'm a guy that prefers price to performance, and I think budget options can often be perfect for a large variety of people. I'm perfectly fine with just High rather than Ultra.
Layton
