bzugu
- Jul 5, 2008
- 31 (0.01/day)
- Portugal
System Name | bzuGu |
Processor | Intel C2Duo E8400 3.0 Ghz FSB1333 6MB L2 Cache |
Motherboard | Asus P5Q-Pro |
Cooling | Asus Silent Knight II |
Memory | Kingston DDR2 800mhz 1gb x2 |
Video Card(s) | Asus Ati HD3870 512MG DDR4 |
Storage | Seagate 120gb |
Display(s) | Philips 17'' |
Case | Nox Collbay 25 silver |
Audio Device(s) | On Board |
Power Supply | Nox urano 600w |
Software | Windows Vista 64 bits |
It is kinda easy and can be done in 2 - 3 min..
1. Go here and download the "mpdata" file - http://www.megaupload.com/?d=AGZQZGLN
2. Go to your "players" folder and copy it to a location outside of your Call of Duty directory. (i.e. - My Documents). This will be your backup copy just in case you screw up. Default location for the "players" folder is C:\Program Files\Activision\Call of Duty 4 - Modern Warfare/
3. Open the Start Menu and click "Run".
4. Type "regedit" and click OK.
5. Navigate to HKEY_LOCAL MACHINE > SOFTWARE > Activision > Call of Duty 4
6. Look to the right box and you'll see the second row is your "codkey". Right-click and select "Modify". Now enter DL2J8PY44Q22GE4888D2 as your new key.
7. Click OK and exit Regedit.
8. Navigate back the original "players" folder again and inside it you'll find your profiles. Open the one you want to upgrade and delete everything inside of it. (Make sure that you have completed step #2 first!)
9. Move the "mpdata" file that you downloaded earlier into the now empty folder.
10. Open CoD4. (You may need to reset some settings such the display resolution, etc.)
11. In the game, go to Options > Multiplayer Options > Enter Key Code and re-enter your key that came with your game.
12. Finitto! / The End !
It works pretty fine..
bzuGu
bzuGu
