Cheapest effective upgrade of Q6600 ?
352 (0.06/day)
System Name The Browser
Processor AMD FX-8350
Motherboard Asus 90 Aura Gaming
Cooling Noctua D14
Memory Crucial Balistix Slim 16gb
Video Card(s) Sapphire AMD 7950 3GB
Storage Crucial MX 240gb + 2X3TB WD Reds
Display(s) Dell 2515H 25"
Case Corsair Carbide 540 (piece of shit case)
Power Supply Seasonic G-650W Gold
Mouse Corsair M65 RGB
Keyboard Corsair K70
Software Win 10
Hi there ! I am looking to change out my Q6600/DDR2 combo for something newer, probably used but still significantly faster than Q6600.
I have no real complaints, I can run Diablo fine and browse the web pretty fast. So I do not want a new expensive combo. The problem is the motherboard lost it's audio capabilities, the CPU fan died, so I figured I would just get something else.
Any specific suggestions ? Perhaps a Phenom II or AMD FX ? I7 940 ?
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
AMD FX would be a good upgrade my bro went from a Q6600 to a 8320 and is loving every second. but a 6300 series would be good too!
FreedomEclipse
~Technological Technocrat~
24,001 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
if the PC is still fine for your use the just by a soundcard and carry on.
grab a Xonar DG which is dirt cheap or a Creative Sound Blaster Z/ZX/ZxR which are on the more expensive side of the scale if you wish to throw more money at it.
If you really wanted a complete overhaul though but are on a tight budget, i recommend going the intel i3 4xxx (Haswell) route. I built my dad a similar set up with a i3 4130 and even though its far from an enthusiast grade CPU, it has performance in buckets
It totally pounds your Q6600 into the ground
FreedomEclipse
24,001 (3.74/day)
London,UK
I think the 4130 is a better option if on a budget
It 'Almost' trades blows with the AMD FX8320
The only test the FX8320 really takes off is in multi-threaded performance otherwise everything is more or less identical
41 (0.01/day)
Slovakia
Processor AMD Phenom II x3 720 2.8GHz @ 3.6 GHz
Motherboard GA-MA790FXT-UD5P
Cooling CPU-Arctic Cooling Freezer Extreme
Memory 4GB Corsair XMS3 DHX DDR3 1600
Video Card(s) SAPPHIRE HD7870 GHz EDITION OC 2GB GDDR5
Storage Western Digital Caviar Blue 500GB
Display(s) 19" Philips LCD 1440x900
Case Xigmatek Midgard W
Power Supply CORSAIR TX550M
Software Widows 7 Ultimate 64bit
First of all. How much are you actually willing to spend together for cpu and mobo?
352 (0.06/day)
Cooling Noctua D14
Software Win 10
Thanks !
Wow 200% upgrade for the i3....
I have a guy here selling Asus Rampage Extreme LGA1366 + Core I7 960 for 220$. From what I can see in your linked comparison website the I3 and that I7 are pretty similar.
Should I get the I7 combo with the great board and OC the hell out of it ? Or would you still get a new I3 ?
By the way, for my uses I should look at Single Threaded Performance, correct ?
MT is all that 3D Studio and the likes, ey ?
1,927 (0.44/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
FX 6300 + 8GB 1600 ram + GA-970A-UD3P. My friend has a HD 7970 paired with that and plays Planetside 2 maximum settings @ 1080p with 0 overclocking and gets at worst 40FPS.
FreedomEclipse
24,001 (3.74/day)
London,UK
you can if you wanted to but IMO that i7 960 is old tech, There is no upgrade path for it beyond what it is.
If you have a bit more cash though the you can buy into a i5 4440 and a cheap $100 motherboard if you dont care for overclocking. for a mobo, CPU & RAM combo it shouldnt cost you above $400 for a decentish setup so long as youre not too demanding.
2,693 (0.43/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
2nd hand 2500k and a z68 mobo all day every day.
dont say this too loud as there are amd fanbois everywhere! but an fx4 aint much of an upgrade from a q6600.
TomJane
4 (0.00/day)
A lot has already been advice. My simplest suggestion would be to go either for Q9400 or Haswell.
Q9400 is next generation and it works at par and is cheap too. If you have a little increased budget
than going with later is a better choice.
2,693 (0.43/day)
System Name panda
Processor 6700k
Case 540 Air
Mouse g502
Software win 10
if you want to stay 775 only get a 9x50 chip as those had all the cache, those without the 50 did not :thumb:
FreedomEclipse
24,001 (3.74/day)
London,UK
waste of money. The Q9400 isnt a much of a step forward in terms of performance
The i3-4130 is better than the Q9400 & the Q6600
At the end of the day it comes down to budget.... but i would not get that Q9400 over a i3-4130. It might be a Quad but Haswell is just so much more efficient.
If it had to be a C2Q chip though, id be looking for a Q9550 or Q9650 chip and those arent cheap as they are still very very capable CPUs
352 (0.06/day)
Cooling Noctua D14
Software Win 10
Guys thanks ! Great options here.
What's a good OC board to take an FX-4 or Phenom II 980 high in the sky ? Again, within 100$ used.
By the way, is the AM3+ socket still active and under development ? If so, may be worthwhile for me to get a new, good OC board for that, with a cheap used Phenom 965 and just enjoy it.
I see good AMD boards are generally cheaper.. And the used CPU's on ebay are also really cheap, as long as it's mainstream and not FX-9 and other useless stuff like that.
11,878 (2.22/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Am3 + is unlikely to last much longer but that doesn't matter if you understand intels near yearly socket swap malarky ie neither has much upgrade potential beyond more cores later so id suggest a decent am3+ mobo like a gigabyte ud3 (cheap but capable) and an fx4300 .you will see a decent amount of improvement over a q6600 in part due to ddr3 and could get a cheap 8 core fx in a few years off ebay etc
Easy Rhino
Linux Advocate
15,577 (2.37/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software The Matrix
Honestly, as someone who has a q6600/8 gigs ram/ gtx 570 I would simply buy a new cheap cpu fan and a cheap sound card. That is $60 in total cost for you and you get to continue using an amazing CPU. I am not upgrading my rig for a long time.
Mussels
Freshwater Moderator
58,413 (7.96/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
if you want better single threaded performance, an i3/i5 is your best bet. trust me, i went from a 6 core AMD to my i5 and i'd never go back for gaming.
for video encoding and such the AMD hexcore works great, but sadly games are still dominated by single threaded performance.
personally i say fix up your PC to get another 6 months out of it (CPU fan + cheapo soundcard, hell maybe even ebay a $10 USB one?) and save up for a whole new machine that kicks the pants off it.
226 (0.04/day)
System Name Rhino
Processor FX6300
Motherboard Asus M5A97 EVO R2
Cooling Corsair H80i
Memory HyperX Beast 1866MHz
Video Card(s) Asus GTX560ti
Storage OCZ Agility 3
Case Lian-li
Audio Device(s) Auzentech Sound Studio
Power Supply EVGA G2 750w
Keyboard Tt eSPORTS Challenger Pro
Software W10 64bit
Surely but surely for your needs you can't go wrong with a nice little AMD FM2 A8 with an ASUS F2A85-M. 200 bucks and if you ever want more graphic performance you can bung in a further G card or two.
I don't recommend buying anything 2nd hand. There is nearly always a reason why the current owner has upgraded from it.
However, as has been mentioned, a quick patch up and saving up for a quantum leap sometime in the future won't be disappointing either.
Aquinus
Resident Wat-man
13,162 (2.82/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Before any recommendation can be made with any sort of reasonable accuracy I think a couple questions are in order.
A: What about your current platform are you unhappy with if anything (other than components failing)?
B: What do you use your computer for? You mentioned Diablo (3?) but that doesn't really tell us what the entirety of the machine is used for. Is it just for gaming?
C: How much are you looking to spend?
2,074 (0.47/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
You sound just like my brother - he's been bragging on his Q6600 rig for years. Three weeks ago I built an i3-4130/MSI Z87-GD45 Gaming/8GB DDR3-2400MHz/840 Pro 128/GTX 460 rig, and I let him borrow it for a week to try it out . He hooked it up as an HTPC/music server in his living room, and he was blown away by the speed and the graphics quality on his 55" flatscreen TV - so I sold it to him for what I had in it (~$500). He still uses his old system for work and general office duties, but he's really taken with the new rig. He was also stuck on Win XP 32 bit, and now he's finding out how much better Win 8 Pro 64 is.
3,622 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Thanks !
If this system comes with DDR3 and good cooling for the I7 that is a good deal and will be a huge performance gain.
226 (0.04/day)
System Name Rhino
Processor FX6300
Case Lian-li
Software W10 64bit
Nooooooooo!
Must be new.
Why spend 200 hundred bucks on 2nd hand when you can get a funky new rig for the same?
3,622 (0.50/day)
Case Corsiar 550
Nooooooooo!
Must be new.
Because while you might get a Funky new rig, it won't out perform the i7 9xx series at $220. An i3 is not going to beat an i7 9xx series which have plenty of potential even if it is a little older. Those are all high-end parts. the i7 9xx series has a min of 8mb Cache and the top of the line i3 has 3mb. The only thing the i3 does better is take less power.
I am not saying the lga1366 is a future proof socket..lol. Its dead. But there is still plenty of performance that can be delivered from this socket.
226 (0.04/day)
System Name Rhino
Processor FX6300
Case Lian-li
Software W10 64bit
If the gear is good.........
rtwjunkie
PC Gaming Enthusiast
13,978 (2.35/day)
Louisiana
Processor Core i9-9900k
Nooooooooo!
Must be new.
I've never gotten any used computer part off ebay that had any problem with it. Most are for sale because the owner upgraded, not because anything is wrong with it. It's a very smart way to shop for upgrades if cash-flow is short.
226 (0.04/day)
System Name Rhino
Processor FX6300
Case Lian-li
Software W10 64bit
Help, help. The i7 mob is ganging up on me.
Well, if it works you won't be disappointed.
