Cooler Master Displays Vapor Chamber-based CPU Fan-Heatsink
47,222 (7.55/day)
There's little innovation with tower-type CPU coolers these days, barring the odd fancy aluminum fin design or heat-pipe layout. Cooler Master put its engineering muscle to use by developing a new tower-type CPU cooler that takes advantage of vapor-chamber technology. Called the TPC 812, the cooler is just large another aluminum fin tower-type heatsink with six heat pipes feeding head through the fin-stack, till the part where a specially-designed vapor-chamber element finds place.
The cooler uses a copper indirect contact base, at which the six heat pipes converge at the lowest level. Above it, is a vapor-chamber plate. From this place, two thin, broad columns arise, passing through the central portion of the aluminum fin stack. The heatsink is ventilated by a 120 mm fan. With its design innovation, the TPC 812 can handle thermal loads of up to 240W. The TPC 812 from Cooler Master will be priced around the $100 mark, and will be competitive with entry-level closed-loop liquid coolers.
4,686 (0.77/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
That's all kinda vague. Either it beats the H100/D-14 or it's overpriced.
F2K
47 (0.01/day)
Europe
I just wonder how long before Tt steals this idea/design :rolleyes:
1,964 (0.42/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard Womier SK75 (Green) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
Hopefully its not as noisy as their V6 GT. Then I may consider it for some builds (as long as it beats low end AIO liquid cooling and Noctua U12 or D14).
188 (0.04/day)
Looks nice, if the noise and performance are right then I may buy this.
INSTG8R
Vanguard Beta Tester
8,042 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Well my Vapor-X 5870 has never let me down so the tech is sound. 32C idle and never touches 70 under heavy load. Nice to see someone using this tech for CPU cooling. Now where is my Vapor-X 7970....
9,899 (1.71/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
I got excited as I thought someone had finally implemented my idea.
5,061 (0.88/day)
Processor AMD Ryzen 5 7600
Memory Kingston Fury Beast DDR5-5600 16GBx2
Video Card(s) Gigabyte Gaming OC AMD Radeon RX 7800 XT 16GB
Storage TEAMGROUP T-Force Z440 2TB, SPower A60 2TB, SPower A55 2TB, Seagate 4TBx2
Display(s) AOC 24G2 + Xitrix WFP-2415
Case Montech Air X
Audio Device(s) Realtek onboard
Power Supply Be Quiet! Pure Power 11 FM 750W 80+ Gold
Mouse Logitech G Pro X Superlight Wireless
Keyboard Royal Kludge RK-S98 Tri-Mode RGB Mechanical Keyboard
There aren't any "entry-level" closed-loop liquid coolers priced at around $100. Cooler Master Fail. :laugh:
2,334 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
trickson
OH, I have such a headache
7,595 (1.04/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
Vapor chamber is yesterday. Bring on liquid chamber.
Yeah this is what I want to see as well ! All this Vapor chamber stuff is so long in the tooth and really old tech . What I would like to see is some real innovation in air tech .
10,738 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 CL30 / 2133 fclk
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Keyboard 65% HE Keyboard
well closed loop systems are great because:
1 they fit in smaller systems and (never have any clearance issues with ram or videocards)
2 are easy and light on the motherboard.
3 you can decide where to locate the radiator (i.e. intake for maximum cooling, or exhaust to lower component temps).
4 - for me they can minimize the number of fans in your system - i.e. exhaust is also rad fan
5 - they make builds alot cleaner and easier IMO.
All those PRO's will not be overcome by "competitive" thermal performance from a tower cooler that costs just as much. It better kill closed loop systems on the thermals or its not worth it.
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
They are all the same any way . How can you really design them any different in the first place ? Only so much you can do with heat pipes and fins .
6,715 (1.39/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Massive copper cooler is probably heavy as hell....
1,964 (0.42/day)
VR HMD Oculus Quest
in Australia a H60 is $99 although the antec kuhler 620 is only $80 and it performs better. Basically the H60 is the poorest performing closed-loop liquid cooler available in Australia as we do not get the H40.
697 (0.11/day)
Zagreb, Croatia
Processor C2D E8400@3.9GHz (488x8, 1.4v :( )
Motherboard Abit IP35-E
Cooling Thermaltake Sonic Tower+120mm fan
Memory 2GB kingmax ddr1066@976MHz 5-5-5-15
Video Card(s) Radeon X1800GTO @700/1400MHz with Accelero S1+Glacialtech fancard
Storage 2xSeagate Barracuda 7200.10 160GB
Display(s) Samsung SyncMaster 793s... just you laugh...
Case some Aplus case
Audio Device(s) Realtek ALC888
Power Supply Chieftec 450W
Software Win7 x64
i think 240w is quite impressive for a single 120mm fan cooler. my trusty old tt sonic tower is about the same size yet only rated for 120.
de.das.dude
Pro Indian Modder
9,041 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
will suck in tower type cases. good for benching r7gs where it stays perpendicular to the ground.
1,964 (0.42/day)
VR HMD Oculus Quest
yes but, video cards that have vapour chambers and are used in tower cases are put in upside down so I don't imagine it will affect temperatures too much.
1,493 (0.22/day)
Orange County, CA
System Name Battle Station
Processor AMD Ryzen 5900x
Motherboard Asus ROG Strix x570-I
Cooling Lian Li Galahad 240
Memory Crucial DDR4-3200 32 GB
Video Card(s) 1 x Gigabyte RTX 4090
Storage Adata 1Tb NVME
Display(s) Samsung G9 Odyssey
Case Hyte Y60
Audio Device(s) Asus Xonar DX + Ultrasone Pro 900 + JBL SLR 308 speakers and SLR 310 subwoofer
Power Supply Corsair SFX 750W
Mouse Logitech G903
Keyboard The rabbit hole of custom mechanical keyboards
Software Window 10 Ultimate x64
Doubt this will beat Noctua NH D14.
T
twilyth
I've always wanted to build something like that, but I would have a hollow column going straight up from the base. Then there would be tubes radiating out from the sides (pitched to drain) which would have the heat fins mounted vertically. The idea was that since the fins are vertical, you might be able to rely just on convection.
With that arrangement, you could have literally, a hundred or more pipes feeding the fins. It would also probably be some multiple of the normal surface area.
Then, just for kicks, I'd have an ionizer electrode going into the column. It would work just like an air ionizer but with the water vapor. Then you put a positive charge on an insulated plate at the top in order to increase the transfer rate. So you'd have the vapor pressure pushing out and the electromagnetic field sucking the vapor up.
I have no idea if it would work with vapor, but it works pretty damn well in air cleaners that have this feature. Hell, if you wanted to get fancy, you could use electromagnets and time them to alternate so that maybe (I have no idea) it would create a slight vortex.
Alright. My work here is done. Where's my royalty check? Hmmm?
sneekypeet
not-so supermod
29,577 (4.35/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Let me specify about the cooling potential....
Each vapor chamber is 120W worth of cooling.....
Along with the pipes and the fins, this cooler will sell as a 300W+ rating;)
de.das.dude
Pro Indian Modder
9,041 (1.71/day)
VR HMD ;_;
good point. im confused now.
vapor chambers. you cant explain that!
ans. aliens :D
471 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
Who said this was going to be $100. Cm already said this was going to be about $69.
Lol who believed this was a $100 cooler. VR-Zone should get its facts straight, before posting.
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
Vapor chambers still have the wick in them
