Crossfire HD 5870
Raijian
177 (0.04/day)
Canada
Processor AMD Phenom II x6 1090T 3.9 Ghz
Motherboard ASUS Crosshair IV Formula 890FX
Cooling Thermaltake Frio + Additional Fan
Memory 12gb G.Skill Ripjaws DDR3 1600mhz
Video Card(s) ATi Radeon HD 5870 1GB + ATi Radeon HD 5870 [Crossfire]
Display(s) Samsung 25" LED
Case Coolermaster HAF 932 Full Tower
Audio Device(s) ASRock VIA HD Onboard 7.1 Audio
Power Supply Kingwin Mach 1 1000W
Software Windows 7 x64 Professional / Backtrack 5
I'm getting a second HD 5870 tonight, hoping it will increase my performance in BF3.
How do I go about cross firing it? I have the bridge, but I don't really know where to start besides the obvious of putting it into the slot.
3,516 (0.61/day)
System Name Money Hole
Processor Core i7 970
Motherboard Asus P6T6 WS Revolution
Cooling Noctua UH-D14
Memory 2133Mhz 12GB (3x4GB) Mushkin 998991
Video Card(s) Sapphire Tri-X OC R9 290X
Storage Samsung 1TB 850 Evo
Display(s) 3x Acer KG240A 144hz
Case CM HAF 932
Audio Device(s) ADI (onboard)
Power Supply Enermax Revolution 85+ 1050w
Keyboard Logitech G710+
With the PC off:
1) Install the second 5870 but do not connect the bridge
2) Start up PC and let the drivers pick up the second card
3) Shutdown the PC again and connect the Crossfire bridge.
4) Start up PC again and it should enable Crossfire by default. If it doesn't just go in to the Catalyst section for Crossfire and check the box for enabling Crossfire.
I've used that method about a handful of times without ever having a problem.
Raijian
177 (0.04/day)
Canada
Thanks a lot!
Do you think I'll see an increase in performance in BF3? At ultra right now outside I get like 25-35 fps. Sucks bad.
3,516 (0.61/day)
Case CM HAF 932
:laugh:
Yea, there will be a bit of a increase. ;)
By the way, the highest working settings in the Beta are high. Ultra is not working currently.
4,931 (0.74/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Thanks a lot!
FYI, I get 47~70FPS with 5870CF, and that is with my CPU at stock right now bottlenecking.
Raijian
177 (0.04/day)
Canada
Yeah, well hopefully they optimize the game further and get their shit together. I'd be surprised if 2 5870's CF still don't max this out.
4,013 (0.72/day)
They won't max it out, but you will be happy with the outcome - I am.
Raijian
177 (0.04/day)
Canada
Well I would be happy with 45-60 fps, but right now it's hard on the eyes... and this isn't even in conquest so I can only imagine the entire game running like crap as of right now, but meh. I've heard this is a really early beta.. maybe it'll run a bit smoother on release :(
I can dream
3,516 (0.61/day)
Case CM HAF 932
Don't worry about performance in the Beta. It will get better as the build is an Alpha build.
Also the Beta is DX10 and not DX11. Usually DX11 gives better performance over DX10 when you have the option.
Fwiw I get ~70 fps constantly being outside on Metro. Underground the get a little better. Even with explosions I don't see bad drops in fps.
43,606 (6.50/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
As far as installing the card.. Put the 2nd card in with the machine off and install the CF bridge. Boot up and it should work. If not, then uninstall and reinstall drivers. It's that simple.
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
With the PC off:
Um ok, but all that really isn't necessary. Like erocker said just install the second card with bridge. Provided there are no other issues e.g. with the driver install then it will see it and enable crossfire (and bring up a Catalyst dialog showing you such).
LordJummy
1,403 (0.28/day)
US of A
System Name Workstation1 | Asus G55VW-DS71
Processor i7 970 3.8GHz | i7 3610QM
Motherboard RIII Formula
Cooling EK 360 Supreme HF | Asus G55VW
Memory 24GB Dominator | 12GB DDR3
Video Card(s) 2x Diamond HD 6970 | GTX 660M
Storage 2x Vertex4 256GB | 256GB Vertex4 & 750GB HDD
Display(s) 3x Crossover 27" LED S-IPS + 30" DELL IPS
Case Corsair Obsidian 800D
Audio Device(s) X-Fi Titanium Fatal1ty Pro + Gigaworks G550W
Power Supply HX1000 + NZXT Black Sleeved Extensions
Software Win7Ult64Bit
Benchmark Scores ballz
Alpha builds generally tend to precede the Beta builds. They usually don't offer open public alpha builds. Hence the beta.
They will optimize things further though before they get closer to release.
Raijian
177 (0.04/day)
Canada
I booted up and it said that my device is now working properly (windows said that) but when I go into CCC and go into hardware it sees my primary device as a 5870 and a "disabled adapter" as a 5870.
How do I enable crossfire? I don't see ANYTHING that even says crossfire in CCC lol
Using 11.10, most recent version of CCC
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Bah. Go into Device Manager first and make sure Windows sees two cards. Driver uninstall and reinstall with latest 11.9 may be in order.
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
Raijian
177 (0.04/day)
Canada
Thanks a lot erocker.
Should I just get the latest drivers once my old ones are cleaned?
Is 11.9 better than 11.10?
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
Get the 11.9 whql's.
Raijian
177 (0.04/day)
Canada
I'm sorry, what's WHQL? Gah >.< Sorry for all the questions, I googled Whql and had no luck.
3,427 (0.65/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
I would think the increased level of detail in DX11 would decrease performance.
I get about 45-80 FPS outside and about 80-150 in the metro/subway.
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Yes 11.9 is better than 11.10 in this case as 11.10 is just a preview rushed out for BF3 beta (and consequently seems to not work as well in that game as 11.9). WHQL stand for Windows Hardware Quality Labs and it just means it's the official latest release and has been tested and certified by Microsoft. The latter, the WHQL part, doesn't really matter so much to us. It's point is to guarantee compatibility and "safety" but we already know a driver from AMD can generally be trusted.
Here's what you want (this is 64 bit; I checked your specs)
http://sites.amd.com/us/game/downloads/pages/radeon_win7-64.aspx#1
Get that CAP linked there too below as you now run crossfire.
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
Raijian
177 (0.04/day)
Canada
So the 11.10 they specifically made for BF3 isn't as good with BF3 as the latest official release of drivers?
Raijian
177 (0.04/day)
Canada
Still saying my second card is disabled.. :( I don't see any crossfire tab or options in CCC.
Windows Device Manager shows
ATI HD Radeon 5800 Series
under display adapters so I guess the cards are there... but it's not working.
Gotta love ati.
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
Raijian
177 (0.04/day)
Canada
I followed that guide, but thanks!
I'm going to try re-seeding the card.
Still nothing showing in CCC.
