Dead pixel yes or not?? Please help.
1,568 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w 5.1 Home Theater | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Today I was browsing some websites when I suddenly noticed an almost black spot near the top left corner of the screen.
I checked with AIDA monitor diagnostics and the color remains black in all red, green and blue solid fill.
Is this a dead pixel?? If yes, any ways to repair it?
2,516 (0.48/day)
Canada
Looks like someone poked their finger... Not a dead pixel, from my experience...
Pixels are usuall .311 > .273 in size IIRC
1,568 (0.31/day)
Kolkata, India
But it remains black and I have checked from outside turning the screen off that there is no external damage. What can it be?
2,516 (0.48/day)
Canada
Prolly the screen protector got poked and left a mark between it and the display panel, would be my guess anyways... Open it up and clean it up with some screen/glass cleaner maybe?
It's not a dead pixel from what i know. :eek:
Frick
Fishfaced Nincompoop
19,280 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
It could be a damaged panel as well.
2,516 (0.48/day)
Canada
Here is a sample of a dead pixel, you can Google IMG search for more views if you like...
From someone poking :p I didn't want to bin the monitor right away... :eek:
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Dumb question, but are you absolutely sure the screen surface is CLEAN?
Like ^m1dg3t shows, that is a single stuck or dead pixel.
1,568 (0.31/day)
Kolkata, India
The thing is I cannot bin the monitor. I will try to repair it because I was born in a time when we fixed things instead of throwing it away. :)
Whatever it is, can it be repaired?
I remember once upon a time I didn't know about dead pixel and my Samsung SGH-E250 had one blue spot on the screen from the very first. After 2 years, I got to know that it was a dead pixel and then..... LOL. Warranty was long over. :p
2,516 (0.48/day)
Canada
Your best bet is to clean it as best you can, if you can open the case and get between the panel and glass that would be awesome! But no guarantees, unfortunately... :eek:
Good luck! :toast:
1,568 (0.31/day)
Kolkata, India
Yeah I just cleaned it(and hence the long time to reply. :p ). The spot is still there.
Good luck! :toast:
Thanks. :) I will try that. I have some experience in repairing water damaged mobile phone LCDs so it won't be a problem. Just have to get some time. :)
de.das.dude
Pro Indian Modder
8,912 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
its time to get a new panel. that blotch is the liquid escaping from that portion. probably resulted from someone poking it hard, or just old age.
1,568 (0.31/day)
Kolkata, India
Hmm maybe the later because no one poked it hard. I will have a look at the light spreading media too. Its easy to open that. I repaired water damaged mobile phone LCDs that way. :)
de.das.dude
Pro Indian Modder
8,912 (1.71/day)
VR HMD ;_;
might be the refractor glue has started to peel off.
1,568 (0.31/day)
Kolkata, India
UPDATE: Its not dead pixel. :D When I look at the screen from a high angle like from the edge very closely, I can surely see that the pixel is lit and changing colors as I change from red to green to blue to white. The culprit must be the refractor or the reflector or something must be stuck between the glass panel and the refractor or between the refractor and the reflector.
Now to open it apart and check it. Gotta get some time. :)
Cheers. :)
de.das.dude
Pro Indian Modder
8,912 (1.71/day)
VR HMD ;_;
apparently you dont know what a pixel is. that is a blotch. its too big to be a pixel.
43,598 (6.56/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Ya think? He did ask the question of whether it's a dead pixel or not.
de.das.dude
Pro Indian Modder
8,912 (1.71/day)
VR HMD ;_;
and it was pointed out already in the thread multiple times.
1,568 (0.31/day)
Kolkata, India
Exactly. That's why I asked whether its a dead pixel or not. I suspect it to be an ant sandwiched between the panel and the refractor because I was seeing some ants lately. I saw dead pixels before and it wasn't like one. But then I wasn't so sure what it was until I saw from the edge with varying colors that its perfect.
Anyways, I have a fear that if I take it apart, more dust particles will enter inside and cause even more trouble since we don't have a dust free environment. What do you suggest?
1,568 (0.31/day)
Kolkata, India
Yeah its not a dead pixel. I rechecked again. When I move from left to write, the spot moves too. Had it been a dead pixel, it should have been fixed. :)
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Live with it.
43,598 (6.56/day)
Storage WD m.2
Keyboard Tester84
Well... I don't see a way to fix it. It indeed seems to be the panel itself leaking. Unless you can find a replacement panel.
2,516 (0.48/day)
Canada
C'mon man! This. Is. INDIAAAAAA!! Get DESI with it :rockout:
Just give it a good cleaning inside/out :)
1,568 (0.31/day)
Kolkata, India
Problem solved. :D Took it apart. Opened the metal frame behind the panel and there came out a nasty piece of black thing at that top left area between the fiber refractor and the light spreader. I gently removed it with spectacle cloth. Then came my beloved vacuum cleaner. Switched to the blower mode and removed all dusts. Finally reassembled everything and presto. Problem GONE. :D
LG ROCKS. :-D
Have a drink everyone. :toast:
Frick
19,280 (2.84/day)
Piteå
No cleaning in the world will mend a broken panel. And that looks exactly like a broken panel.
1,568 (0.31/day)
Kolkata, India
No man its fixed. Read my previous post. :toast: :D
