Fake Vga and I want to flash
dadasalam
23 (0.01/day)
hello dears
i bought a shipment from china which was 78pcs of ASUS 750TI
but they sent me GTS250 which they flashed the video card to show ASUS GTX750 TI 2048MB
the drivers will not work properly and the screen lags because it thinks it is asus 750ti but the real is gts250
now i want to flash the bios to gts250 to driver work properly and be able to sell these peice of craps
i tried nv flash but with every command it says :
NVIDIA Firmware Update Utility (Version 5.227)
Simplified Version For OEM Only
Adapter: GeForce GTX 750 Ti (10DE,1380,1043,0000) H:--
F:00
The display may go *BLANK* on and off for up to 10 secon
EEPROM depending on your display adapter and output devi
Command failed to complete mailbox0 = 0000
Command id:000A Command: NV_UCODE_CMD_COMMAND_PREP faile
Command Status:NV_UCODE_CMD_STS_NONE
Error: NV_UCODE_ERR_CODE_CMD_TIMEOUT
Identifying EEPROM...
Command id:0002 Command: NV_UCODE_CMD_COMMAND_EID failed
ERROR: Error: Display adapter's EEPROM ID process failed
any help would be appreciate so much
7,142 (1.04/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Keyboard Akko 3108 DS Horizon V2 Cream Yellow | L14 G2 UK Lumi
Software Win11 Pro 23H2 UK
If u use Nvflash u need to write: nvflash -4 -5 -6 filename.rom
If i am not mistaking this will overwrite almost everything if not everything.
dadasalam
23 (0.01/day)
these are undefiend when i run these parameters i shows program parameters and not go to flashing
i used bootable usb to blind flash but no result please check image
660 (0.21/day)
127.0.0.1, London, UK
System Name Warranty Void Mk.IV
Processor AMD Ryzen 5 5600
Motherboard Asus X470-I Strix
Cooling Arctic Freezer 240 + 2x Be Quiet! Pure Wings 2 140mm / Silverstone 120mm Slim
Memory Crucial Ballistix Elite 3600MHz 2x8GB CL16 - Tightened Sub-timings
Video Card(s) EVGA RTX 2080 XC Ultra
Storage WD SN550 / MX300 / MX500
Display(s) AOC CU34G2 / LG 29UM69G-B - Auxilary
Case CM NR200p / Silverstone RVZ03-B
Audio Device(s) Realtek ALC 1220+SupremeFX
Power Supply Corsair CX550M 550W / Silverstone SX650-G 650W
Mouse Logitech G302/G502/G203 / RPG: Corsair Nightsword
Keyboard CM Masterkeys Pro M / Asus Sagaris GK100
VR HMD Oculus Rift S
Software Windows 10 Pro x64 - LTSB
nvflash -i0 --protectoff
Also disable in device manager in Windows, try this and tell me how that goes. The parameters might work outside Windows.
dadasalam
23 (0.01/day)
dear as i said i used Bootable USB with DOS
protectoff will not work i tried
660 (0.21/day)
Hmm, only now I ask myself if there's a hardware or software lockout to prevent flashing. Does that even exist?
There aren't that many commands you can try.
4,666 (0.72/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
Any chance of filing a dispute with eBay first? It's probably going to be pretty annoying and lengthy to go through, but it's likely the best thing to do.
dadasalam
23 (0.01/day)
i didnt bought from ebay , it was from alibaba.com
any way to flash this?
  • Like
Reactions: xvi
Hugis
819 (0.16/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Rii M01(3360Sensor)
Keyboard Logitech S530 - mac
660 (0.21/day)
This is as I feared, you bought the cards from a site with quite high risks of getting ripped off. I've known about this site for some time, a few relatives of mine buy electronic components from there, and it's 50/50 that they got ripped off on what they sent off.
GPU's in bulk are especially known to be reflashed cards.
Tatty_Two
Gone Fishing
25,818 (3.83/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Memory 32GB (4 x 8GB SR) Patriot Viper DDR4 @ 3600Mhz CL14 1.45v Gear 1
Video Card(s) Asus Dual RTX 4070 OC
Mouse Coolermaster Storm Octane wired
Keyboard Element Gaming Carbon Mk2 Tournament Mech
Software Win 10 Home x64
Have you tried the command line force command -f?
Example: nvflash -f -5 -6 yourbios.rom
12,062 (2.71/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Why not send these 78 cards back where you bought them from for a refund?!
dorsetknob
9,106 (1.29/day)
flash with the latest utility you can download and flash from root dir C:/ not a sub dir as you are now trying to
qubit
Overclocked quantum bit
17,865 (2.95/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
You've been defrauded, so why don't you try to get your money back instead, like rcoon said?
dadasalam
23 (0.01/day)
my dear the country name is "china" .
they send these as 750ti so why do they sent these craps if they accept return?
so they dont accept return
thanks for your care
64K
6,341 (1.68/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Video Card(s) MSI RTX 2070 Super
Display(s) Dell 27 inch 1440p 144 Hz
Keyboard Logitech G105
I wouldn't put much hope into a refund from these jokers either unless you paid by credit card then contact your card service and see if they will do a charge back.
dorsetknob
9,106 (1.29/day)
dorsetknob
9,106 (1.29/day)
You Are flashing from a command prompt (dos box ) you should have booted to command prompt only
If that's the card (s) then they also want a "DAMM" good cleaning
3,505 (0.63/day)
Purchasing from alibaba.com is like rolling a dice. I purchased an aluminum HTPC case from there once. Cheap as hell. Got it and threw it away. Scratches all over the places, missing pieces, bent places.
That place is a joke.
dorsetknob
9,106 (1.29/day)
Trade Assurance
A FREE Payment Protection Service
  • 100% Product quality protection
  • 100% On-time shipment protection
  • 100% Payment protection
To get full protection:
  • CONFIRM your order online with a Trade Assurance supplier
  • PAY to the supplier's account designated by Alibaba.com with credit card or bank transfer
Order with Trade Assurance Learn more
COMPLAIN AND GET YOUR MONEY BACK
3,505 (0.63/day)
That sounds only good on paper. Seller asked me to send it back and the shipping cost alone was triple of what I paid it for. Not worth it and the seller probably knew that.
