Front I/O Wiring Help Needed
289 (0.06/day)
Processor i5 4670K @4.4GHz 1.239V
Motherboard Asus Z87M-PLUS
Cooling High Pressure Fan System
Memory 24GB DDR3 2400MHz
Video Card(s) AMD R9 290 4GB
Storage 256GB Samsung 830, 500gb WD Blue 7200rpm
Display(s) 23inch Dell LCD
Case Silverstone Sugo SG10B
Power Supply Antec TP-750
Hi
I am currently in the middle of swapping out the insides of my Dell Studio XPS 435MT into a new CM Enforcer case and need some help in the wiring.
The board is mATX form factor and all connections seem to be standard but I have never connected a motherboard up before and dont know what goes where in regards to front IO panel for this case. Here are a few links;
Motherboard manual and conections;
http://support.euro.dell.com/support/edocs/systems/435mt/en/sm/techov.htm
Case manual and connections pg15;
http://www.cmstorm.com/files/CMStorm_Enforcer_Manual.pdf
Could anyone please explain in detail how they would connnect as I really dont know. Also where do the connections like the power and reset buttons, HDD and CPU LEDs plug into?
Any help would be much appreciated, I dont want to balls this one up!
Thanks
kciaccio
364 (0.06/day)
Processor QuadCore Intel Core i7-2600K, 4433 MHz (43 x 103)
Motherboard Asus P8Z68 DELUXE GEN 3
Cooling Corsair H60
Memory 8 gigs DDR3 Corsair Vengeance 1600
Video Card(s) POWER COLOR HD6870 EYEFINITY 6 EDITION 2GB
Storage KINGSTON HYPER X 120G SSD
Display(s) Quad set of Acer X193X's AND 2 Dell P2210 - 22"
Case Silverstone Raven 2 WHITE LIMITED EDITION
Power Supply NZXT HALE 750
Software Windows 7 Ultimate 64 Bit
The wires from your case will have makings at the end, like RS for reset switch, PWR for power ect.
Plug them into the 15
front panel connector (FP1) in order that your motherboard instructions say.
9,896 (1.86/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
the easiest is look at your board pins it usually marked with pwr, rst, hdd, pwr led
just plug it according the front panel cable
bout led if it aint turn on you may switch the + cable
289 (0.06/day)
Ok I see, but on the front panel connector on the motherboard how do I know what pins do what? because Dell just use a single plug with all connectors
Zyon
264 (0.05/day)
Australia
System Name Computernamehere/Computernamehere2/Computernamehere3
Processor i5-2500/Athlon 6000+/C2D Q6700
Motherboard P67A-UD3R/M2N-SLI Deluxe/P5K-Deluxe
Cooling Stock/Hyper212+/Unknown Coolermaster
Memory Patriot PC3-10666 2x2/A-Data PC2-6400 4x1/OCZ PC2-8500 4x1
Video Card(s) MSI GTX580 Lightning/2x Gigabyte GTS450 OC 1GB/2x HIS HD4870 512MB
Storage Seagate 1TB/Samsung 500GB/Seagate 1TB
Display(s) Samsung BX2440
Case V4 Black/Mystique 631 Silver/Soprano VX
Audio Device(s) WTF is a sound card?
Power Supply Corsair HX650/Antec Earthwatts 650W Green/None
Software Windows 7 Home/Professional/Professional
Benchmark Scores TBA
ASUS also does that with some of their products, instead of figuring out which one connects to which you connect to the white slot and then simply connect that to the motherboard.
The motherboard should say it, 15min layout always have plugs going from left to right for +/- or power/ground.
289 (0.06/day)
My motherboard instructions do not list which pins go where, I have the following pins to connect to the front panel connector;
Power Switch: 1 plug, 2 pins
HDD LED: 1 plug, 2 pins
Power LED -: 1 plug, 1 pin
Power LED +: 1 plug, 1 pin
Any ideas how I can find out which order they connect in with this motherboard
Motherboard manual and conections (15 FP1);
http://support.dell.com/support/edocs/systems/435mt/en/sm/techov.htm
Thanks
sneekypeet
not-so supermod
29,487 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
It helps if you can find the motherboard make and model versus the pc name. usually you can find the info you need from the actual motherboard maker and not the pc builder.
cadaveca
My name is Dave
17,232 (2.55/day)
Better yet, take a picture of the front panel header.
Then one wit hthe factory header installed.
Heck, I'd even pull al lthe switches and stuff out of the Dell case to figure it out.
289 (0.06/day)
I will post some pics on monday if I still havent found an answer, monday is the day i am doing it all, should be straight forward if i can get this bit sorted. The motherboard is a Dell inc one but it is made for dell by Foxconn and is a standard mATX although not listed on the foxconn website. Things will be clearer on monday when I get to see it for myself.
sneekypeet
not-so supermod
29,487 (4.36/day)
System Name EVA-01
Can you tell me what the specs of the board are?
Chipset even? I just need to get a board that is similar and the layout is likely the same;)
289 (0.06/day)
Here are some specs;
Dell Studio XPS Core i7 Socket 1366 Motherboard R849J 0R849J
General Information
The motherboard is also commonly called a main board, system board, or logic board. The motherboard holds many of the crucial components of your system like the CPU and Memory, while providing connectors for other peripherals like your speakers. We make it simple to replace your faulty motherboard or upgrade it for better performance capabilities. With one of our Genuine Dell Replacement Motherboards you can get back up and running quickly and economically!!
Features/Specifications
* Chipset
o Intel X58+ ICH10
* Processor
o Intel Core i7-920 Processor (8MB L3 Cache, 2.66GHz)
o Intel Core i7-940 Processor (8MB L3 Cache, 2.93GHz)
* Memory
o 6x 1066 MHz or 1333 MHz DDR3 Memory Sockets
o 12gb Max Total
* Audio
o Integrated 7.1 channel, High Definition Audio with S/PDIF support
* Expansion Capabilities
o 3x PCI Express x1
o 1x PCI Express x16
* Peripheral Interfaces
o 1x RJ45 Ethernet/LAN Port
o 4x back-panel USB 2.0–compliant connectors
o 1x Back Panel and 1x Front Panel IEEE 1394 (Firewire) Connector
o 6x back panel connectors for 7.1 Surround
o 1x S/PDIF Connector
o 1x eSATA Connector
* Motherboard Part Number
o R849J
Zyon
264 (0.05/day)
Australia
IF (and only IF) Dell motherboards follow the standard 15pin front panel, this is how you would do it:
|PLED+|PLED-| | SPEAKER 4-pin |
|HDD+ | HDD-| |POWER|Ground| |RESET|ground|
Others are empty space which uses no pins.
Notes:
1. Some cases with PLED+ and PLED- separated (1 space apart), don't try to connect if your case only has a PLED connector where both are next to each other (but you will be fine since your - and + are separated)
2. Note that some boards say IDE instead of HDD but it's the same thing and will work with any harddrive)
3. Some of the speaker 4-pins are separated from the front panel part, but generally the layout is always power LED on top and HDD LED on bottom followed by power/ground and reset/ground
4. Usually the case connector with the white writing faces up for power LED, all others connect with the word side face down (triangle side usually connects to the corresponding ground).
5. If it doesn't work then just reverse them and try turning on again.
EDIT: my wording sucks so just to give you an idea...
289 (0.06/day)
Thanks for your help but the motherboard diagram shows a connector with 9 pins here (part 15) and I have 6 pins to put in it (excluding the reset) http://support.euro.dell.com/support/edocs/systems/435mt/en/sm/techov.htm
Im not sure if the diagram is 100% accurate on the amount of pins but I will find out on monday when I have a proper look.
Just wondering if I do wire up the motherboard incorrectly is there any chance of screwing the board? or will it just not work untill stuff is in the right place?
2,670 (0.49/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
ah ha your in luck my friend. I have my old Foxconn board with me. I know foxconn makes a lot of stuff for dell. how do i know? when i built my previous rig the case was an old server with no front panel. I pulled one from a dell and it plugged in and worked perfectly. And i was a sytem admin for a dealership for almost 2 years... and they had nothing but dell. my board even seems to have all the plugs at the bottom edge of the board arranged the same way as your dell! I'll give you the pinout info.
289 (0.06/day)
That great thanks for the help! with the pin layout it should be easy enough!
Just wondering though if by chance the layout is not the same can I damage the board by wiring incorrectly?
Also the connectors on my case have the white writing on one side of the plug and on the other are barely visable symbols for each pin, a triangle with or without a small "s" above it, or a letter "G".
They go in this order with the white writing facing upwards, the actual pins facing down as if plugging into motherboard, and reading the pin symbols from left to right;
Power Switch: 1 plug, 2 pins - G, Triangle with s above it
Reset Switch: 1 plug, 2 pins - G, Triangle with s above it
HDD LED: 1 plug, 2 pins - G, Triangle with s above it
Power LED -: 1 plug, 1 pin - G
Power LED +: 1 plug, 1 pin - G
My question is which way round do they go
Your help is much appreciated thanks
4,815 (0.76/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
I have a Foxconn Motherboard and the coloured wires go on the left (+) hand side while the white go on the right (-).
Otherwise it's pretty easy to find which way they go.
Just plug in everything then power up the machine.
If the HDD and or PWR LEDs do not work switch them around.
It doesn't matter which way the PWR switch and RESET switch go.
Either way works just fine.
BTW don't bother about the G, as it's irrelevant although can be a concern for the new techie.
Usually G would stand for Ground or Earth wire but usually with a black wire.
But in this case it appears to be nothing of concern.
289 (0.06/day)
Why would the ground only be a concern for the new techie?
4,815 (0.76/day)
Wangas, New Zealand
Because like yourself they wouldn't be too sure what the symbol means, so it ends up being a concern.
That's the only reason :)
289 (0.06/day)
Hi
I have finished wiring it up, but am a little nervous about turning it on incase I have done it wrong. If the wires are slightly wrong is there a risk of it blowing the motherboard?
289 (0.06/day)
Hi can i just have a reply about what is the worst that could happen? I am only concerned about the front IO like the power switch
ps 100th post!
4,015 (0.77/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
ps 100th post!
nothing i can think off, the power like LED's won't be affected if you put them in the wrong plugs and the switches jut won't work
i accidently plugged my On light to the HDD connector and it worked like that for ages
289 (0.06/day)
Ah no! nothing is happening!
Monitor is on standby, some little orange light is on the motherboard, but no power up when I press the power button or reset button
What to do??
2,521 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 2X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
What to do??
If you have and ohmmeter or other continuity tester, bug out each pair of wires on the Dell harness and label them.
Then check the location of each pair in the motherboard header connector to ensure you place the correct new chassis harness pair on the motherboard header.
Or, you could always by a new motherboard and ditch that Dell P.O.S.
289 (0.06/day)
Is it worth experimenting with the wires in different places or is that not a good idea?
I do not have an ohm meter
4,815 (0.76/day)
Wangas, New Zealand
Yeah just pull out all the connectors and plug the power button into each pair of pins.
Took a look at your Motherboard and it does appear to be the typical pin layout.
If you still have the old case, take a look at what wires go to the power button.
Since the old case basically had a plug which had all the wires going to it, you can trace them this way to find the two correct pins to power up your computer.
Same goes for the other things, like the reset, HDD and PWR LED.
