Gaming Monitor 1920X1200 vs 1920X1080
214 (0.05/day)
Italy
Processor I7 6700K @4.6GHz
Cooling Liquid
Memory 16GB DDR4
Display(s) 27" LCD 2K 144Hz
Audio Device(s) G6
Software W10 Pro 64BIT
Can you tell me what resolution is more suitable (more graphic quality) for Gaming?
4,966 (0.89/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
technically speaking, more pixels = better quality. in reality, it enables you to have better quality.
so 1200 would offer the ability to have more vertical pixels, which has the ability to give better visual quality - but in the end it depends on the game, and whether it was designed for 16:9 and gives options for fov, etc - otherwise all it will do is stretch the picture for more pixels, which WILL NOT give you better quality.
1200 is technically better but 1080 is the standard, which gives benefits of it's own. in most cases there is a simple workaround like black bars to stop it from stretching, so if money isn't the issue and you want to be able to get better quality while understanding you may have to fiddle with some options or even ini files to get all the games you want to work optimally, then 1200 would be the option. i went 1080.
2,116 (0.32/day)
System Name Not named
Processor Intel 8700k @ 5Ghz
Motherboard Asus ROG STRIX Z370-E Gaming
Cooling DeepCool Assassin II
Memory 16GB DDR4 Corsair LPX 3000mhz CL15
Video Card(s) Zotac 1080 Ti AMP EXTREME
Storage Samsung 960 PRO 512GB
Display(s) 24" Dell IPS 1920x1200
Case Fractal Design R5
Power Supply Corsair AX760 Watt Fully Modular
I went 1200. It's fantastic. Even things like web browsing is better. Those extra 120px are absolutely noticeable.
3,614 (0.51/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
There are 2,073,600 pixels on a 1920x1080 and 2,304,000 on 1920x1200.
Is better in every way for gaming FOV. Only bad thing is the added stress on your hardware. More to render, more pixels to manage. The more you have the better the image, and also higher resolutions tend not to need so much Anti-Aliasing.
Completely Bonkers
2,576 (0.40/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
Depending on your GPU, your budget, and if you are using the PC only for gaming, you might want to consider a 1600x900 or 1680x1050. Your GPU might be able to give you a better quality picture on these resolutions than a higher resolution.
I would never choose for such a low resolution, because I use my PC for work, productivity, reading PDFs etc. and want more pixels for better screen and font readability and more of an A4 page on the screen at a time.
I would go for a 2560x1600 or 2560x1440 and run it at a lower resolution so that my GPU could cope. The monitor would take care of the scaling, so you set your gaming resolution to (say) 1280x800 and get nice fast gameplay.
So what's your budget, and do you use your PC just for gaming?
4,012 (0.73/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
I have used 1920*1080 displays for several years and don't care about the 16:9 vs. 16:10 debate. 16:10 monitors are less common these days and are typically more expensive than their 16:9 counterparts. Many games these days are console port trash so they tend to work great with 16:9 monitors, so that's why I have used them. I currently own a $320 ASUS VG236HE 23" 120Hz monitor and it's the best monitor I have ever owned (even though it is glossy TN panel it seems vastly better than the generic TN monitors everyone gripes about).
I still have a 2005 Samsung SyncMaster 940BW at work and while it is 16:10 it's a measly 1440*900 19" monitor and I would easily replace it with a 1080p monitor in a heartbeat.
Frick
Fishfaced Nincompoop
19,271 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
This and this. Cheap 1920x1200 are like €200 here and you can get a pretty decent IPS 1920x1080 for that.
214 (0.05/day)
Italy
Cooling Liquid
Memory 16GB DDR4
Audio Device(s) G6
I do not make a problem of money or performance of the vga, but simply the monitor (and its aspect ratio) more suitable for video games, saw that the exclusive use is gaming.
I read around that is important the native aspect ratio of the game, which is for most of them 16:9. This dont has particular problems in 1920x1200 but can lead to a slight loss of vision (the sides) or the complete picture but with black bars above and below
Completely Bonkers
2,576 (0.40/day)
I disagree completely with your first gif/flash showing 16:9, 16:10 and 16:12
16:9 is more letterbox than 16:10. But you cannot think of 16:10 as less, cutting off the sides. No. 16:10 is everything and all 16:9 offers PLUS extra pixels/FoV up and down. It's simple. They are both 1920 in the x. One is 1080 in the y, the other 1200. Clearly, one can show MORE than the other. The gif/flash is faking/falsifying the results by pretending the y is the same but x is less. How disingenuous is that?! Horizontal FoV (measured as an angle) has changed between screenshots!
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
That about sums it up. Most games support 1920x1200, so you'll actually get almost 11.1% more field of view (FOV) vertically with a 1920x1200 monitor. The horizontal FOV will be the same.
It's also a heck of a lot nicer when working with productivitiy tools and web browsing, quite simply, you'll see 11.1% more of a page.
I have TWO 1920x1200 monitors at home, one is actually a Samsung 27" 1080p HDTV (which scales a 1080p signal nicely to fill the screen). I'd ALWAYS take 1920x1200 given the choice.
Me too. With a 16:10 PC monitor, the entire width will be filled up, assuming it's an application running at full resolution.
1,842 (0.35/day)
London
System Name Jaspe
Processor Ryzen 1500X
Motherboard Asus ROG Strix X370-F Gaming
Cooling Stock
Memory 16Gb Corsair 3000mhz
Video Card(s) EVGA GTS 450
Storage Crucial M500
Display(s) Philips 1080 24'
Case NZXT
Power Supply Enermax 425W
Go 1920x1200, good luck finding one. It's better for gaming and can display 1920x1080 movies but a 1920x1080 monitor cannot display 1920x1200 :D
620 (0.11/day)
Michigan, USA
System Name Black Box
Processor Intel i7 3770K
Motherboard AsRock z77 Extreme 6
Cooling Thermalright Venemous X
Memory 2 x 8GB Crucial Ballistix
Video Card(s) 2 x GTX 480
Storage A-Data 128GB SSD, Samsung Spinpoint F3 1TB
Display(s) HANNspree 25" 1080p 2ms
Case Lian Li PC-9F
Audio Device(s) Creative XFI
Power Supply PC Power & Cooling Silencer MKII 750w
Software Win 7 pro x64
That about sums it up. Most games support 1920x1200, so you'll actually get almost 20%more field of view (FOV) vertically with a 1920x1200 monitor. The horizontal FOV will be the same.
It's also a heck of a lot nicer when working with productivitiy tools and web browsing, quite simply, you'll see ~20% more of a page.
It's not 20% more it's only 10% more.
43,598 (6.56/day)
Motherboard ASUS TUF x670e
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
I've seen this person post on other forums with the same false argument. The true way to look at 16:10 vs. 16:9 and comparing 1920x1080 vs. 1920x1200 would be to show a 1920x1200 picture and remove 60 pixels from both the top and bottom of the 1920x1080 picture.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Kwod
548 (0.09/day)
Australia
System Name Crysis 3
Processor i3570+CM 212
Motherboard ASUS P8Z77 V
Cooling Antec 1100+3 fans
Memory 2x8gig 1600 Corsair
Video Card(s) Saphire 7950 Vapour X
Storage Samsung 250g 840
Display(s) 26in LCD 1920x1200 8 bit+37in 1080p HDTV
Case Antec 1100
Audio Device(s) Xonar DG+Z5500D
Power Supply Antec 650 Hi current
Software W7 64
The panel quality and type are FAR more important than the meager diff between 1200 and 1080 pixels.
I've yet to see a TN panel come anywhere near my 4yr old 8 bit Acer 25.5in LCD.
TN panels{one's I've had a chance to fiddle with} are faint and lack depth and detail.
2,356 (0.48/day)
VT
Processor Intel i7-10700k
Motherboard Gigabyte Aurorus Ultra z490
Cooling Corsair H100i RGB
Memory 32GB (4x8GB) Corsair Vengeance DDR4-3200MHz
Video Card(s) MSI Gaming Trio X 3070 LHR
Display(s) ASUS MG278Q / AOC G2590FX
Case Corsair X4000 iCue
Power Supply Corsair RM650x 650W Fully Modular
Aren't there some games that experience inexplicable performance decreases at a particular Aspect Ratio? I remember Bulletstorm was one such example where using a 4:3 or 16:10 resolution made the game borderline unplayable at launch. I think it was since patched in the case of Bulletstorm, but it's something to consider.
Get the 24' Dell UltraSharp IPS, you won't be disappointed :p
620 (0.11/day)
Michigan, USA
Case Lian Li PC-9F
11.1% Fixed :toast:
Try again bud.
1200 / 90% = 1080.
1200 x 90%= 1080
1200x.9=1080
Or 1080/1200=.9
:toast:
EDIT: If it was 11.1 then the aspect ratio would be 16:11.1 ;)
Completely Bonkers
2,576 (0.40/day)
But with productivitiy tools and web browsing, quite simply, you'll see 15% more of a page.
Fixed.
On productivity tools, ie applications, you get the taskbar 32px, the windows title 32px, the menu bar 32px, the icon shortcuts 32px for one row, 64px for two rows. In MS Word 2003 you get the top margin 32px and bottom footer bars 64px. In MS Excel 2003 you get cell entry and column headings bar 64px and the tabs and calc footers 64px.
This means a 1080y actually gives the user "working space" of 1080-32-32-32-64-64-64=792px.
Whereas a 1200y gives the user "working space" of 1200-32-32-32-64-64-64=912px
The difference is 120/792 or 15%. If your screen shots 32 lines of text in MS Word 2003, or 32 rows in Excel 2003, that is equivalent to another 5 lines of text or 5 rows!
With MS Office 2007+, the ribbon bars add another 64px making the difference 17%
Email clients are similar to MS Office 2003. You will see another 5 emails on each screen.
NOBODY would go for 1080 over 1200 if they use productivity software.
2,750 (0.45/day)
Minnesota
I thought cutting off the sides then enlarging going from 1080 to 1200 was game-specific, but I just tried it with a few games and they all do it... What the hell man? Do any games have a vertical FOV option?
TF2 1920x1200
TF2 1920x1080
TF2 1600x1200
AOE3 1920x1200
AOE3 1920x1080
AOE3 1600x1200
Skyrim 1920x1200
Skyrim 1920x1080
Not sure what the deal is with the time of day or weather change here. I didn't do a 16x12 for Skyrim.
Stalker 1920x1200
Stalker 1920x1080
Stalker 1600x1200
These were all full-sized images. I have no idea why imageshack has since re-sized them.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
1200 / 90% = 1080.
1200 x 90%= 1080
1200x.9=1080
Or 1080/1200=.9
You're looking at the inverse
1200 is 111.1% of 1080
1080 is 90.0% of 1200
TF2 1920x1200
TF2 1920x1080
TF2 1600x1200
AOE3 1920x1200
AOE3 1920x1080
AOE3 1600x1200
Skyrim 1920x1200
Skyrim 1920x1080
Stalker 1920x1200
Stalker 1920x1080
Stalker 1600x1200
That settles it, at least for those games... it appears the FOV is better with a wider aspect ratio.
4,012 (0.73/day)
TF2 1920x1200
TF2 1920x1080
TF2 1600x1200
AOE3 1920x1200
AOE3 1920x1080
AOE3 1600x1200
Skyrim 1920x1200
Skyrim 1920x1080
Stalker 1920x1200
Stalker 1920x1080
Stalker 1600x1200
This is why I don't bother with the screen ratio debate. I simply went with a 1080p 16:9 monitor a couple years ago because it was affordable to do so. The main game I play happens to be Team Fortress 2 (which I also play competitively), and I have ~3100 hours total in it. Your testing proves that TF2 at 16:9 is superior to the other aspect ratios, and I'd imagine this is applicable to most if not all other Source based games, and that is what matters to me.
There are 169 1080p monitors and 20 1200p monitors currently available on Newegg. 1080p monitors start at $109 and 1200p monitors start at $280. Being snobby and paying a ton more for a probably outdated 1200p monitor just because "it's 10% taller" is a rather crappy argument. In fact, for slightly above the price of the cheapest Samsung 24" 5ms 1200p monitor, you can get a 23" ASUS VG236HE which is a fantastic 2ms 1080p monitor that has a 120Hz dual-link DVI input and the nicest TN panel I have ever seen. 5ms TN panels are so 2005, and I would not drop $300 on one.
How about some pros and cons for 16:9 monitors?
Pros:
Cost effective, lots of models on the market.
Standard aspect ratio for HD movies released on consumer mediums. (seriously, guys, everyone considers scaling evil, so how is scaling your 1080p movie to 1200p suddenly acceptable?)
Most games support 16:9 well, since many are ported from consoles played on 16:9 TVs.
No black bars on fullscreen 16:9 content, which is basically most entertainment content nowadays.
Potential ~10% performance increase in games (because you have to render 230,400 extra pixels on a 16:10 display, and chances are your game will still chop off your sides to fill the extra height up).
3D or 120Hz models readily available.
Cons:
Less desktop "height" (but if you have some document fetish and are so concerned with 120 pixels of height being gone, you should really consider a professional 27/30 inch monitor if you are scared of zooming out).
If you're doing any work that you are going to gripe about not having enough space to work with, get a higher resolution monitor. Plain and simple.
Brilford Wimley
53 (0.01/day)
System Name The Wimley Special
Processor C2D E8400
Motherboard GIGABYTE GA-EP45-UD3P
Memory 4gb DDR2 800
Video Card(s) 1gb 5870
Storage WD Caviar Black 640gb
Display(s) Samsung XL2370
Case Antec Something or Other :P
Power Supply Corsair TX650
Software Vista 64 bit
Benchmark Scores SuperPi 1M 11.08 seconds
Completely Bonkers
2,576 (0.40/day)
Consumer 1080 killed the workstation star. Just where did all those 2048 x 1536 TFTs go? Because that is what I want... 3 of them... side by side.
1,539 (0.28/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
16x9 is wider than 16:10 but 16:10 are higher in heights
See here-->http://www.displaywars.com/24-inch-16x10-vs-24-inch-16x9
It's all about what you like the most i guess?
16x9 are cheaper to make than 16:10 so they cost less & that is why 16:9 is the norm now
As for me i like it wider but still 16:9 is not wide enough for me i would like more...
I would like something like 21:9 or 21:10 it would be so :cool: maybe in 10 years from now?
4,520 (0.71/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
