- Apr 16, 2011
- 738 (0.14/day)
- coventry UK
System Name | Gwafwar |
Processor | Ryzen 5 3600 |
Motherboard | Msi MPG X570 Gaming Plus |
Cooling | Montech D24 |
Memory | 16Gb Adata Spectrix 3600 Cl18 |
Video Card(s) | XFX 7900 GRE |
Storage | Adata 512Gb SX8200 pro |
Display(s) | 3x 27" 1080p Lg's |
Case | Montech King 95 pro |
Audio Device(s) | onboard |
Power Supply | Coolermaster 750W Masterwatt |
Mouse | Saitek X65-f HOTAS |
Software | Win10 Pro |
I'm having an issue with both of the GTX 970's I got.
I didn't notice it at first but when using a VGA cable with the DVI adapter I'm getting a dirty signal on both cards on 2 different rigs.
If anyone can test their cards in the same mode I would be appreciative.
The test is simple. Just use a standard VGA cable to your monitor and a DVI adapter.
You are looking for the effect in this video. It will only happen on GPU demanding games and some benchmarks.
Unigine haven causes it but it's hard to spot. Warthunder and FC4 cause it all the time.
I have tried the suggested fix on that video's comments, No dice.
So I'll be buying adapters to move over to digital output. (my cards only have mini HDMI, Mini DP, and Dsub) So I had to use the DVI adapter to get the cards working on both rigs. Adapters are on order but I wanted to see if the problem was universal.
If it is universal then perhaps Wizzard or someone like can do an article on it since there are still a lot of VGA only monitors at 1080p out there.
