- Aug 29, 2005
- 7,200 (1.03/day)
- Stuck somewhere in the 80's Jpop era....
System Name | Lynni PS \ Lenowo TwinkPad L14 G2 |
Processor | AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U |
Motherboard | ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68 |
Cooling | Noctua NH-D15 Chromax.Black (Only middle fan) \ Lenowo C-267C-2 |
Memory | G.Skill Flare X5 2x16GB DDR5 6000MHZ CL36-36-36-96 AMD EXPO \ Willk Elektronik 2x16GB 2666MHZ CL17 |
Video Card(s) | Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics |
Storage | Gigabyte M30 1TB|Sabrent Rocket 2TB| HDD: 10TB|1TB \ WD RED SN700 1TB |
Display(s) | LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p |
Case | Asus Prime AP201 White Mesh | Lenowo L14 G2 chassis |
Audio Device(s) | Steelseries Arctis Pro Wireless |
Power Supply | Be Quiet! Pure Power 12 M 750W Goldie | 65W |
Mouse | Logitech G305 Lightspeedy Wireless | Lenowo TouchPad & Logitech G305 |
Keyboard | Ducky One 3 Daybreak Fullsize | L14 G2 UK Lumi |
Software | Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan) |
Benchmark Scores | 3DMARK: https://www.3dmark.com/3dm/89434432? GPU-Z: https://www.techpowerup.com/gpuz/details/v3zbr |
Here is a small guide on how to get Windows to see your Killer E2200 NIC as a Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller....
the Killer E2200 NIC is actually more or less a Qualcomm Atheros AR8161 chip.
1. Download the Driver for the Qualcomm Atheros AR8161 on qca.qualcomm.com.
in the Download Sector this driver is called "WIN_AR816X_Windows WHQL Driver V2.1.0.21" under AR816X QCA817X Family Drivers.
Link: https://link-4share.com/download/TuqLAbo3ce/atheros_ar813x_ar815x_ar816x_v2_1_0_21_whql_zip.html
2. after downloading the zip file, unpack it somewhere.
3. Go into Device Manager. (Right click on Computer-->Properties then on the left side under "Control Panel Home" you see "Device Manager"
4. When "Device Manager" opens locale and expand "Network Adapters", you do that by clicking on the arrow head or double click on it.
5. When "Network Adapters" is expanded you show see your Killer E2200 NIC
6. Right click on the "Killer E2200 NIC" and choose "Update Driver Software..."
7. These Next steps are important so follow them carefully....
Choose "Browse my computer for driver software"
8. Now choose "Let me pick from a list of device drivers on my computer
if you just do it as you normally with with "Search for a driver software in this location:" you will get that "Windows was unable to install the driver" (And no this isn't because i already have the driver installed it's because Windows see's the card as a Killer E2200 NIC):
9. Click on the "Have Disk..." button:
and then hit the "Browse" button, and go into where you have unpacked the driver, then find the folder called "Common_Dri" as u can see in the picture below...
Choose the folder that matches your OS like for Windows 7 32bit u take "Win7_32", for Windows 7 64bit u take "Win7_64", for Windows 8/8.1 32bit u take "Win8_32", for Windows 8/8.1 64bit u take "Win8_64".
11. When u find the correct inf file, you either double click on it or mark it and hit "Open":
Then you click "OK" here.
12. Then you get this window with a selection of drivers since this is a multi driver you get more then one, but scroll down in the window until you find "Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30)" mark it and hit "Next":
13. Then you will get this "Update Driver Warning" that the driver ain't verified to the hardware bla bla bla, and it can be unstable or stop working completely which it won't because it works fine...
14. Then let Windows install the driver and you will get the message "Windows has successfully updated your driver software":
hit "Close" and you will see your "Killer E2200 NIC" is now called "Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30) as shown below:
I am using this driver with my MSI Z87I Gaming AC motherboard and it works like a clam, i never had any issues with my Windows 8.1 Professional 64bit.
I decided to add the links for the Killer™ Cleaner since Qualcomm's side appearently don't exist anymore.
Link:
KillerCleaner_32bit.exe: http://www100.zippyshare.com/v/HTTVTlh5/file.html
KillerCleaner_64bit.exe: http://www40.zippyshare.com/v/9BWUx3gl/file.html
The 2 cleaners can be download from MSI too: http://faenl.msi.com/index.php?dir=Networking/Killer_Networking/
Link:
