Help finding Internal USB 2.0 to SATA
7,233 (1.03/day)
Motherboard ASRock B650M PG Riptide Bios v. 3.08 AMD AGESA 1.2.0.2 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
i am looking for something like this but it needs to be for normal size sata connector not slim:
source: http://www.diytrade.com/china/pd/10..._CD_DVD_Optical_SATA_Adapter_w_SP4_Power.html
i want to connect my Blu-ray drive up to my internal usb 2.0 header on my MSI Z87I Gaming AC board so i need to see if i can find a pcb or something like this that's made for slim optical drives i can use, but since optical slim drives got a smaller sata/power connector i can't use this so anyone know if there is something like this with normal sata connector?
12,311 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Ive read this like three time and I still cant figure out what you want
7,233 (1.03/day)
i need pcb with SATA connector on like this:
but i want to be able to connect it to internal usb 2.0 header on motherboard.
since i don't got any more sata ports left on my ITX board and i can't run a E-sata to sata cable into my cable, i want something like this, ino u can get it for slim optical drives but that don't work for me when i got normal 5.25" blu-ray drive.
536 (0.10/day)
Bahrain
System Name Lazyman 9000+
Processor AMD Ryzen 7 3800X
Motherboard X570 Aorus Ultra
Cooling Arctic LF II 280
Memory 2x8GB Crucial Ballistix 3600 MHz DDR4
Video Card(s) PowerColor Red Devil 5700XT
Storage Never Enough
Display(s) ASUS VG248QE+ Dell E2420H
Case LIAN LI Lancool II Mesh RGB
Audio Device(s) Sennheiser HD518 / Logitech Z623
Power Supply FSP AURUM PT 850W
Mouse Logitech G600
Keyboard Logitech G810 Orion Spectrum
Software Win 11
Benchmark Scores All over the bench
I've never seen one with an internal header...... maybe you could get something like this and just cut the wires and solder on an internal header instead?
EDIT: it may not work also as some drives draw too much power for USB 2.0 unless you can find a way to directly power it from PSU?
7,233 (1.03/day)
nope, not gonna work sry, i don't mind having internal sata power connector since it will be internal so this here won't look good inside my case.
but after i found the pic i linked in my second post, i did a little digging and found it at Addonics Technologies.
Source: http://www.addonics.com/products/adsau3.php
the price is $26,99 for it plus shipping from Addonics Technologies and amazon.co.uk u wants £20 plus shipping they are really expensive, wish i could find a cheaper one.
got a price?
12,311 (2.28/day)
Oregon
7,233 (1.03/day)
536 (0.10/day)
Bahrain
Mouse Logitech G600
Software Win 11
The problem is that its a 5.25" drive, probably your only option is the one 95Viper linked as other options would require an external power brick
95Viper
Super Moderator
12,911 (2.21/day)
got a price?
I can't find the TEAC on retail... seems it may be an OEM product.
Jetster may be right about taking an enclosure apart; I believe they may only sell them to manufacturers.
However, Amazon has one that is very similar.
Koutech SATA 6G to USB 3.0 Motherboard Vertical Adapter
And, Addonics makes one similar: ADSAU3 - (Serial ATA to USB 3.0 converter
Ebay has a couple of similar items listed; however, they are shipped from China and the sellers are not high volume sellers.
Mussels
Freshwater Moderator
58,413 (7.98/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
you wont find it, because optical drives need 12V power, and USB only provides 5V.
the only way i see this working is with a PCI USB card with a regular USB port (not a header!) inside the case, and a USB-> sata dongle, using native SATA power.
i dont see why you'd go to such lengths to do this. performance of your drive will be hampered, and IIRC you wont be able to play encrypted blu ray movies over USB- something i read a while back.
95Viper
Super Moderator
12,911 (2.21/day)
Just like the TEAC... the Addonics & Koutech, both, derive 5V and 12V power from the power supply's sata power connector. And, they seem to be clones of the TEAC part.
I don't understand why it would not play the HDCP content, as, they sell USB connected drives that do.
Mussels
58,413 (7.98/day)
Oystralia
it might have changed, but i had issues with it years ago when i first tried blu ray over USB.
AsRock
TPU addict
19,034 (3.01/day)
UK\USA
got a price?
you can get them with external DVDplayers, i have one here and it was $25 a few years back from Amazon.
7,233 (1.03/day)
i need blu-ray not dvd player. i use my pc for watching blu-ray don't want a stand-alone player.
7,233 (1.03/day)
don't know how good it be though and your going pay other wise.
http://www.amazon.com/dp/B001TVAU0E/?tag=tec06d-20
Did you look on ebay ?.
i tried ebay not much to find at a good price, i can get a NoName Blu-ray player that can also do 3D for like £44 with shipping but then i would rather buy a Asus SBC 06D2X-U for about £10 more i know it's not 3D but atleast it's a name i can support.
