help me choose a watercooling kit 290X Xfire
1,576 (0.23/day)
The Gulag Casino
System Name ROG 7900X3d By purecain
Processor AMD Ryzen 7 7900X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
well ive finally finished tuning my new pc and providing my health holds out I would like to begin purchasing the parts for watercooling my 2 290X gpu's....
the parts I have so far are:
GPU Block x 2=Aqua Computer Kryographics Hawaii Radeon R9 290x
Radiator=Watercool Radiator MO-RA3 9x120 PRO - black stand=Watercool MO-RA3 Stand - black
Pump=Aqua Computer Aquastream XT USB 12V Pump - Ultra Version mounting kit=Aqua Computer Pump mounting kit
Reservoir=Aqua Computer Aqualis ECO 150ml with Nano Coating
Bridge=Aqua Computer Kryoconnect for Kryographics 1 and 2 slots - SLI bridge
Temperature senser=Bitspower G 1/4" Black Sparkle Temperature Sensor Stop Fitting
LCD water temp poster=Aqua Computer Aquaero 5 XT LCD Fan-Controller
Tubing&connectors=No idea
im stuck on which barbs/connectors I need...
its 10years since I water cooled my pc and usually I'd just research this myself...
but at £10 per connector and i'll need a few will become extremely costly mistakes...
I need the advice of the pro's here who can tell me which to avoid and which are the best ect....
thanks TPU...:toast:
1,927 (0.44/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
All my fittings are 13/19mm EK compression fittings because they were the cheapest and biggest(slightly lower restriction) fittings not made by Alphacool. They were a pain to install and I ended up with alot cuts on my fingers but apart from that I think they're great.
1,715 (0.39/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Display(s) Samsung Odyssey G7
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
subscribing.... :toast:
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
so which tubing and fittings should I get.... that will fit the gpu blocks and radiator.... with the G1/4" thread size ...
they are 10-20 pounds a fitting so I could do with getting this right first time...
thanks in advance...:toast:
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
am I in the right section... please move to the right part of the forum if needed... thanks in advance....
the54thvoid
Super Intoxicated Moderator
13,055 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
I tend to go for 1/2" barbs with 7/16" ID tubing. I've never used compression fittings. I'd advise you plan your layout and buy fittings that suit angles, i.e. rotary barbs or angled ones. A nice clean cut on a barb fitting can look very pleasant and a tubing ID that is narrower than your barb fitting is exceptionally secure.
I'd not buy cheap rotary fittings - if you get them, buy a decent brand - not wam-bam no names. I've used koolance and Bitspower fittings mostly but also a few XSPC ones. Standard barb fittings are NOT expensive.
The fittings below are 1/2" Bitspower 90 degree rotary fittings using 7/16" ID tubing.
6,765 (1.38/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Is 7/16 really small enough to not leak on a 1/2 barb? I have 7/16 tubing and 1/2in barb but still use clamps. I have though about going to 3/8 tubing that I expand to fit around 1/2 barbs with hot water.
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Are you wanting compression or just barb fittings? Standard tubing seems to be 1/2" ID by 3/4" OD. I definitely recommend Bitspower compression or barb fittings.
I would never do 1/2" ID fittings with 7/16" ID tubing, without clamps. But I don't like the look of the clamps so I usually opt for compression fittings. They look cleaner IMO, but some people don't like the bulky look they have.
Solaris17
Super Dainty Moderator
26,968 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
It depends alot on the tubing. You need tubing that doesnt get too flimsy if your pumping tons of hot water through it. From my experience anyway.
manofthem
WCG-TPU Team All-Star!
10,960 (2.16/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
OP, that is a beautiful block for the 290(x) cards, sexy choice :toast:
the54thvoid
13,055 (2.39/day)
Software W10
It's absolutely solid. If you try pushing the tubing over the barb you'll realise how difficult it is and you'll see it's pretty infallible.
I usually need to cut the tubing from the barb when i'm redoing my loop, it's very hard to pull off. It doesnt fall off.
I've only been water cooling for about 4 years but I've never had a tubing leak using the above.
974 (0.18/day)
System Name Grond
Processor Ryen 5 3600x PBO ~ 4.4GHz / fabric at 1900
Motherboard MSI b550 Tomahawk
Cooling XSPC Raystorm CPU w/ am4 mounting bracket+ 2 RX360 radiator + xspc Razor R9-290 w/ backplate
Memory 32gb Crucial Ballistix @ 3800
Video Card(s) XFX R9 290 w/ XSPC Razor full cover block and backplate
Storage WD SN850 1tb-OS, SN750 1tb, Samsung 860 Evo 1tb, WD blue hdd 4tb
Display(s) Samsung 23" 120hz 3d LCD w/ 3d glasses, using 'lightboost' trick
Case NZXT H630 white watercooling case
Audio Device(s) Onboard realtek ALC 1200+ Sennheiser HD 598
Power Supply XFX Pro 850 XXX semi-modular
Mouse Logitech G703 Wireless
Keyboard Steelseries 6 v2
Software Windows 10 Pro (Had some mystery error on Win7 and decided to go W10)
Straight barbs would be cheaper, but compression fittings look better.
Just make sure thet the barbs/fittings are the same size as your tubing and you are good to go.
Or go for 1/2" barbs and the 7/16 tubing like the54thvoid. I've tried the method out and it works great, but I like compression fittings better because it's easier to remove the fittings and hose.
Damn that watercooling gear you listed looks pretty sweet. I was thinking about getting the MORA3 non-pro, but I've already burned through my budget.
Norton
Moderator - Returning from the Darkness
14,108 (2.98/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
If you want a little more insurance you can add a small zip tie just behind the first barb on the fitting (see pic)
I'm using 3/8"x5/8" tubing on that 1/2" barb and the fit is plenty tight, but I found that a $0.10 zip tie really put my mind at ease ;)
