MrHydes
- Jun 5, 2008
- 106 (0.02/day)
Processor | INTEL CORE2 DUO E8500 @4.1GHz |
Motherboard | ASUS RAMPAGE FORMULA X38 |
Cooling | Tuniq Tower 120 |
Memory | TRANSCEND PC9600 DDR 1200 |
Video Card(s) | EVGA 9800 GTX |
Storage | WD RAPTOR X |
Display(s) | SAMSUNG Syncmaster 2032bw |
Case | SILVERSTONE TJ07 |
Audio Device(s) | SB X-FI XTREMEGAMER FATAL1TY |
Power Supply | LC-POWER ARKANGEL 850W |
Software | MS XP PRO SP2 |
HP Voodoo Omen
The pinnacle of design and performance
Supporting up to four graphics processing units and sporting advanced
thermal engineering, the modern-styled Voodoo Omen blends art and
technology inside and out. The Omen features integrated copper liquid
cooling pipes and a built-in, fully functional LCD auxiliary screen. Its
advanced thermal engineering with liquid cooling makes it run quietly, even
when performing at high levels.
Customers can add the finishing touches to their Voodoo Omen via an
extensive palette of Voodoo Allure paint color choices. The new Voodoo
Omen will be available for a starting price of $7,000.
Other key features include:
* Vertical diffusion thermals - the power of natural convection currents is
harnessed for advanced cooling and quiet acoustics.
* Auxiliary LCD - a 7-inch (diagonal) built-in auxiliary LCD is a full-function
secondary display.
* Advanced liquid cooling - copper cooling pipes embedded in the chassis,
aircraft-quality quick-release hose connectors, and more combine in one of
the most advanced liquid cooling systems on the planet.
* Tool-less architecture - side panels, hard drives, video cards and other
critical components can be removed without tools.
* Top-loading cables - cables plug into the system under a removable top
panel, improving access to the cable connections and contributing to the
clean exterior design.
* Interior lighting - battery-powered interior lighting gives users visibility
to upgrade components when the system is powered off.
Source: techpowerup
