Is Fiji XT a dual GPU?
the54thvoid
Super Intoxicated Moderator
13,234 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
7,607 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
wouldnt be surprised if this is true. but wouldnt it be called 395x
3,890 (0.81/day)
Processor AMD Ryzen 7 3700X
Cooling AMD Wraith Prism
Display(s) Samsung 50" QN94A Neo QLED
Case Antec 1200
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
It's boring either way, fucking release it.
4,332 (1.10/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
Right from the unreliable horses mouth.
http://fudzilla.com/news/graphics/37373-amd-fiji-has-two-gpus
Makes some sense - TDP, leaked (Titan X busting) performance, requires water cooling, the jump from 4GB HBM to 8GB HBM, the requirement of two gpu's for a certain software in VR.
If that is true, its a huge disappointment...
But then again we will not know until we see it in person. But I would be confused if they did that because it would not be interesting enough to take a crown especially considering that they would still be held back to 4gb per GPU...
Also it would not fit with this leak from earlier about the new AIO. The AIO shown was designed more with a single GPU in mind so to me it still has to be a single GPU card. But that is my speculation...
http://wccftech.com/amd-fiji-xt-r9-390x-zauba/
2,097 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
I don't think it's a dual gpu.That might come later in the form of a R9 395x or something.
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Okay this is pretty much fud and heres why
If we lookat GCN cores and their performance and look at the 285 Tonga, then the 390x would have similar capabilities to a 7990 ~ 295x2 now due to scaling being worse on dual gpus we can expect look ing at specs that the 390x should come in around 7970 xfire performance in terms of cores / rops / tmus if we believe the specs reported.
390X
Shaders: 4096
ROPs: 64-128
TMUs: 256
285 Tonga:
Shaders: 1792
ROPs: 32
TMUs: 112
280x:
Shaders: 2048
ROPs: 32
TMUs: 128
295x2
Shaders: 5632
ROPs: 128
TMUs: 352
Looking at the specs and the minor efficiency gains in GCN with recent revisions the 390X Should perform somewhere between R9 285 Crossfire and R9 290 Crossfire
At 4k Resolution
Considering Crossfire doesn't tend to scale great across all titles we can extrapolate that performance of the 390X if its specs are correct it should perform somewhere between the 7990 and 295x2 leaning closer to the 295x2 due to improvements in silicon / memory bandwidth etc. That means 10%-46% faster than the 290X. An increase of 30% would put the 390X on par with Titan X. 295x2 has a lead of 20% over the Titan X. that makes a gap of 50% which is VERY close to the supposed 60% increase. This of course boils down to if the leaked specs are correct. With things as they are I expect the 390X to be about 30% faster than a 290X at standard resolutions. At 4K we might see an increase of around 45% realistically which would allow for a R9 390 to place in about 15% behind that while a tweaked 290x with higher clocks could then fill in easily enough as the 380X and so on.
390X
Shaders: 4096
ROPs: 64-128
TMUs: 256
VS
295x2
Shaders: 5632
ROPs: 128
TMUs: 352
The 390X as a dual GPU would make no sense as it would be according to specs weaker than the 295x2.
14,223 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Makes no sense.
The new single chip GPU will beat the TitanX, but probably not by as much as speculated.
It's not exactly a major leap from 4Gb to 8Gb for top tier cards, there are cards with more that are single chip also.
AIO cooling solutions are being touted for a number of cards now, not just dual chip models.
I think there will be a dual chip offering in the future, based on the new card, but not quite yet.
