Sorry, but that is not a thing.
It does not matter if it dries out. Contrary to what many seem to believe, TIM never needs to be replaced just because it is X number of years old, or because it has dried out. It will easily last 10, 15 years or longer
AS LONG AS the cured bond between the two mating surfaces has not been broken.
I note there is not
one TIM maker, CPU/GPU maker or cooler maker who says TIM needs to be replaced regularly.
The ONLY reason TIM comes in a semi-liquid form is so you can squeeze it out of the tube and spread it out easily and evenly. Remember, the purpose of TIM is for the solid particles to fill the microscopic pits and valleys in the mating surfaces to push out and prevent any insulating air from getting trapped between the device and its heatsink. Even if those liquid solvent components dry up, the solid materials remain in the microscopic pits and valleys and are still doing their job.
Yes, a fresh new layer of TIM "
might" provide a few degrees cooler temps, but the fact remains, if your systems actually "needs" those few degrees to keep from crossing thermal protection thresholds, your temps are already too high and you have bigger, more urgent cooling issues to deal with first - such as case cooling.
Which fits the typical (2 - 5°C) improvement normally seen. Sadly, the risk of damaging a pin, the socket, or worse, zapping the CPU with ESD is greater than a few degrees of extra heat an old application of TIM might impose.
I don't see any temps in your last post to indicate why it is throttling. Perhaps there is a setting in your BIOS Setup Menu that is just set too low? I note according to the
ARK for your CPU, your temps your well under the 100°C T-Junction rating. That said, the CPU is not the only heat sensitive device in there.
You cannot rule out that some component is failing.
