Newbie's Questions on Motherboard Connections
86 (0.02/day)
Thanks to all of y'alls help I have the following items ordered and on the way:
Intel i5 2500 (Non K)
ASUS P8Z68-M Pro LGA 1155
CORSAIR Vengeance 8GB (2 x 4GB) DDR3
Now I have never built/worked on a PC before, but through loads of studying in preparation, most of the hookups are pretty straight forward. I know that with my new motherboard my Firewire will not be supported (no 1394 hookup). So now on with the questions:
1. If my stock front panel has USB ports (rated at 2.0), will they automatically become 3.0 when I hook them up to the 3.0 connectors on the motherboard? Basically just asking if the only thing that makes them 2.0 or 3.0 is what kind of connector they are hooked to.
2. I have a 10 pin audio hook up on my front panel. It is labeled F_Audio. I am unsure if it is HD or AC97, but believe the latter due to it being 2-3 years old. Here is the diagram in the manual of the new ASUS board (note mine is an old ASUS made specifically for HP, which has no manual to be found online or otherwise, from what I have read ASUS does not publish a manual for these because they are custom for specific manufacturer).
Here is a description of how mine is hooked up (for reference I used A and B to represent wire 1 and 2 of a specific color):
Black (2 wires)--Empty----------Green(A)--------Empty-----------Black (1 wire)
X---------------X---------------X---------------X---------------X
Red(A)---------White(A)--------White(B)--------Red(B)----------Green(B)
Wires coming from the headphone jack:
1 of the 2 combined black wires and the third black wire
White(B)
Red(B)
Green(B)
Wires coming from Mic jack:
1 of the 2 combined wires (note: it is thicker than the second wire in the same pin)
Green(A)
Red(A)
White(A)
Now I know how to move the pins between the spaces, but don't know the proper layout and was wondering if someone could help me out.
3. Final question is about front panel. Here is the diagram for the new ASUS board:
Now on my current board, I only have a 10 pin connector, which looks like this:
Black------Blue-------Red--------Black-------Empty
X----------X----------X----------X----------X
Yellow-----Black------Empty------Empty-----Empty
Now I have no clue how these will hook up. I will not be using a speaker system. I only want the power to come on and the blue LED (running) and amber LED (Idle) to work. If it is not possible I would mainly just like for it to turn on when I push the button (LOL). If someone could make sense of these wires I would appreciate it. Again thanks for you time and I would not be asking if I could find an actual diagram of my current MOBO, but that is a "NO GO".
4,012 (0.74/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
USB 3.0 connectors have 9 pins each and thus USB 2.0 connectors do not support the USB 3.0 standard. http://en.wikipedia.org/wiki/File:USB_3.0_A_Buchse_13.jpg
You do not need to connect the front panel audio connector if you are not using the case's front ports. For the front panel button and lights, I usually cut up the proprietary block connector and attach the individual pairs to the respective spots on the motherboard.
5,061 (0.90/day)
Processor AMD Ryzen 5 7600
Memory Kingston Fury Beast DDR5-5600 16GBx2
Video Card(s) Gigabyte Gaming OC AMD Radeon RX 7800 XT 16GB
Storage TEAMGROUP T-Force Z440 2TB, SPower A60 2TB, SPower A55 2TB, Seagate 4TBx2
Display(s) AOC 24G2 + Xitrix WFP-2415
Case Montech Air X
Audio Device(s) Realtek onboard
Power Supply Be Quiet! Pure Power 11 FM 750W 80+ Gold
Mouse Logitech G304
Keyboard Redragon K557 KAIA RGB Mechanical Keyboard
Why not take an actual picture of your board first?
4,016 (0.69/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
I'm not sure about the USB 3.0 to 2.0 question, but I know they use different physical motherboard connectors, so at the very least you would need an adapter to do that.
Your front panel audio on the case is neither HD or AC97, because it's the motherboard that determines that. In this case, it will be HD. Each pin is separate on the connector so that they can be arranged to support either HD or AC97, and they should be labeled so you can just follow the MB diagram for HD audio.
For the other front panel connectors, each one should be labeled just like in the diagram so you just match those up. "-" or "ground" wires are typically black or white, and all the others should be colored, so just make sure you orient the connectors the right way.
86 (0.02/day)
OK, in reference to the front panel. I believe I am following you. I can remove the wires from the connector and connect them straight to the pins (they each have a little brass fitting on the end of them that should slide onto the pins). Would you think that RED/Black (closest wire to the red one) would be main power. Blue/Black (closest to the blue wire) would be the blue LED. Yellow/Black (closest to the yellow wire) would be the amber/yellow LED. This seems to make sense going by wire color. What do you think.
4,016 (0.69/day)
Ohio
Red/black is power, I'll have to check on the others
edit: hmm, actually I just looked at mine and red/black is HDD LED, blue/black is power LED, amber/black is power switch, and purple/black is reset switch
I don't think everybody uses the same colors though, but you can just trace them
86 (0.02/day)
For the audio, I believe if I am looking at it right. Port1 L, Port1 R, Port2 L, and Port2 R are interchangeable. Meaning as long as I hook up 1 red wire and 1 white wire form each port then this should work. Meaning red and white from headphone wires go into Port1L and Port1 R. Red and white from Mic wires go to Port2 L and Port2 R. I believe GND is gonna be the double black wires that are connected to 1 pin. This leaves me with 3 wires; 2 green and 1 more black. Now I don't know where these wires go, but it makes sense that the green wire from the headphones would go into the SENSE1_RETUR slot because the headphones wires go into Port1 L and R. The green wire from the Mic would go into SENSE2_RETUR for the same reason. This would leave me with 1 black wire and SENSE_SEND and PRESENCE# slots still open. Comments?
86 (0.02/day)
Thanks. I just traced mine and found out that what I had was correct.
Red/Black = Power
Blue/Black = Blue LED
Yellow/Black = Yellow LED
So simple, who would've thought :eek:
1 problem solve, now just got the audio to go.
JrRacinFan
Served 5k and counting ...
20,093 (3.17/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
I would skip the front audio unless you use a headset on a regular basis.
4,016 (0.69/day)
Ohio
Trust me, you won't miss the front audio. I ran for years without any front panel connections except two wires hanging out that I'd short together when I wanted to turn the PC on or off and it never bothered me :laugh:
mediasorcerer
978 (0.21/day)
coast ,melbourne
System Name THE MEDIAMACHINE
Processor i5-3570k
Motherboard Asus gene v z-77 matx.
Cooling Antec h20 620
Memory 2x4gb g.skill ripjaws z 2400
Video Card(s) h.i.s radeon 7950 reference 3 gb- hooray!!!
Storage samsung 128gb~830 ssd. samsung 500gb hdrive.
Display(s) 22 inch tele.
Case circa 1996 grey rat box with no sides front.until my own is finished
Audio Device(s) inbuilt creative.supreme effects 3
Power Supply thermaltake tt-500w
Software win 7 x64-
Benchmark Scores Coming soon
You can switch the front panel audio to either hd or ac97 through the bios just as an afternote[pretty sure its the front anyway], i know cos i have xact same board as you.p8z68m pro.
4,016 (0.69/day)
Ohio
Right. It'll default to HD and that's what you should want to use anyways.
mediasorcerer
978 (0.21/day)
coast ,melbourne
Processor i5-3570k
Software win 7 x64-
hey i just noticed on my board, it only has two wires connected on the bottom right connectors as in the diagram, red and black and this is the onboard speaker[ie beep beep when turning on etc]
the front panel audio is to the left/bottom of the board[below the last pcie slot], its marked as -aafp-[its to the left of the 5 blue internal usb ports]
the blue usb ports on the rear panel are the usb 3 ports [below the esata-2 of them], the rest that are internal-[5 blue ones] and the external black- are usb 2 only.
if you need a better explanation than this i shall endeavour to provide upon request, i can take a foto and post to if needed.
id say that the 10 pin u mentioned just goes str8 onto the system panel connector?
