Overclocked HBM? It's true, and it's fast
Status
Not open for further replies.
127 (0.03/day)
Guys at hardware.info manage to OC HBM. It seems that HBM is locked in driver only. It's a 20% OC on mem, from 500MHz to 600MHz. The stock fs score is 14098, and the 1145/600 score is 16963, very impressive for an AMD in fs.
Source:
http://uk.hardware.info/reviews/615...-flag-ship-graphics-card-overclocking-results
Another successful stories
http://www.techpowerup.com/forums/threads/overclocked-hbm-its-true-and-its-fast.213875/#post-3306462
http://www.overclock.net/t/1547314/...nano-x-x2-fiji-owners-club/1720#post_24106947
http://www.overclock.net/t/1547314/...nano-x-x2-fiji-owners-club/1800#post_24109973
A big how-to with MSI Afterburner
- Save a OC profile with FuryX. Turn off MSI.
- Go to MSI folder and edit HBM clock in that profile with text
- Restart (optional)
- Now the new HBM clock is set when you load that profile :D
18,585 (2.72/day)
System Name AlderLake
245 (0.05/day)
I'd be more interested in real world results, at least too me it didn't even seem like DDR5 would be bottlenecking the rest of the Fury X card, let alone HBM. So making it go faster didn't seem like a big solution, I could be wrong though.
MxPhenom 216
ASIC Engineer
12,991 (2.53/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
Also the ROP count in GPUz is wrong. Pretty sure Fury X has 64, not 128.
3,013 (0.65/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
Officially there is no option to adjust the memory clocks, but (probably due to a bug in the drivers) we did see a slider to adjust memory clock frequency after every other few reboots. Hence, we could also raise the memory clock.
Hilarious bug in drivers - every other few reboots you get memory clock slider enabled in catalyst control center.
When such reboot happens, OC the memory and never turn the system off ... let it sleep at night and make the uptime last for months.
127 (0.03/day)
This proves that AMD just made it not possible in CCC, not completely locked it. It means the next MSI AB for example will be able to OC the shiny HBM.
On other note, here is a picture of a buggy GPUz 0.8.3 with FuryX (was running SoM with 3.9 GB VRAM :D)
6,757 (1.40/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Is there any real world gains from this? The memory is already extremely fast, and not the bottleneck.
127 (0.03/day)
Not really sure about the real performance. I think it does because 16900 fs is very impressive for an AMD card. But the important thing here is that we can OC the HBM on FuryX after all.
OneMoar
There is Always Moar
8,789 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
Amd limited the clocks because the silicon just can't handle it or they where getting really shitty yields on HMB
also the cores just don't overclock ... at all ... again AMD's fabs just aren't up to task .
the54thvoid
Super Intoxicated Moderator
12,858 (2.38/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
7,441 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
it's already insanely fast for memory. Fury X doesn't need moar HBM
If I recall correctly... HBM is even faster in bandwidth than L3, the heck even L2 cache of an Intel CPU albeit we don't know about the timings of the HBM...
82 (0.01/day)
North Central Ohio
System Name Custom build - I built it for gaming and some content creation
Processor Intel i7 12700K on air
Motherboard MSI MAG Z690 Tomahawk WiFi DDR4
Cooling Noctua NH-D15S
Memory 64GB G.Skill 3600 DDR4 [16GB x 4]
Video Card(s) MSI RTX 3070 Ti SUPRIM X, power limit 75% & Mem +300
Storage SSD: Sabrent Rocket 2TB, Samsung 970 EVO 1TB, SSD Samsung 860 EVO 1T
Display(s) 55" Samsung Q80T 120Hz at 4K [on my desk]
Case Cooler Master 922 HAF [3rd 200mm fan in door], 10 years old & fans still run
Power Supply Seasonic Focus Platinum PX-850
Mouse Corsair M55 RGB Pro
Software Windows 10 Pro 64-bit 21H2
Benchmark Scores [GPU Score] Time Spy: 13 925 [Power Limit 75%, MEM +300, GPU Max Power 232w, Max Hot Spot 62.4C
The memory does not need overclocked, the Fury X with 4GB already beats the GTX 980 Ti with 6GB of VRAM at 4K resolution gaming. Memory speed and data throughput are not the issue. Currently drivers are the problem. Overclockers could look at overclocking the GPU, however as I said, good drivers are sorely needed and will come with time.
The Fury X has a very effective 4096-bit memory interface and that is why memory MHz can be relatively low, it is not an issue.
72 (0.02/day)
Processor Intel Core i5 6500
Motherboard MSI H110I PRO
Cooling Stock
Memory 8 GiB (1x8 GiB) DDR4
Video Card(s) Integrated
Storage WD Caviar Blue 1 TB (WD10EZEX)
Display(s) BenQ GL2250
Audio Device(s) Integrated
Power Supply Be Quiet! TFX Power 2 300W (BN228)
Mouse Gigabyte M5050
Keyboard Logitech Y-SAF76
Software OS: Windows 7 Ultimate 64-bits
854 (0.16/day)
If overclocking of the vram is possible I really hope to see wizard give us some more benchies. :)
72 (0.02/day)
Cooling Stock
Probably higher timings as it runs at 500 MHz
127 (0.03/day)
Awesome
3dmark top 100 scores for Firestrike single gpu - lowest score at position 100 is 18730 (20938 gfx score).
http://www.3dmark.com/hall-of-fame-2/fire+strike+3dmark+score+performance+preset/version+1.1/1+gpu
The memory overclock doesn't help - it's already insanely fast for memory. Fury X doesn't need moar HBM. It needs faster core clocks.
EDIT: so 9% core OC and 20% memory overclock on Fury X is still 8% off the top 100.
Is that have any relation to the topic here? Why didn't you compare FuryX with itself when judging its overclock?
I did mention, right? 9% core OC and 20% mem OC and the score jumped from 14098 to 16963, an impressive 20% increase.
FuryX does need moar bandwidth afterall.
282 (0.04/day)
You are just speculating on all of that. Think about it for a minute. We actually have absolutely no idea why it may be performing lower than it could. We don't even know for sure that it isn't performing as well as it can, besides some stutters in some games, which may or may not mean it's running slower overall. :)
53 (0.01/day)
L2 Cache
System Name Antares V4
Processor Intel Core i9-13900K
Motherboard MSI MEG Z690 ACE
Cooling Custom Liquid Cooling (480 rad, EKWB Velocity RGB, Noctua NF-A12x25 fans, Alphacool Distro D5)
Memory Patriot Viper Elite 5 DDR5-6200 64 GB
Video Card(s) Sapphire Nitro+ RX 7900 XTX
Storage Sabrent Rocket 4 Plus 4 TB || Sabrent Rocket Q 8 TB
Display(s) LG 27UK650 x2
Case Corsair Obsidian 1000D
Power Supply Corsair AX1600i Titanium
Mouse Razer Deathadder V3 Pro
Keyboard Razer Blackwidow V4 X
Also, most of the top 100 3DMark scores are made under LN2, with disabled tessellation, modded Videocard.
C'mon :)
702 (0.15/day)
Where the hand of man has never set foot
Processor AMD Ryzen 5 3600X
Motherboard ASUS TUF GAMING X570-PLUS
Cooling Noctua NH-D15 SE-AM4
Memory 2x8GB G.SKILL Ripjaws V DDR4-3200MHz CL16 1.35V
Video Card(s) MSI Radeon RX 6600 XT Gaming X 8G
Storage Crucial MX100 512GB + Samsung 870 EVO 2TB
Display(s) MSI Optix MAG24C
Power Supply Seasonic FOCUS GX-550
Mouse Razer Viper Ultimate
Keyboard Corsair K60
1,927 (0.44/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
TSMC makes the GPU cores for both Nvidia and AMD so it's just a case of AMDs design not being able to run higher clocks. Once voltage gets unlocked I expect some cards to be able to hit 1250mhz on water at 1.35V.
Status
