overclocking a monitor :O
AlienIsGOD
Vanguard Beta Tester
5,129 (0.84/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 7700 12GB | GTX 1650 4GB (soon to be RX 5700)
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer Nitro x27OU 27" VA 165hz Freesync Premium|TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
so i happened upon this review/thread of my new Samsung PLS and it suggests o/c ing the monitor to 72hz, here is the article http://wecravegamestoo.com/forums/m...review-matte-1080p-ad-pls-72hz-overclock.html (scroll down to overlcocking link and click ).
Im wondering if it is worth it as i have a Nvidia gfx card and the thread says this:
After downloading the latest Nvidia Drivers, Nvidia Users should follow the instructions in the above image to overclock the Samsung S24D590PL.
To force 72hz in games and OC download CRU from here and follow the instructions in this thread.
72hz is idea for movies and higher overclocks like 75hz mess up the colors. Overclocking the monitor also bypasses the Nvidia signal issue.
Any help/guidance is appreciated :)
Frick
Fishfaced Nincompoop
20,020 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
So why would you want to overclock a monitor?
636 (0.14/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
:twitch: higher refresh rates don't only give moar epeen but are a lot smoother?
However, I'm not really sure on what noticeable difference going from 60 -> 72hz would make.
@OP: You should be able to make a custom profile to make it run 72hz @ 1080. Just look in nVidia Control Panel -> Display -> Customise and set it up accordingly.
If it doesnt work, it should auto-revert back to the previous settings that were fine.
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
I found that on my Dell S2340Ms that increasing the refresh rate is possible up to ~75Hz but the problem is the if feels like the display is dropping frames so it really results in a less smooth image. All in all, for my displays it wasn't really worth it.
Athlon2K15
HyperVtX™
7,909 (1.17/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
I ran my Qnix up to 96Hz and it seemed much smoother, i guess it depends on the panel?
Tallencor
TPU's First Patreon
789 (0.19/day)
N.S. Can.
System Name Francis
Processor 7700k @5.0 delid
Motherboard Rog Maximus IX Code
Cooling Corsair H100i V2
Memory 32 GB Gskill Trident Z RGB 3200 xmp
Video Card(s) MSI RX 480 Gaming x 8G
Storage Samsung960evo250GB os Samsung 860 evo 500GB (Games)Samsung 840 120 (Storage)
Display(s) Viewsonic XG 2701 Freesync
Case Corsair Crystal 570x
Audio Device(s) On board Supreme FX
Power Supply Evga 850 G3
Mouse Logitech G900
Keyboard Logitech G810
Software Win 10 Home 64
Benchmark Scores 11+12=19?
Tried this on my viewsonic and anything beyond 60 made me reduce from 1080. And if I oversampled 2560x1440 (I think) it made me reduce back down to 58 hz. In games that supported higher resolutions it looked some nice allowing me to almost drop AA on a 1080 screen. Overall for me it really wasn't worth it. Some monitors are better at accepting overclocking than others thou.
Edit: I should mention I am using DVI. Word is hdmi or displayport work better for holding the signals.
6,881 (1.43/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Have a backup or dual monitor in case something goes wrong. which will happen usually with cru.
Things might work with oc/hz increase,but when you reboot might load to a black screen.
OneMoar
There is Always Moar
8,832 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
I been using CRU for years you people live under a rock :roll:
never had a issue with CRU causing black screen on most monitors it will simply display "signal out of range" and then fall back to the default so long as you don't set the refrash rate on boot without testing it first you are fine
just make sure you are using the "detailed resolutions field" and that that default refresh rate is first on the list
Tallencor
TPU's First Patreon
789 (0.19/day)
N.S. Can.
System Name Francis
Mouse Logitech G900
This.
Mussels
Freshwater Moderator
58,412 (7.79/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
well it made a huge difference in the CRT days. if your monitor can do higher than it allows you, definitely try it.
44,209 (6.80/day)
Upping refresh rate TO 75Hz on my ol Nec Multisync LCD 1700V allowed better picture quality.
16 (0.00/day)
Forssa, Finland
System Name HP EliteDesk 800 G4 Mini
Processor Intel i5 8500T
Memory Kingston FURY Impact DDR4 3200 MHz SO-DIMM 2x8Gb
Video Card(s) Intel HD Graphics 630
Storage Western Digital 1TB WD Blue SN580 NVMe SSD
My old LG 24' lcd screen"overclocked" from 60Hz to 75Hz. The difference was noticeable when playing. A lot smoother experience even with so little increase. So i say it is worth trying :)
1,149 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
is it just me or is 60fps far too slow for a fps? anything less than 90 for me looks laggy even with a 60hz screen.
16 (0.00/day)
Forssa, Finland
60fps is enough for me. But if it goes below that, then it's not good.
7,475 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
my Catleap runs 120hz with my GTX 780 without any issues at all, of what i can see.
1,156 (0.19/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
As I've mentioned a few times, I tinkered with this quite a bit. It allowed me to get my tv to 77mhz while using lcd overdrive (in catalyst). In my opinion, the results were tangible and worth doing. That said, at that point it was a really weird game of amd's drivers vs. ToastyX working around them (not to mention the video encoding/decoding issues as well as hdmi vs dvi drawbacks). At some point I gave up because eff it, but I think for many people it can be helpful.
That alllll said, I'mma just buy a P series tv 'cause it says 120hz input ('high velocity mode') on the freakin' tin (ie there *should* be a 1080p 120hz EDID). That makes life so much easier. In many peoples' cases...if you're truly thinking of doing this, imho just buy a 120hz monitor and be done with it...the advantages of 120hz (be it 24/30hz multiples for video/film, gaming smoothness, input lag, etc) are worth it.
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
That could be an issue with particular games where user input is directly tied to the same thread that handles rendering. That would make it feel rough with respect to you interacting with the game and at higher frame rates, it polls HIDs faster giving a smoother experience. This isn't true for games that are well designed and other than that, there is no reason why 90FPS would be better than 60FPS on a 60Hz screen, even more so since frames just get dropped otherwise.
With that said, a well coded game should feel the same at 60FPS or 120FPS on a 60Hz screen.
1,914 (0.40/day)
Romania
My U2713HM went from 60 to 80 with CRU i dont see a difference in BF4, witch runs with my settings at about 100 fps.
616 (0.13/day)
Nebulas
System Name X99
Processor 5930K @ 4.7GHz @ 1.323v
Motherboard Rampage V Edition 10
Cooling EK
Memory Dominator Platinum 32GB
Video Card(s) 2x Gigabyte xtreme gaming 980ti
Storage Samsung 950 Pro M.2, 850 Pro & WD320
Display(s) Tempest X270OC @100Hz
Case Thermaltake Core P5
Audio Device(s) On-board
Power Supply 120-G2-1600-X1
Mouse Mamba 2012
Keyboard K70
Software Win10
Benchmark Scores http://www.3dmark.com/fs/6823139
27", 2560x1440 @ 100Hz with my Overlord LG panel.
720 (0.11/day)
Processor i9 9900k @ 4.8 Ghz
Motherboard Asrock Z370 Taichi
Cooling Xspc raystorm direct die, 2x 480 swiftech rads + 2x 120 block ice rads D5, Monsoon Dualbay Res
Memory 32gb G.Skill DDR4 3200mhz CL14
Video Card(s) Gigabyte Aorus 3080 Ti Waterforce WB shunt mod
Storage Samsung Evo 860 500gb, Samsung Evo 860 1Tb x2, WD White 12tb x2
Display(s) Acer xb270hu 144hz 2560x1440
Case Enthoo Primo
Audio Device(s) Schiit Modi Multibit/Magni3 - M1060 (fuzzor+LQi cable+Eikon suede)/ATH-W1000X (Purrin's mod+suede)
Power Supply EVGA SuperNova 1300w
Mouse Razer Orochi
Keyboard Tesoro
Software TeamOS W10 Pro/W7 Pro
Got my Qnix 27" 2560x1440 @ 110hz. Been running that for the past 9 months. No issues.
I came from a 24" 1080p 120hz TN panel. The 10hz difference is not really noticeable, but the IPS (or PLS?) is certainly nicer.
Waiting for some 4k panels that are less than 40" and can do 120hz @1080p without fiddling with CRU.
6,790 (1.35/day)
Processor 7800x3d
Case ThermalTake P3
Software Windows 11 64 Bit
I recently just purchased a 144hz monitor. Running at 100hz, 120hz, or 144hz, I do not not see much gain over 60hz. Natural selection 2 which I play quite a bit has incredibly fast movement where more hz actually makes a difference. Faster hz makes a difference but it wasn't anything impressive to me. Using lightboost, even on AMD gpu's, makes NS2 seem like slow motion because I don't lose my target. I feel like I am advertising but my point is that hz alone doesn't make a huge difference in my opinion. 60 to 72 just doesn't seem worth it.
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
Just for the record, it's worth noting that 72Hz is an interest refresh rate for a very good reason and I would like to explain it. Many HD videos in the USA have a frame rate of 24 frames per second of progressively scanned frames by ATSC standard, which is exactly 1/3 of 72 frames per second. As a result, you can render all frames of a video (1 video frame to 3 display refresh frames,) without dropping any frames or having to do anything special when the rates don't match up. So playback might feel less jittery as a result. Much like how video at 29.97 FPS (NTSC) would be less choppy at 60Hz because it's (practically) a multiple of the video frame rate.
So basically, when your refresh rate is above 60Hz and is a multiple of your video frame rate. You win. :p
MxPhenom 216
ASIC Engineer
13,150 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
The only monitor that does not seem to drop frames when overclocked are the X-Star Korean panels. There was a lot of talk about the idea behind dropped frames as a result in a Korean Monitor Owners thread at OCN.
1,407 (0.35/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
60 to 75 is huge. (My monitor does both at stock) However, as someone else said they might not display all the frames when overclocked.
433 (0.09/day)
Processor Intel i7 10700K
Motherboard Gigabyte Z490 Aorus Pro AX
Cooling Be Quiet Dark Rock Pro 4
Memory DDR4 Corsair Vengeance LPX 3200MHZ (2X16GB)
Video Card(s) Asus RTX4080 Super Tuf Gaming 16GB
Storage Intel SSD 670 2TB
Display(s) Samsung QLED 43QN90C
Case Phanteks Eclipse P600S White
Audio Device(s) ifi Zen DAC + Klipsch Promedia Heritage 2.1
Power Supply Corsair RM1000X 1000W 80 Plus Gold
Mouse Razer DeathAdder V3 Hyperspeed
Keyboard Keychron Q6 Pro
Have been using 120hz monitor for years, I'm not going back to 60hz forever.
