Partition a USB Flash Drive
827 (0.14/day)
Bannock County
Processor AMD FX-8320 4.1Ghz
Motherboard Asus Aura
Cooling Corsair H60
Memory Crucial Ballistix Sport 32GB
Video Card(s) EVGA 1060 SC
Storage Intel 535 Series SSD + Seagate FireCuda 2TB
Case NZXT
Power Supply EVGA 650 Watt
Has anyone figured this out? I've tried 4-5 different ways and still nothing.
Kreij
Senior Monkey Moderator
13,817 (2.09/day)
Cheeseland (Wisconsin, USA)
Why would you want to partition a USB flash drive?
No offense meant, just wondering.
827 (0.14/day)
Bannock County
Cooling Corsair H60
Case NZXT
I use flash drives to repair windows, install windows, etc ... I have created a AIO installer for Windows Vista/Windows 7 to install all version both 32 bit and 64-bit
I have this located on a 16gb usb flash drive. I still have about 7gb free and want to store other software on this flash drive. Software that I use after a reinstall, spyware/virus software, codes, etc ... I know I can keep this software on a directory on the flash drive... but just want to partition the drive.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Acronis Disk Director Suite will let you do it.
pbmaster
2,588 (0.38/day)
Savannah, GA
Processor AMD Phenom II 955
Motherboard Asus Crosshair III Formula
Cooling Cooler Master V8 CPU cooler, 120 mm and 200 mm exhaust, 3 x 120 mm intake
Memory 4 GB OCZ DDR3 1600
Video Card(s) Sapphire Radeon HD 4890
Storage Western Digital 500 GB Blacks in RAID 0/ Wesdtern Digital SE16 250 GB
Display(s) Acer 19" widescreen
Case Antec Nine Hundred
Audio Device(s) Supreme X-Fi
Power Supply Seasonic M12 SS-700HM
Software Windows Vista Home Premium x64 SP2
Benchmark Scores 3dMark 03-~62k 3dMark 05-~22k 3dMark 06-18268
Lol, Acronis will let you do anything. It's a great program.
827 (0.14/day)
Bannock County
Cooling Corsair H60
Case NZXT
Tried it... doesn't work
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
DirectorC
1,624 (0.29/day)
Florizy
System Name -= Son of a Whore =-
Processor E8400 @ 4.0GHz (445 x 9)
Motherboard Gigabyte GA-EP45-UD3R
Memory 3GB Corsair XMS2
Video Card(s) EVGA 8800 GT 512
Storage 74GB Raptor + Caviars in RAID0
Display(s) I-Inc 19" LCD 1440x900
Audio Device(s) Audigy SE & Logitech X-540
Power Supply Corsair 750TX
Software Win32 v6.1.7600
Benchmark Scores Logitech KB & Sidewinder X3
This is the scary stuff that happens when you use Google:
'USB flash drives cannot be partitioned in the Windows operating if the drive is identified as removable media. The only way to partition the USB flash drive is to flip the removable bit so that it is recognized as fixed media instead which can be partitioned like any normal hard drive'
Infoz/Appz:
http://www.lancelhoff.com/multi-partition-a-usb-flash-drive-in-windows/
http://www.ghacks.net/2009/04/17/partition-usb-flash-drives/
I got that from searching for 'partition flash drive'.
I should get paid for this.
827 (0.14/day)
Bannock County
Cooling Corsair H60
Case NZXT
I've tried that information and it doesnt work. I've tried this on 4-5 different usb flash drives as well... and, again... Acronis does not work. its been tried a few times
1,888 (0.31/day)
System Name The Beast
Processor Intel Core i3-2100 @ 3.1GHz
Motherboard Asus P8P67 LE
Cooling Stock
Memory 4GB Corsair Vengeance DDR3 @ 1600MHz
Video Card(s) 1GB Sapphire Radeon HD4650 Ultimate Edition
Storage 60GB Corsair Force LE, 1TB Samsung SpinPoint F1, 500GB Seagate
Display(s) 22" Samsung T220HD & 19" Acer X193W
Case Corsair Obsidian 750D
Power Supply Corsair HX650W
Infoz/Appz:
And people can also use Google when asking which video card is better or what CPU cooler to get, but it's easier to post on a forum and for people to share their knowledge.
827 (0.14/day)
Bannock County
Cooling Corsair H60
Case NZXT
Just so you know... you can try to increase the size of ur ego all you want... I searched google and found a ton of information on this... none of it has worked. Thats why i'm asking for help here. And, isnt that what these fourms are for? to ask for help? wtf ....
DirectorC
1,624 (0.29/day)
Florizy
You're talking about technical steps to get something done vs personal opinions and advice. So no it's not the same thing.
DirectorC
1,624 (0.29/day)
Florizy
I don't want to make you feel like I'm baggin on ya, coz I'm not. But honestly a high percentage of posts like these could be solved if the user had done research first. It's good to know you did.
Try this, it has worked for some: http://www.angelfire.com/falcon/speedload/Enabler.htm
827 (0.14/day)
Bannock County
Cooling Corsair H60
Case NZXT
You shouldn't even make comments like that... That is the whole point of using Forums. To ask questions regardless of using google, msn, yahoo, etc ... before posting questions here. I've tried all of the info out there. Over and over again. I know there is tons of info on this. But known of this has worked.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Acronis will do it, I have a flash drive with two partitions as we speak that I created using Acronis.
The problem is getting Windows to recogonize the second partition, which isn't easy, as I'm sure you found out via google. The second partition is there, created by Acronis, but Windows doesn't use it or assign it a drive letter because most flash drives are marked as removable and Windows will not allow removable media to have more than one partition, and if you create a second partition with a 3rd party utility such as Acronis, Windows will not recognize it.
So you need to find and use one of the many work arounds out there to make Windows detect the drive as a fixed disk, and not removable.
The problem is that most of the work arounds change Windows, and not the flash drive itself, so it will only work on the single Windows install you apply it to. If you move the flash drive to another computer, the second partition will not be seen...
The only real way to change this is to change the Removable Media Bit. Changing the Removable Media Bit will allow both partitions to work on all Windows systems. BootIt does this on some drives, but not all. I don't know of a tool that works with all drives. I know the Removable Media Bit is in the SCSI Inquiry Data string, but I don't know how to change that on a flash drive.
mars
11 (0.00/day)
USB Partitioning
Do you know the technical part of it? How does the flipping of the removable happen? How can we partition a USB without using a 3rd party software? Can you suggest any programming language? and what algo should I use? thanks!
de.das.dude
Pro Indian Modder
9,190 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
just use XP install CD, fo till the drives menu, partition and exit/turn comp off. done. i did this. so it works. but, you need USB boot option on, i think.
also note that windows will set aside 8mb at first, but if you reallocate, it will go away(use your logic)
95Viper
Super Moderator
13,195 (2.20/day)
Here is some info on the Lexar Boot-it app.
It works with some USB drives/sticks.
It has the option to do the flip bit, too.
(Remember to make it bootable... mark it "Active")
Lexar tool makes creating bootable USB flash drives easy
How to Create Multiple Partitions on a USB Drive
Get the file here @ 911cd.net forums or click on this link>Lexar Boot-it zip file
I, as always, checked this file with Kaspersky, Malwarebytes, and Superantispyware - it came up clean for me, please, check it yourself, as you should always do when downloading from any source that you are not 100% sure of.
This thread has risen!:eek:
mars
11 (0.00/day)
I tried Lexar bootit and yes it really works. But what I need to know is how Lexar does it. I am required to do a software that works exactly like it and I should do it from scratch. did a lot of research and im having troubles dealing with the "flipping of the bit" what does it do to the USB that makes it recognize by the computer as a fix media?
thanks for your reply :)
95Viper
Super Moderator
13,195 (2.20/day)
I hope, this may help some with what you are looking for.:)
Quoted from USB Storage - FAQ for Driver and Hardware Developers:
Quote:
Q. What must I do to trigger AutoRun on my USB storage device?
The AutoRun capabilities are restricted to CD-ROM drives and fixed disk drives. If you need to make a USB storage device perform AutoRun, the device must not be marked as a removable media device and the device must contain an Autorun.inf file and a startup application.
The removable media device setting is a flag contained within the SCSI Inquiry Data response to the SCSI Inquiry command. Bit 7 of byte 1 (indexed from 0) is the Removable Media Bit (RMB). An RMB set to zero indicates that the device is not a removable media device. An RMB of one indicates that the device is a removable media device. Drivers obtain this information by using the StorageDeviceProperty request.
For more information about the SCSI Inquiry command, see http://www.t10.org .
For more information about StorageDeviceProperty, see the STORAGE_DEVICE_DESCRIPTOR storage structure in the WDK documentation at http://msdn.microsoft.com/en-gb/library/ff566971(VS.85).aspx.
For more information on Autorun.inf files see "Creating an AutoRun-Enabled Application" at http://msdn2.microsoft.com/en-us/library/aa969330.aspx.
Some more info: Re: Howto Flip Removable Media Bit (RMB)
