Problem with heatsink, in the way of RAM
106 (0.02/day)
Farmingdale, NY
Processor Intel Pentium III Tualatin 1.4ghz (2x)
Motherboard SuperMicro P3TDDE
Cooling Antec Solution Plus CPU Cooler, replaced fan with 60mm LED fan (2x)
Memory Micron 1GB PC133 ECC Reg DDR Memory, 168-Pin SDRAM (4x)
Video Card(s) nVidia GeForce FX5500 PCI Video Graphics Card - 256MB
Storage 80gb
Case Ultra Products Wizard Mid-Tower ATX Case Black with Blue UV ULT31742
Audio Device(s) Sound Blaster Live! X-GAMER
Power Supply 400 watt
Software Windows XP Pro
This is my first quad core build, here are the pics below of the problem I've faced during installation:
I am currently using a an Intel qx9650 heatsink (which has the LED in it) and as you can tell from the pics, I am unable to use the 1st RAM slot since the heatspreader that came with the RAMs are too tall. I would like the same kind of heatsink but with 90mm that cools just as well, if not better than the current one I have now. I would like for the fan to be LED as well, but most importantly, that the heatsink be both copper/aluminum and lightweight. The reason I choose this kind of heatsink is due to cooling at the northbridge (I don't want to spend more for water cooling or modify any of the heatsinks for the northbridge that the board came with). My case has no fans on the side of the case, as it is an Antec Super Lanboy. So recommendations are welcome, I did a lot of research for choosing a heatsink, not even Newegg has the one I need >.<
Cold Storm
Battosai
15,010 (2.45/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
I 've had that feeling before man.. Gskill PiS.. it's a pain due to that ram that you like, but that cooler you like also.. Some, have even cut the cooler just to get that stick under.. but you got to much cooler there to even think about that..
now, what sites have you looked at?
JrRacinFan
Served 5k and counting ...
20,091 (3.17/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
106 (0.02/day)
Farmingdale, NY
Storage 80gb
Just newegg so far. I wanted a heatsink more like the qx9650 heatsink, like the Zalman and not like the heatsink/fan protruding outward from the board (like the Arctic Freezer Pro 7, etc). I wanted to see the fan facing me
The Zalman's I would consider, but I needed to know if they have one in 90mm LED fan, that way it prevents from being in the way of the RAM
Cold Storm
Battosai
15,010 (2.45/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
I say, look at:
frozencpu
Performance-PCs
for idea's.. also, good reviews from Tweaktown
Or, frostytech
Tweaktown will give you a good idea on newer coolers that will probably give you the height, and cooling that you need.. On both the CPU and NB..
Since your one that likes to "look and look" at things, I'm not really going to "suggest" ya anything.. But, allow you to look for something..
Also remember.. even if the cooler doesn't come with a "led" fan.. The sites, even newegg, that I listed will give you fans that can cool the cpu and have led..
913 (0.17/day)
nebraska
System Name TheBruise
Processor i7-960
Motherboard Gigabyte x58A -Ud5
Cooling Vantage ALC push pull/2x180mm fans/1x120mm silverstone
Memory 12GB Corsair Vengeance 1600Mhz
Video Card(s) 2 Sapphire Vapor-X 5870's in Xfire
Storage Ocz Vertex 3 Max Iops (OS) 300GB Velociraptor, 750 GB WD Black
Display(s) Asus 23" VS238H-P
Case Silverstone Ft01-BW Fortress
Audio Device(s) Creative X-fi Titanium
Power Supply Corsair HX-850
Software W7pro SP1
106 (0.02/day)
Farmingdale, NY
Storage 80gb
You can always replace the fan with another, whatever you get couldnt you? Maybe something like this would be beneficial?
http://silverstonetek.com/products/p_contents.php?pno=NT06-E&area=
Thanks for the suggestion, that's somewhat the kind I'm looking for where the fan is shown in front when board is vertical (for the tower), the reason I need this is because the purpose is to cool down northbridge as well as the majority of the components around the board, including RAM. Looking for versatility as well as performance. Again, thanx for the suggestion
Anyone tried this on a Rampage Formula board with an extreme 775 processor, how well do you think it will cool? Do you think it would get in the way of the RAM?
913 (0.17/day)
nebraska
Processor i7-960
Software W7pro SP1
Sure enough...theres a thank button for that btw! :)
there are specs on the site to compare, just take measurements...i havent used it myself. I know scythe and others make similar styles as well
newtekie1
Semi-Retired Folder
28,472 (4.17/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
You don't need a fan blowing down on the board to keep all that stuff cool. You can use a tower cooler with the fan blowing backwards and you will be fine.
If you definitely want a cooler that blows down onto the board, then you can try this: XIGMATEK HDT-D1284 120mm Rifle CPU Cooler
Put whatever fan on it you want.
JrRacinFan
20,091 (3.17/day)
Youngstown, OH
Storage 20+ TB
@kenred2
Sorry i came off a little harsh. I am one of the "all about form, who cares about cosmetics" kind of guys. Now I understand why you are looking at "low profile" type coolers. PM me with what you choose cause i myself am looking for a viable inexpensive solution over stock cooling in my HTPC. :rockout:
2,644 (0.47/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
if you only have 2 sticks of ram.... why not just use the other two slots and keep your current heat sink.
106 (0.02/day)
Farmingdale, NY
Storage 80gb
I have 8gb of RAM (all are the same Gskill Pi, DDR2 1066), if I have 2 sticks, I wouldn't bother posting this topic :cool:
HTC
4,637 (0.78/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
I have that board and PI black RAM but not the extreme 775 processor. Currently using this heatsink. It doesn't cool the RAM though (i have the now discontinued version and it doesn't but maybe it's replacement does) and it's pricey but it's very quiet and fit's my case (big tower coolers do not) which is why i got it.
There may be other coolers that match your criteria as well so i suggest you search around. Who knows: you may find something better for the same price or even cheaper.
913 (0.17/day)
nebraska
Processor i7-960
Software W7pro SP1
106 (0.02/day)
Farmingdale, NY
Storage 80gb
Ok, I've made my choice, it's either the following below:
SilenX EFZ-100HA1 Fluid Dynamic CPU Cooler
or
Scythe SCSK-1100 100mm Shuriken Rev. B 3 Heat Pipes CPU Cooler
I am aware that both have interchangeable 100mm fan, so my plan is to modify the fan that came with the heatsinks and put a higher performance 100mm fan on top of it that can reach from 1800 - 3600 RPM (controlled by PWM). So if possible, please let me know your input on the base surfaces of the heatsink (without fan as it will be replaced), which one is better suited for cooling a qx9770 (in other words, which heatsinks have the best heat transfer). Thanks for your time
2,331 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
106 (0.02/day)
Farmingdale, NY
Storage 80gb
Thanx, anyone else? Input is appreciated
JrRacinFan
20,091 (3.17/day)
Youngstown, OH
Storage 20+ TB
I vote for the SilenX also.
913 (0.17/day)
nebraska
Processor i7-960
Software W7pro SP1
If i had to choose id go with the Silenx as well. Higher cfm fan and Hdt pipes. The only thing i like bettter about the scythe is the heatsink design itself, looks like it has more surface area to me.
106 (0.02/day)
Farmingdale, NY
Storage 80gb
I should have rephrased the question a little better, what I meant was if a fan (both 100mm with 1800 - 3600 RPM) were installed on BOTH of these heatsinks (their original fans replaced) which one of the heatsinks provide better heat transfer, if not cool better as a result?
Both have 3 copper heatpipes connecting to the base surface of the heatsink, but one heatsink has a metal nickel plated copper smooth base (The shuriken). Is it better to have the 3 copper heatpipes be in contact to the cpu for better heat transfer or have the smooth base finish of the Shuriken? Thats all, please let me know
So far, people voted for the exposed 3 piped base of the SilenX, I'm more inclined to get it. Thanx guys
590 (0.12/day)
Latvia
System Name Zen2600
Processor Ryzen 2600
Motherboard MSI B450-A Pro MAX
Cooling Captain120EX
Memory 2x8 GB Patriot Viper Steel 360000 @3400MHz [18-19-19-39-80] DDR4
Video Card(s) Sapphire RX5700XT Nitro+ @stock
Storage WD Black 500GB NVME
Display(s) LG 32GK850F
Case NZXT H440 EnvyUS
Audio Device(s) Custom HP AMP + Sennheiser HD380
Power Supply Thermaltake Toughpower GF1 650w
Keyboard ElE Game1
I have been thinking of Cooler Master V8 myself, because I have tall ram's and I want to use them in their current positions. V8 should not interfere with RAM's, but it sure ain't low profile.
106 (0.02/day)
Farmingdale, NY
Storage 80gb
The problem I see for this heatsink is that there is a lack of cooling coming down to the Northbridge. I'm looking for coolers that utilize not only cooling the cpu, but cooling down the northbridge as well (versatility). Secondly, the thing weighs 1.91lbs, I don't want the thing potentially rip out the motherboard if I lug around my desktop computer to lan parties, etc, lightweight is one of the factors I also focus on. I don't mean to be rude, but that's the reason I made the choice on those 2 low profile heatsinks. But if I "replaced their original fan," it won't be low profile, it will cool at sheer performance (again, getting a fan that can deliver up to 3600rpm)
5,196 (0.89/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Corsair Vengeance LPX 3600MHz (16GBx4)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Steelseries Arctis Pro]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
from what ive seen the SilenX cools about as good as the stock intel cooler. If your planning on oc'ing id worry more about ur cpu temps then the nb. And if your not oc'ing then why not just get a normal not oversized stock intel.
