Red Dead Redemption using emu
14 (0.01/day)
EU
System Name PILA // PILA2
Processor intel i5 2500k@4,5ghz (1,28v) // AMD Ryzen5 5600
Motherboard ASRock Z68 Ext4 Gen3 (bios 1.20) // Asus x370 Prime Pro rev1.03 (bios 5220)
Cooling FSP Windale 4 // Noctua NH-D14
Memory 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V // GSkill Aegis 32gb@2,8GHz
Video Card(s) Gigabyte GTX960 // MSI Radeon RX Vega 56 Air Boost 8G OC (samsung mem)
Storage Samsung 64gb, 2x256gb // 2x Intel 545s 128GB, Crucial MX500 500GB
Display(s) AOC C24G1 + 46" Samsung 46es6710
Case CoolerMaster Centurion 534 modded // Corsair Carbide 300R
Power Supply corsair vx450w // Riotoro ENIGMA G2 850W 80 Gold
Mouse logitech g403 // logitech g403
Keyboard ROCCAT Suora FX // ROCCAT Suora FX
Software Win7 x64 // Win7 x64 Pro + Win10
anyone played RDR on pc using an emu?
yesterday I came upon info that this is playable and I need confirmation before I dive in into research...
can anyone confirm that it's so and can I use mouse+keyboard successfully (keymaps changeable?)?
which emu? I can see xenia canary mentioned alot?
ryzen5 5600, 32gb RAM, RX6800. I presume this should be more than enough to achieve 1080p at 60fps?
thanks
5,644 (2.98/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
It is possible:
14 (0.01/day)
EU
thanks.
I've seen that. I know it's possible, but I need above info, before I dive in into research.
If keyboard+mouse with changeable keys is not possible, that's a deal-breaker for me, and I wont spend time on research.
regards.
5,644 (2.98/day)
Poland
Mike12Eden
3 (0.38/day)
Australia
Yes, you can play RDR on PC using an emulator. Your system with a Ryzen 5 5600, 32GB of RAM and an RX6800 is definitely powerful enough to handle the game. As for controls, Xenia supports mouse and keyboard, and you can customize the key mapping to your liking. Just be sure to check the latest compatibility updates on the emulator's website to ensure the best performance settings for RDR.
