Sand Paper for lapping
4,628 (0.75/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
I figured I would throw this question in here, sorry if it is in the wrong section. But I am trying to find some super high grit sand paper to lap my CPU, the highest I have found is 800 grit wet or dry 3M. I plan on going 400, 800, 1200, 2000, and finishing with 4000. Thanks.
intel igent
4,640 (0.65/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
Try your local autoparts store in the autobody section
3,051 (0.50/day)
Pontaic Michigan
System Name The Netbook
Processor Intel Atom n270
Memory 1GB DDR2 533mhz
Video Card(s) Intel G945
Storage 250GB
Display(s) 10.1" LCD
Software Microsoft Windows 7 Starter x86
Yeah, I always get mine at autozone, and you really don't need to have THAT many steps, Just 300, 800, and 2500 is all I do.(I understand why you want the 4000 mirror finish though)
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
if you have a hard time finding ultra fine paper look up a local auto paint store (they sell sheets individually and have all grits)
Make sure to get a REALLY flat surface to sand on (piece of glass works) and move the piece in a figure 8 pattern to eliminate sanding more to 1 side than the other.
4,628 (0.75/day)
Local Autozone had some, going 400, 800, 1000, 1500, 2000.
3,051 (0.50/day)
Pontaic Michigan
Storage 250GB
Figure eights? I've always done straight lines back and fourth, in fact I read (I don't remember where anymore) that it's better to go straight back and fourth rather than a circular pattern that way there's no swirls.
intel igent
4,640 (0.65/day)
Toronto, Canada
4,628 (0.75/day)
I have read both do well.
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
no no no no no.......lol
My very first job was as a machinist and I had to work with crazy small tolerances. Sanding back and forth puts more force on the leading edge no matter how careful you are.
(just because someone that lucked out dosent mean everyone else will, better to do it right)
3,051 (0.50/day)
Pontaic Michigan
Storage 250GB
Machining isn't lapping though :/
In fact lapping is to remove the imperfections from machining.
Edit:
I guess it really doesn't matter though as long as you're getting a mirror surface on the bottom of the sink/top of the cpu.
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
the purpose of lapping the CPU is to make the surface flat. Stock they can vary by quite a bit (the reason for TIMs)
WarEagleAU
Bird of Prey
10,812 (1.60/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
+1 to case mods. I got me a lapping kit from a guy in Athens, AL. cant remember the website, I think its easypckits.com he has some different grades of paper, glass, and some wet super fine mirror finishing stuff.
intel igent
4,640 (0.65/day)
Toronto, Canada
4,628 (0.75/day)
So method for heatsink and CPU are the same?
intel igent
4,640 (0.65/day)
Toronto, Canada
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
The only diff would be to make sure not to let any water get inside the IHS (and the whole not bending the pins thing)
I took a heatgun and removed the socket off an old AM2 mobo and use that to install the CPU into than I lap the top without worrying about bent pins.
When its something important just because someone posts a log dosent mean its the right way. Try to get advice from someone that you trust.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
I've used this kit, works awesome. http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=21971
18,584 (2.67/day)
System Name AlderLake
Some people love doing it back and fourth and others just take the circular pattern:laugh:
But yeah I lapped my e2200 first in a straight line, later on when the copper was visible I changed to a circular pattern.:)
However I must say I have a weird thing going on now with my cpu, the cores are always a few degrees COOLER then the "cpu temp"
While usually the cores run always hotter then the "cpu temp"
