Sapphire Vapor-X R9 290X Tri-X OC Bios
ElastofixO
3 (0.00/day)
Hey guys :)
Does anybody have a Sapphire Vapor-X R9 290X Tri-X OC Bios fpr me?.
Both, UEFI and Legacy (only one of them is also good)
Thanks!
1,980 (0.40/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Why dose the vga card require flashing? did something go wrong!
"(only one of them is also good)" please explain
Dose vga card have dual vbios switch have tried switch in both positions?
go here fill in system specs, hardware brand names and opperating system
Have taken a look here in the TPU database
Note: looks like there are two:
113-C6710100-OU5
113-C6710100-O05
[make sure version is correct before flashing]
Make a backups of the original vbios before flashing: use GPU-Z
Example:
Select: Bios Chip Icon
Select: Save to file [VbiosName.rom] [**keep a copy in a safe place]
atb
Law-II
