Upgrade Ati mobility radeon HD 4650?
jojic88
6 (0.00/day)
l have Toshiba laptop L505-12q with 4650 graphics, can l upgrade it with mobility 5000 series?? Tnx
Mussels
Freshwater Moderator
58,413 (7.95/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
most likely not. upgrading video cards in laptops tends to be impossible, as the BIOS needs support for them.
4,357 (0.90/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
Only laptops I know with upgradeable graphics are Alienware and Dell XPS.
jojic88
6 (0.00/day)
but does graphic card has its own BIOS? its independent or not from system BIOS?
jojic88
6 (0.00/day)
This is how looks mobility 4650 its from google but l will picture next time when l clean laptop:
http://usih.merchantrunglobal.com/I...566&ImageID=583&DisplaySize=400&ListingID=287
and this is mobility 5730:
http://i.ebayimg.com/t/Dell-6K2MV-NTVGT-Alienware-M15x-Mobility-Radeon-HD5730-1GB-MXM-III-Graphics-/00/s/MTI3MFgxNjAw/z/2l8AAOxyOJxSMkJO/$(KGrHqMOKpYFIt1kTPG(BSMkJN06kw~~60_12.JPG
its almost the same with 4650...:cool:
Mussels
58,413 (7.95/day)
Oystralia
its not the same as a desktop PC. the system has to be designed from the start to be upgradeable.
212 (0.05/day)
Nashville, TN
System Name red_stapler
Processor Core i5-2500K 4.4GHz
Motherboard BIOSTAR TZ77XE3
Cooling Deepcool Gamerstorm, SP120HP chassis fans x5, NZXT Grid+
Memory Kingston HyperX 16GB DDR3 2133
Video Card(s) Powercolor 7950 PCS+ OC 1060/1500
Storage Crucial MX100 128GB / Seagate 1TB/8GB Hybrid / WD Green 2TB
Display(s) n/a
Case NZXT Source 210
Power Supply Rosewill Quark 650 Platinum
Mouse Logitech G400
Keyboard CM Storm Quickfire Rapid
Software Windows 10 Pro x64, Steam, Etc.
The 4xxx radeons used a MXM 2 slot, and the 5xxx and newer used a MXM 3 slot. I don't think you will be able to find a 5xxx or newer card that will fit into the MXM 2 slot.
4,012 (0.72/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
Most laptops don't even have removable graphics cards to begin with.
Aquinus
Resident Wat-man
13,164 (2.81/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Your GPU is soldered to the motherboard. You can't replace it.
jojic88
6 (0.00/day)
Aida64 shows PCIe x16 2.0 but l dont know what is MXM slot
l will take picture when l open laptop and if l can to remove graphic card
4,012 (0.72/day)
PCI Express doesn't have to be a socket, it's an electrical communications standard between devices. If it's an average or thin thickness laptop, the chip won't be removable because having an expansion card increases the thickness of the notebook. Even if it were removable, it certainly wouldn't be MXM or anything "standard" that could be upgrade. It's a Toshiba, I'm typing this on my A665D-S6091 and the Mobility Radeon HD 5650 is part of the motherboard.
212 (0.05/day)
Nashville, TN
Display(s) n/a
Mouse Logitech G400
You will need to review the information here:
http://www.mxm-upgrade.com/Tech_13.html
As I said before, I believe the 5xxx and newer series only came on MXM 3.0 cards, which use a different connector.
The easy answer is probably "no" because the 4650 is the most powerful MXM 2.0 card, and you already have one.
3,427 (0.65/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
