Which is better for keyboards: USB or PS/2?
EastCoasthandle
6,885 (0.95/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
I haven't seen much about this but I wonder if current USB keyboards has anything over PS/2 type keyboards?
From things like:
-keystroke delay
-ghosting
-durability
-etc
2,573 (0.38/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
Usb is better. I still buy ps2 keyboards to work with an old kvm switch , but that`s the only reason to go that way.
4,015 (0.75/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
PS/2 keyboards have some cool features though, they can turn your PC on when its compleatly off, (where USB's just do it from standby/hibernate)
they also don't take up a USB port :laugh:
I use PS/2 keyboards for compatibly with Old bios' and OS installs (also because i have no need to buy a new one)
7,023 (1.32/day)
I use ps/2. I see no reason to use usb if I have a ps/2 port
kciaccio
364 (0.06/day)
Processor QuadCore Intel Core i7-2600K, 4433 MHz (43 x 103)
Motherboard Asus P8Z68 DELUXE GEN 3
Cooling Corsair H60
Memory 8 gigs DDR3 Corsair Vengeance 1600
Video Card(s) POWER COLOR HD6870 EYEFINITY 6 EDITION 2GB
Storage KINGSTON HYPER X 120G SSD
Display(s) Quad set of Acer X193X's AND 2 Dell P2210 - 22"
Case Silverstone Raven 2 WHITE LIMITED EDITION
Power Supply NZXT HALE 750
Software Windows 7 Ultimate 64 Bit
hat
Enthusiast
21,753 (3.25/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Steelseries says:
We absolutely recommend using the PS/2 connector when possible. First,it will give you total freedom with no limit to the amount of simultaneous key presses. And, equally as important, using the PS/2 may just improve your overall gaming experience. The reason is that when you use a USB keyboard your computer is actually using CPU time polling your keyboard. The higher the polling rate the more CPU time is used to perform the polling. And because of the built-in debounce rate found on any quality keyboard, any polling rate above 200Hz is simply a waste of CPU time and really just a result of pointless marketing hype. Unlike USB keyboards a PS/2 keyboard isn’t polled at all. The keyboard simply sends a signal to the computer as key presses are made, which causes a hardware interrupt, forcing the CPU to register the signal.
I did have to turn my sensitivity down in some games after switching to a PS/2 keyboard, but that could also just have been a change in my own sensitivity level. It's pretty hard to measure that sort of thing.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
PS/2 always works. I've never met a PS/2 keyboard/computer (that had a PS/2 jack) that didn't work. I've had a lot of USB hiccups though--especially related to accessing the BIOS.
I used to use a PS/2 + VGA KVM but have moved to DVI + VGA + USB + Audio KVM. The KVM is the only reason why I switched to USB. I still often have to break out the PS/2 keyboards though for ornery computers (e.g. good luck getting USB to work on a Windows 95 computer).
hat
Enthusiast
21,753 (3.25/day)
Ohio
Yeah, I once ran into an error message from the BIOS telling me that there was an issue with my CPU's bus speed of 200MHz wasn't supported and it would run at a lower frequency of 266MHz at reduced speed (this was after doing a BSEL mod on a Celeron 430). This error appeared before USB initialized, so I couldn't press y to continue. Needed a PS/2 keyboard for that.
1,338 (0.20/day)
Processor e8200 3.93mhz@1.264v
Motherboard P5E3 Pro
Cooling Scythe Infinity
Memory 4gb of G.Skill Ripjaw 6-7-7-18@1404 and 1.62v
Video Card(s) HIS 5770 v2 940/1275mhz stock volts
Storage 1TB Hitachi
Display(s) Acer 22" Widescreen LCD
Case Blue Cooler Master Centurion
Audio Device(s) Onboard audio :(, and Klipsch 5.1 Pro Media's
Power Supply 650 Watt BFG
Software Vista 64 Ultimate
I doubt they do. FWIW I have a keyboard that is over 8 years old and PS/2. It still works great.
MxPhenom 216
ASIC Engineer
13,134 (2.47/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
PS/2 are awesome, because most PS/2 keyboards are mechanical!
EastCoasthandle
6,885 (0.95/day)
System Name MY PC
Storage 2
Display(s) 24"
Case P180
So PS/2 it is, thanks...
5,250 (0.85/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
USB is the new shape connector, so if you like it or not PS2 become over soon like FDD.
Don't forget old dead shape connector for mouse and keyboard which was called serial,‎‏ ‏and the other one it was look like PS2 it was work untill last P3 but it's gone when P4 come.
T
twilyth
It's been years since I've had a problem with a USB keyboard - even the wireless variety and even over a KVM (which only emulates a basic keyboard - to get full functionality you need a KVM with DDM - dynamic device mapping).
But then I've been changing hardware pretty frequently the past several years given my crunching jones (honestly, it's worse than crank or smack). I think the bottom line is how often will you use it on hardware that is more than a few years old. I think that's going to be most people, even if maybe not most people on TPU. So from that point of view I would have to say PS/2, but ONLY for that reason.
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
You really wont notice a difference in performance using the either PS/2 or USB. I Just stick to PS/2 because it was made for keyboards.
EastCoasthandle
6,885 (0.95/day)
System Name MY PC
Storage 2
Display(s) 24"
Case P180
For your information...The Das Model S has a 6 key roll over for usb and full key roll over using PS/2.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
By the way, PS/2's advantages (except being hardware interrupt-based) are pretty much lost on computers running (U)EFI.
6,560 (1.02/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
Wait they still make PS/2 keyboards?
EastCoasthandle
6,885 (0.95/day)
System Name MY PC
Storage 2
Display(s) 24"
Case P180
Yes and no. Most will come with a usb to ps2 adapter. An adapter that I don't have fond memories of. Over time I've noticed that the weight of both pushing on the ps2 port itself (a few years back). I didn't even noticed anything until it would only plug in on a downsloping angle. This did take a while before it started happening but none the less I stopped using them.
4,686 (0.76/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
Was using an asrock board the other day that wouldn't let me into the bios with a ps2.
EastCoasthandle
6,885 (0.95/day)
System Name MY PC
Storage 2
Display(s) 24"
Case P180
I found this thread very interesting. It discusses response times and how a slow controller might be queuing up the data and sending it out of order. That may explain where "teh" came from.
thread
Looks like this question was asked before (usb vs ps2)
3,565 (0.65/day)
By the Channel Tunnel, Kent, England
System Name Benny
Processor Phenom II 1055t @ 3.3GHz; 300x11; 1.380v; NB 2700; HT 2400
Motherboard ASUS Crosshair IV Formula (2002 BIOS)
Cooling Thermalright TRUE 120 Black + 2 Xilence Red Wing PWM 120mm (push/pull) + polycarbonate fan holders
Memory 8GB GeIL Ultra 2133MHZ C9 running at 1600MHz @ 7-7-7-21 1T 1.5v
Video Card(s) MSI Twin Frozr II GTX470 @ Stock w/CPU fan cable-tied on, as one of the GPU fans broke.
Storage 60GB OCZ Agility3 (OS);500GB WDC Grn; 1x1TB WDC Blk (Backup)
Display(s) ASUS PA823Q
Case Silverstone Raven 2 (all cables custom sleeved with velcro mod on side panel...)
Audio Device(s) X-Fi (Onboard) + Harmon Kardon HK6100 amp powering JVC HA-RX700's with Zalman mic
Power Supply Corsair HX650W
Software Win7 Pro x64
Benchmark Scores No benchies so making this space useful! Corsair M90, Logitech G19. Phobya FlexLight LED's (gawjus)
Another vote for PS/2. So much so, I'm actually quite angry at ASUS for only giving one PS/2 ports on some of it's mobo's. I use a PS/2 mouse aswell, and I was not happy at having to find a USB mouse or a converter just to use my rig.
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
Exactly! my thought...
It's been years since i see a PS2 Keyboard or mouse in stores around here (3+years) all you could buy was/is a USB to PS2 adapter...
I frankly don't care about PS2 port , they never hold quite right , always got loose after a while or get your feet to barely touch the wire than it moved a little & Keyboard doesn't work anymore & push it back in doesn't help you have to restart you PC in order for the PS2 to work again..
So yeah! USB is much better IMO
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
thread
"Teh" is just a very common typo that has been happening since teh (haha, that was unintentional but I left it there just to demonstrate) invention of the QWERTY keyboard. I think it happens because the left hand does some 70% of typing so it is trained to respond quicker than the right hand. As such, it is faster to hit e than h so your brain thinks it hit h but, in fact, it already pressed e. I doubt it has anything to do with 5-pin DIN, PS/2, nor USB.
There's really no advantage for using PS/2 on mice. Most mice these days are USB with a PS/2 adapter and mice are useless in BIOS so, yeah, it's mostly keyboards where PS/2 is still relevant.
4,015 (0.75/day)
UK
System Name PC
It's been years since i see a PS2 Keyboard or mouse in stores around here (3 years) all you could buy was/is a USB to PS2 adapter...
I frankly don't care about PS2 port , they never hold quite right , always got loose after a while or get your feet to barely touch the wire than it move a little & Keyboard doesn't work anymore & push it back in doesn't help you have to restart you PC in order for the PS2 to work again..
you must have a dodgy socket, i've never had problems with a loose connector?
