Will an AM2(+) Heatsink/Fan fit an AM3 skt?
HookeyStreet
Eat, sleep, game!
7,122 (0.95/day)
Great Yarmouth, England
Im looking for a new AM3 cooler and was wondering if the fixtures are the same as the AM2/AM2+ :confused: I know the pin placement on the actual CPU is different but would an AM2/AM2+ CPU cooler be suitable for an AM3 CPU?
Thanx in advance
rockleez
136 (0.02/day)
System Name AlanZ
Processor AMD Phenom II x2 550
Motherboard Asus M4A79XTD EVO
Cooling Xigmatek Dark Knight-S1283
Memory Crucial 2GB DDR3 1333MHz Ballistix Memory CL7
Video Card(s) HIS HD 5770 1GB GDDR5 PCI-E Graphics Card
Storage Western Digital 500GB SATAII 7200RPM 16MB
Display(s) Samsung Syncmaster 226BW
Case Antec Three Hundred
Power Supply Corsair PSU/VX Series 550 Watt ATX
Software Windows 7 Ultimate 64bit
I guess a AM2+ would, and if you get a AM3 heatsink get the Xigmatek Dark Knight, there awesome and work really well :D
HookeyStreet
Eat, sleep, game!
7,122 (0.95/day)
Thanks for the advice, but I was hoping to be able to use this: Zalman CNPS 9700 LED Socket 754, 940, 775, 939 & AM2 CPU cooler
Rintrah
11 (0.00/day)
Processor AMD Phenom II X6 1090T
Motherboard MSI 990FXA
Cooling Sunbeam Core Contact Freezer
Memory 8GB (4x2GB) G.Skill
Video Card(s) HD 5850
Storage Kingston Hyper X 128GB/ WD 1TB/ WD 2TB
Display(s) Asus 22in. 1920x1080
Case Antec P182
Power Supply Silverstone DA750
Software Win 7 x64 HP
I know for a fact AM2+ heatsinks will fit an AM3 mobo and if I remember correctly AM2 will aslo fit . AMD has not changed the retention mechanism very much. When purchasing a heatsink be aware of its orientation after installation as many heatsinks designed for amd will blow from bottom to top and not from front to back. Hope I could Help.
5,226 (0.83/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Any heatsink compatible with skt 754, 939, AM2, and AM2+ will work on a AM3 board. The only things that could be a concern is clearance around the heatsink like mosfet heatsinks, caps, or tall standing memory.
With that Zalman you should be able to have it pull cool air from the front if it's anything like my 9500 LED was.
  • Like
Reactions: Kei
rockleez
136 (0.02/day)
System Name AlanZ
HookeyStreet
Eat, sleep, game!
7,122 (0.95/day)
Thanks guys, I had a feeling that the retention mech was the same :)
cdawall
where the hell are my stars
27,683 (4.06/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
939, AM2, AM2+, AM3, and server L1 all use the same mounting config
2,313 (0.36/day)
If I told u.. I'd have to kill u
System Name Hogan's Crap
Processor Intel i3-2120 Crap!
Motherboard Dell POS Crap!
Cooling Stock Crap!
Memory 4 GB Kingston DDR3 10600 Crap!
Video Card(s) Stock Crap!
Storage 500 GB 5400 rpm Crap!
Software Windows 10 64bit
Thats a very nice cooler. Will work perfectly with what you have.
Dandel
102 (0.02/day)
Processor AMD Athlon II X4 630 (3.5ghz)
Motherboard GIGABYTE GA-MA790XT-UD4P
Cooling Sunbeam Core-Contact Freezer
Memory 2x2g A-Data DDR3 1600
Video Card(s) XFX Radeon HD5770
Case Coolermaster HAF 932
Power Supply FSP FX600-GLN
Software Win7 x64 pro
I can confirm this as well, because the cooler i have says it supports AMD AM2/AM2+ however, on stock mountings for my AM3 setup, it works with ease. The only issues that can arise from where the motherboard mounts are the size of the chipset heatsinks, and how tall the ram kit is.
5,123 (0.89/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
in fact, 939 has only 2 tightening screws, when the retention module is removed. its slightly different, but most manufactures have thought about that (thermaltake did something right finally... they produced an universal plate for every socket up to am3, for my block :D)
all other sockets are virtually the same ;)
cdawall
27,683 (4.06/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
actually 754 has two mounting screws 939 was the first with 4
5,123 (0.89/day)
North of Germany
the 939 board bogmali once sent to me has 2 screwing holes. are there differences between manufacturers?
p_o_s_pc
F@H&WCG addict
13,006 (1.99/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
I agree that 939 has 2
I don't think that is right. I remember people making a big deal there there 939 heatsinks can't be used on there AM2 because of AM2 having 4 screws when 754 and 939 have 2.
Now back on topic. The AM2/+ will work without a problem on the AM3 as the only thing that changed was the pin out and DDR3 ram.That is about all that AM3 changed
cdawall
27,683 (4.06/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
ok i just had my gf check they are 2 screws but the plastic piece is the same shape as a AM2 etc. so if the cooler is locks with the plastic mount your fine 939 and up. i'm using a cooler off one of my phenoms on her PC right now
5,123 (0.89/day)
North of Germany
as long as the retention module is mounted, every cooler that uses it, will fit;)
i use my old thermaltake block, that i modded to a makrolon cover, and it works pretty good!:)
