Will it fit? Biostar H81MHV3 / CM Elite 110
40 (0.01/day)
Processor Intel Core i5 3570K
Motherboard Gigabyte G1.Sniper M3
Cooling Antec Kuhler H2O 620
Memory Avexir Blitz 1.1 LEET Edition 16GB DDR3 1600
Video Card(s) HIS HD 7950 IceQ X2 Boost Clock
Storage ADATA XPG SX900 128Gb
Case Bitfenix Prodigy M
Power Supply Cooler Master Silent Pro M2 850w Silver
Software Window 7 Ultimate 64-bit
Planning to build a budget system for my wife. It would be only used for gaming (Dota 2 to be specific). And i want it small.
Got a CM elite 110 already, just waiting the motherboard to arrive.
Will it fit?
Biostar H81MHV3
Support the Intel 4th generation Core i7 and Core i5 processors in the 1150 package
Intel H81 single chip architecture
Support 2-DIMM DDR3-1600/1333 up to 16G maximum capacity
Cooler Master Elite 110 ITX case
Thanks!
40 (0.01/day)
brandonwh64
19,542 (3.55/day)
the board isn't even ITX, i don't even know what to call it. Bigger than an itx and smaller compared to a MATX.
Sorry I take that back. I didn't look up the board initaly
Board
Micro ATX Form Factor Dimension: 19cm x 17cm ( W x L )
Case:
Physical Spec
Dimensions
11.1" x 8.2" x 10.3" (W x H x D)
Weight
5.9 lbs.
Its close but I dunno
3,529 (0.69/day)
Netherlands
System Name desktop | Odroid N2+ |
Processor AMD Ryzen 5 3600 | Amlogic S922X |
Motherboard Gigabyte B550M DS3H |Odroid N2+ |
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 case fans | stock heatsink + fan |
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 |
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 |
Storage SK Hynix SSD 240GB, Samsung 840 EVO 250 GB, Toshiba DT01ACA100 1T | Samsung 850 Evo 500GB |
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) |
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack |
Mouse Logitech G500 |Steelseries Rival 300
Keyboard Qpad MK-50 (Cherry MX brown)| Blaze Keyboard
Software Windows 10, Various Linux distros | Gentoo Linux
Always assume that an mATX board will not fit in a ITX case. Plan builds properly to avoid nasty surprises.
sneekypeet
Retired Super Moderator
29,473 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Something funny going on here. The image in the OP is Mini-ITX, only four mounting screws. I checked the Biostar site to see it does indeed say Micro-ATX, but again, the images of the board are of Mini-ITX motherboards, not Micro-ATX.
The board in all the images will fit. The real question here is did Biostar screw up on the images, or did they screw up on the form factor naming?
brandonwh64
19,542 (3.55/day)
Im with sneeky, this board screams ITX thats why I didn't look it up at first
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It uses the 4 mounting holes of mITX, but mATX uses those 4 holes too(and usually, but not always, 2 more). The reason the board is labelled mATX is because it has two expansion slots, mITX only has one expansion slot. So the board doesn't fit in the mITX form factor, but it isn't a true mATX either, I'd call it Flex-mATX. It is labelled mATX though, because it is guaranteed to fit in any mATX case, it will not fit in all mITX cases though.
Now, as for fitting in the Cooler Master Elite 110. Yes, it should fit in that case only because the has space for two expansion slots. Usually this is so that you can use a dual-slot graphics card on a mITX motherboard. In this situation, however, the two slots will actually line up with two expansion slots on the motherboard. Now, the issue I see with this is that, due to the layout of the motherboard you will only be able to use a single slot graphics card with the case. With a little modding(of the card or the case) you might be able to squeeze a dual-slot card in there, but it isn't guaranteed.
40 (0.01/day)
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Why not just get a mITX motherboard?
40 (0.01/day)
Really in a tight budget for a second build so I have to look for savings on every pc part.
mITX board costs $80 while this one is only $45.
