T
twilyth
I already posted this on GN but I should have posted it here. Please delete from GN if appropriate.
full story - read the whole article if you can. Scary but interesting.
The Earth has a roughly 12 percent chance of experiencing an enormous megaflare erupting from the sun in the next decade. This event could potentially cause trillions of dollars’ worth of damage and take up to a decade to recover from.
Such an extreme event is considered to be relatively rare. The last gigantic solar storm, known as the Carrington Event, occurred more than 150 years ago and was the most powerful such event in recorded history.
That a rival to this event might have a greater than 10 percent chance of happening in the next 10 years was surprising to space physicist Pete Riley, senior scientist at Predictive Science in San Diego, California, who published the estimate in Space Weather on Feb. 23.
“Even if it’s off by a factor of two, that’s a much larger number than I thought,” he said.
But such possibilities likely represent only the worst-case scenario, said Robert Rutledge, lead of the forecast office at the NOAA/National Weather Service Space Weather Prediction Center. The potential dangers might be significantly less, since power companies are aware of such problems and can take action to mitigate them.
For instance, companies may store power in areas where little damage is expected or bring on additional lines to help with power overloads. This is assuming, of course, that they are given enough warning as to the time and location of a solar storm’s impact on the Earth. Satellites relatively close to Earth are required to measure the exact strength and orientation of a storm.
“It’s like being able to see a cyclone coming but not knowing the wind speed until it hits your boat 50 miles off the coast,” Rutledge said.
