1 x 18-1 pin ROG_EXT Impossible to aquire???
1,576 (0.23/day)
The Gulag Casino
System Name ROG 7900X3d By purecain
Processor AMD Ryzen 7 7900X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
As the title states people, I'm really struggling to acquire 1 x 18-1 pin ROG_EXT cable. Its sending me around the bend.
Asus is no longer the company it was. Ive emailed them and had nothing back over the last two years. The people I've spoken to simply had no idea what I was talking about.
Can anyone give me a heads up on how I could aquire another cable. Ebay do not have any for sale. google brings up nothing and the cable shops ive tried had no idea.
looking for some help. I really need this cable before I can move a pc on. Thanks in advance:toast:
SL2
2,480 (0.36/day)
I have no answer to that. This is just an idea, feel free to ignore it. ;)
If you've been looking for that long, I think you should consider making that cable by yourself. Do this at your own risk, and check the connections using a multimeter before connecting.
There's a pinout available, and it seems like it uses one regular USB (2x10) header, and one 2x8 header but I think two 2x10 headers would work just as well if there's room for it on the board.
In the other end there's a 2x20 pin female, pretty much the same as used for USB 3.0 headers. Start with two USB internal extension cables, and move the pin receptacles one by one by pressing the metal tab and pull the wire in question gently. Remove all pin receptacles in the USB 3.0 connector and put the other wires in the right place according to the pinout. If the connectors differs too much you might have to solder instead.
Ebay is one place to look, two cables like this (get long enough),
124888
put together/soldererd to this 20 pin female (remove the rest).
124889
1,609 (0.35/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
wtf I get nothing from a google search but pages of garbage... thanks for the reply's...
I still dont get what you found in my google search for 1 x 18-1 pin ROG_EXT connector.
1,609 (0.35/day)
Mouse Logitech G903
VR HMD Rift S
I've searched for an ROG_EXT cable, it was the last link on the first page (at least for me).
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
lol ive been searching for this cable for a long time. I was certain you couldn't buy one after researching. I obviously didnt look hard enough.
:toast:
19,375 (3.52/day)
Is this what you need?
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
yep thats exactly the cable, sorry I havnt replied. im recovering from having kidney stones among other things so not been able to respond...
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
I actually need the whole cable splitting into two at the usb_ext side as I cant plug it in to my new motherboard.
asus has added a plastic surrounding the pins. not sure if its possible to take it off.:toast:
1,576 (0.23/day)
The Gulag Casino
Mouse M65 RGB Elite
correction, asus have replaced rog_ext with the code socket. repinning of the rog cable is necessary to get it working.
