1024 bit memory bus!!!
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Motherboard ASRock z68 pro3-m
Cooling Corsair A70
Memory Kingston HyperX 8GB 2 x 4GB 1600mhz
Storage OCZ Agility3 60GB(boot) 2x320GB Raid0(storage)
Display(s) Samsung 24" 1920x1200
Case Custom
Power Supply PC Power and Cooling 750w
Software Win 7 x64
ok so i was thinking the other day...
if ati used 2 3870 cores (256 bus each) for a combined bus of 512 on the x2
wonder what it would be like if they used the 2900's 512 bit bus and combined them for a combined bus of 1024 bit bus...how sweet would this be...
i know its not practical but hey i guy can dream right! :rolleyes:
TonyStark
225 (0.03/day)
Processor Intel Core 2 Duo E8600 @ 4.0GHz
Motherboard Asus P5Q Pro
Cooling Zalman CNPS9700LED
Memory Kingston DDR2 800 @ 4-4-4-12
Video Card(s) Asus GTX 260
Storage Seagate 160GB, Seagate 320GB
Display(s) Samsung 46" LCD (full 1080p)
Case CoolerMaster Centurion
Power Supply Tagan U22 530W (32 amps on 12V)
Software Vista ultimate 64 bit
Benchmark Scores 3DMark06 - 17,000
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
120 (0.02/day)
System Name MONSTER
Processor Core2 Quad Q6600 G0 @3.6GHz (9x400MHz) 1.35v
Motherboard Gigabyte GA-P35-DS4 Rev. 1.0
Cooling Home-made water cooling + 3x120mm 1200rpm case cooling
Memory 4x1GB Kingmax DDR2-1066 @ 1000MHz CL4 5-5-16
Video Card(s) Asus EN8800GTS (g92) 512MB @core:783, shader:1944, video ram:1044
Storage 2x250GB Hitachi 8MB 7200RPM SATA2 RAID0 + WD 400GB 16MB 7200RPM SATA2
Display(s) Samsung 226BW 22" 1680x1050 2ms
Case Custom Made
Audio Device(s) Creative Labs Audigy X-Fi XtremeMusic
Power Supply Spire Rocketeer 600W
Software Vista Ultimate 64 & 32 bit; Windows XP Pro 64 and 32 bit
Benchmark Scores 17645 3D Mark 2006, http://service.futuremark.com/compare?3dm06=4995796
By comparing the results of the 38x0 and the 2900 you can notice that the memory interface doesn't mean much. This is because their graphics chips are not starving for memory bandwidth. That's why ATi reduced the bus width from 512bit to 256bit. nVidia did the same, although their cards are more bandwidth hungry. It's a compromise between a low performance penalty and a much cheaper production of the PCB.
With the 1024bit memory interface, you'll only end up with a more than 2 times more xpensive and very complex PCB that would bring almost 0 performance improvement over the 512bit.
wolf
Better Than Native
8,232 (1.28/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
and 2x512 bit doesnt exactly make it 1024-bit. its still 2x512.
just like the GX2/X2, theyre both 256 bit x2 and 512 mb x2, as oppose to 512 bit 1024 mb.
4,378 (0.67/day)
Hurst, Texas
System Name The86
Processor Ryzen 5 3600
Motherboard ASROCKS B450 Steel Legend
Cooling AMD Stealth
Memory 2x8gb DDR4 3200 Corsair
Storage WD Black 512gb, WD Blue 1TB
Display(s) AOC 24in
Case Raidmax Alpha Prime
Power Supply 700W Thermaltake Smart
Mouse Logitech Mx510
Keyboard Razer BlackWidow 2012
Software Windows 10 Professional
as said both nvidia and AMD are shader starved, though Nvidia is less shader starved right now. As AMD's opperate as a 64 shader core most of the time
wolf
Better Than Native
8,232 (1.28/day)
System Name MightyX
VR HMD Meta Quest 3
i think nvidias got the right idea clocking the shaders really high and having less of them. makes for some kickass fun overclocking too :D
120 (0.02/day)
System Name MONSTER
Case Custom Made
Well, effectively the 2x512bit is making it a 1024bit, but with the frame buffer reduced to half.
4,876 (0.79/day)
Joplin, Mo
System Name Ultrabeast GX2
Processor Intel Core 2 Duo E8500 @ 4.0GHZ 24/7
Motherboard Gigabit P35-DS3L
Cooling Rosewill RX24, Dual Slot Vid, Fan control
Memory 2x1gb 1066mhz@850MHZ DDR2
Video Card(s) 9800GX2 @ 690/1040
Storage 750/250/250/200 all WD 7200
Display(s) 24" DCLCD 2ms 1200p
Case Apevia
Audio Device(s) 7.1 Digital on-board, 5.1 digital hooked up
Power Supply 700W RAIDMAXXX SLI
Software winXP Pro
Benchmark Scores 17749 3DM06
Lol, it doesnt matter if you have 8x256bit, you think its a full 256bit? no, its 16x16bit sub-interfaces, and broken down further. 2x512 bit would perform the same as a 1024 bit, someone please correct me if im wrong im sure someone will try :p
InnocentCriminal
Resident Grammar Amender
6,477 (0.89/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
Fuckin' funny beginning to a rather, pointless thread.
4,876 (0.79/day)
Joplin, Mo
Case Apevia
Software winXP Pro
agreed. closed.
47,285 (7.53/day)
That's not how it works. It's two GPU's with their own memory sub-systems, their own 512 MB of memory with a 256-bit wide memory bus. A HD3870 X2 has 1024 MB of memory for sure, but it's 2x 512 MB...in other words, 512 MB of memory mirrored just like any other multi-GPU setup.....again depending on the modes, like tiling, AFR, etc.
Graogrim
308 (0.05/day)
East Coast US
System Name Paradigm
Processor i5 3570k
Motherboard MSI Z77A-G43
Cooling OEM
Memory 8 GB Corsair Vengeance DDR3 2133
Video Card(s) EVGA GeForce GTX 670 2 GB
Storage 128 MB Corsair M4 SSD + 1 TB WD Caviar Black
Case Rosewill Challenger USB 3
Audio Device(s) Soundblaster X-Fi Titanium HD
Power Supply Corsair GS 800
Software Windows 7 64 bit
It makes a difference when both cores are fetching the same data redundantly. It really isn't the same as a single unified core with a broader bus.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
What's awesome is that in near future an el-cheapo 128bit bus will outperform a typical 256bit bus used on modern high-end cards like nVIDIA's 9-line. Say hello to 4GHz+ GDDR5. ;)
Exciting times ahead...
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
makes me wanna wet my pants! :D
4,378 (0.67/day)
Hurst, Texas
System Name The86
Cooling AMD Stealth
Display(s) AOC 24in
well 256bit is practiclly free these days and doesnt cost much at all over 128 or 64bit.
I think the next lowed cards will be GDDR3 equipped 128bit bus cards
as for memory, the reason they use the memory like that is to conserrve bandwith. The Crossbar Memory controller was very needed.
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
the only thing i see bad about gddr4 or gddr5 over gddr3 is right now some of them have higher latency but i guess if the clock out weighs the timings then its not really a prob!
2,792 (0.39/day)
Tre, Suomi Finland
candle_86,
Surely, those GDDR3 chips are not free. 5$ won't get you even a single GDDR3 chip...
jbunch07,
Latency = cycle time × timings
When frequency goes up, cycle time goes down. GDDR5 doubles the frequencies so the latency cycles can be doubled too without increasing the absolute latency which is measured in nanoseconds. And it's the absolute latency that matters, not the amount of latency cycles.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
So true. maybe if they had enough shaders the 512bit bus would help more. BUT heat and higher volts power usage seem to be the problem.
Megasty
1,263 (0.21/day)
The Kingdom of Au
Processor i7 920 @ 3.6 GHz (4.0 when gaming)
Motherboard Asus Rampage II Extreme - Yeah I Bought It...
Cooling Swiftech.
Memory 12 GB Crucial Ballistix Tracer - I Love Red
Video Card(s) ASUS EAH4870X2 - That Fan Is...!?
Storage 4 WD 1.5 TB
Display(s) 24" Sceptre
Case TT Xaser VI - Fugly, Red, & Huge...
Audio Device(s) The ASUS Thingy
Power Supply Ultra X3 1000W
Software Vista Ultimate SP1 64bit
The 2900xt had that 512bit wonderful stuff & look at what happened to it in terms of power slurping :rolleyes: ...although the 80nm core was mostly the cause of that.
2,792 (0.39/day)
Tre, Suomi Finland
Megasty,
And as a 1GHz GDDR3 chip can draw ~5W peak it does indeed add up when there's 16 chips total...
btw, R600 is 80nm. ;)
Megasty
1,263 (0.21/day)
The Kingdom of Au
Cooling Swiftech.
Storage 4 WD 1.5 TB
Megasty,
geh, I have the comparison pic with the 3870 & x2 right on my desktop :laugh:
I think screwing around with the slow gx2 & crysis has fried my brain, btw its 5hrs & I'm still not done yet, its doing 2-8 fps on the Assault level :mad:
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
at what settings?
Megasty
1,263 (0.21/day)
The Kingdom of Au
Cooling Swiftech.
Storage 4 WD 1.5 TB
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
