Fearofthemrak
- Sep 12, 2020
- 18 (0.01/day)
i bought cheaply 1070 that was used in sli config. the guy marked it in not working condition (no videou output) but in sli it worked while he was benchmarking it.
So i saw videos on youtube how you can use amd apu to passthru video out but use gpu power to render the game.
i put everything in the case, switched in bios primary gpu integrated. firstly i had some errors 43 but sometimes when i reset the computer or when i disable and enable the driver in device menager it disapears.
when i download gpu-z to see if it is working properly it says memory 0 gpu clock 0 and bios unknown. When i click look up it brings me up manli 1070 but my card is asus turbo.
i try to nvflash it but when i do protectoff EEPROM not found.
I also have a choice to switch it with 1060 that is working and to give 100$.
can someone suggest what should i do
photo of gpu z https://prnt.sc/248j234
