10700 vs 5600X
1,547 (0.73/day)
London, UK
Software ❶ Win 11 ❷ 10 ❸ 10
According to the above 5600X review, the non-K series 10700 comes out ahead @ 1080p (in most games). Also beats the 10700K and 10900k (stock).
I'm just just trying to wrap my head around how this was made possible. I've always been lead to believe the K-series CPU's are "marginally faster" out of the box + the added benefit of overclocking. My kaby lake 7700K sees pretty wide single threaded perf gains over the non-K 7700.... "so vat da hell iz goin on with 10th Gen?"
Is the 10700 reference in these reviews based on a premium Z-series board, more expensive lower latency memory and overclocking (as I understand some OC is possible with non-K series)? Or was it based on stock configurations with a B/H series board and not-so expensive RAM? Also your know-how thoughts on how the non-K is able to beat intels flagship i9 SKU?
10,737 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 CL30 / 2133 fclk
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
That's probably well within margin of error - .6%
1,374 (0.36/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
It's some form of %0.1 difference... you can see that these chips were indeed getting decent results in the tests so the better one was either capped by something else, or simply didn't help marginally at FHD.
As for overclocking locked SKUs, you're going to have to work on your bCLK which could lead to anything from USB device unreliability to failure. It's not something I'd suggest.
2,963 (0.84/day)
Long Island
The $324 10700 is 3.6% faster in Gaming than the 5600x but is $24 more than the MSRP of the 5600X
Keep in mind that this will change somewhat at higher resolutions. If you see yourself upgrading to 1440p / 2160p, take a look at those.
The surprise to me was at 1440p where. in gaming, the $174 10400F outperformed very one of the new Ryzen CPUs, including the $550 5900x.
1,547 (0.73/day)
London, UK
Does the 10700 reference in the charts rope in overclocking performance gains? Eg. raised BCLK + power limits? The 10700 for me is only a desirable option if it's running at stock with auto-boost enabled without having to invest in a premium Z-series board + 14CL 3200Mhz kits. Alternatively I am more than happy to follow through with the more power efficient 5600X.
3,504 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.10.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2161), upgraded from Win10 to Win11 on Jan 2024
Both platforms on the end of their lifetime. 5600X and 10700 are really close in perf. 0.5~3% is identical in real life.
On gaming performance the 5600X does it with a little less power that both 10700/10700K and on multi it stands between them on perf but a little lower in power consumption than the nonK and a lot lower than the K.
With 5600X you get PCI-E 4.0 and something tells me that with RX6000 is going to be a lot more relevant than fast NVMe(s), if you are interested for a new GPU also.
(see SAM feature)
1,374 (0.36/day)
Display(s) PG348Q
Case Core X71
Get the 5600X, you could use it with the stock cooler for your needs.
17,574 (2.40/day)
Keep in mind that the tests that were performed here was with an RTX 2080 Ti and the recently launched and announced will shift things around somewhat.
738 (0.45/day)
Processor Intel i7 13900K
Motherboard Asus ROG Strix Z690-E Gaming
Cooling Arctic Freezer II 360
Memory 32 Gb Kingston Fury Renegade 6400 C32
Video Card(s) PNY RTX 4080 XLR8 OC
Storage 1 TB Samsung 970 EVO + 1 TB Samsung 970 EVO Plus + 2 TB Samsung 870
Display(s) Asus TUF Gaming VG27AQL1A + Samsung C24RG50
Case Corsair 5000D Airflow
Power Supply EVGA G6 850W
Mouse Razer Basilisk
Keyboard Razer Huntsman Elite
Benchmark Scores 3dMark TimeSpy - 26698 Cinebench R23 2258/40751
The Wraith Stealth? Garbage for gaming...
I would buy a 30/40€ cooler like the Arctic Freezer 34 at least
1,374 (0.36/day)
Display(s) PG348Q
Case Core X71
Gaming does not load the CPU to its limits, if you actually made an example like rendering, where the whole chip is used... that might have made more sense.
I have couple of those and they work just fine when you don't push the CPU, which is what the OP sounded like he is going to do. Especially now that winter is coming.
1,547 (0.73/day)
London, UK
My thoughts too. I've been looking at all three (10400/10600K/10700) to compare with Zen 3 (5600X). For me the 10400F only demands £150 (GBP) which is a steal!! For gaming @ 1440p I wouldn't have looked past a 10400/10400F/3600 - problem being I am looking for a 8-core chip with growing thread utilisation demands (multiple DT applications, occasional rendering + video transcoding, i guess games may also benefit to some extent in the long run, etc).
I'm in no rush though - my 7700K is holding up to anything and everything listed in the review charts and multi-threaded inferiority isn't a big deal with my "current" requirements....which brings me to: What are your thoughts on waiting for Rocket lake for a more meaningful ST advantage over the 7700K or slashed ZEN 3 prices? Money isn't a problem and I don't mind paying less excruciating over-spends but i'm 50/50 whether it's worth upgrading now. My next upgrade will be put to use for 4yrs+ or earlier if DDR5 platforms sees larger than life performance uplifts. So many options... and I already know i'm over-thinking... (SOMEBODY HOLD MY HAND!! hehe)
3,504 (1.84/day)
In that case if I didn’t had any serious gaming issues I would keep it for another year at least. After AlderLake, or even after Zen4
9,426 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
In terms of gaming the differences are practically zero, however, despite having 2 less cores it outperforms the 10700 in just about every other task. I'd get the 5600X.
1,547 (0.73/day)
London, UK
(see SAM feature)
Excellent point!! I forgot about the announcement notes on smart cache and 4-11% perf gains (i think) when pairing Zen 3 with a AMD GPU. Yes also have a GPU upgrade in mind. I'm definitely open to RDNA 2 but don't see myself pulling the trigger at launch. I've got a 1080 TI hence don't mind waiting a lot longer for big navi to hit the shelves, Nvidia to respond with TI/super variants and who knows RDNA 2 counterattacks too (not needing the absolute best, but hopefully some price slash action). I'll wait until the dust settles. I definitely want to see how well the smart cache feature performs in a select number of games I play.
Honestly I don't like stock coolers. Even if it came with a Wraith Prism i'd get something better. Anyway cooling isn't a problem... i got a couple of monster-like air coolers already.
3,504 (1.84/day)
Just a clarification. It’s SmartAccessMemory and not smart cache. The large Infinity Cache all RX6000 have, is something different and unrelated to SAM.
IC is just an enhancement of GPU<->VRAM communication. SAM is CPU access to full VRAM.
1,547 (0.73/day)
London, UK
I agree. Even my multi-threaded workloads don't urgently require a 6core+ option although it would be nice. My only worry is running multiple applications whilst day trading and a whole bunch of side-charts/market feeds/multiple browser windows and a couple of other tasks... i'm a beginner at DT hence not an immediate requirement from the get-go. Bottom line, i've hit a point with hardware enthusiasm where an "upgrade" is an itch I can't scratch lol I can't shake it off but willing to a wait a little longer until 11th Gen hits the shelves.
thank you for the correction. I swear I knew should have reverted back to the Zen 3 slides before making an a$$ of myself hehe.
Actually I was meaning to ask... are there any current independent reviews for SAM in action (other than AMD slides)? Or is this something expected with RDNA 2 NDA's lifted at launch?
Also in your words, can you simplify the SAM process? For example, my not-so researched understanding is the CPU uses both system memory (RAM) and VRAM for the added performance uplift. If games don't utilise more than lets say 10GB RAM, and I've already got 16gigs... does that mean I won't benefit with SAM or have i got it all wrong?
3,504 (1.84/day)
GPUs (6000) must be released first...
Around the 18th
We don’t know the specifics yet, but from my understanding, CPU will be using empty VRAM for its own workload during gaming.
10,737 (1.73/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Around the 18th
I am curious to see how this works. Could be massive, could be marketing nonsense.
738 (0.45/day)
I'm speaking from direct experience.
Bought a 3600X for my son, in a "cheap" gaming rig (3600X + MSI B450M Mortar Max + GTX 1660 Super) and the stock cooler was terrible: while gaming it struggled to keep temperature under control with the fan at maximum speed.
Swapped with the Wraith Prism brand new from my 3900X (I'm using a Dark Rock 4 with it) and the situation dramatically improved in both temperatures and noise.
The Wraith Prism isn't a great cooler, but it is more than adeguate for a 3600X/3700X while the stock Wraith Stealth is not.
And if you don't believe my words, you can check by yourself: stealth vs prism
Even in gaming the difference is huge.
Even the cheap Spire is better than the garbage Stealth, and I don't know why AMD was providing the Spire for 3600X and now is giving the Stealth to the more expensive 5600X.
1,547 (0.73/day)
London, UK
Around the 18th
Ah, that makes sense. I guess we'll have to see how much of an impact this feature will have :)
3,746 (1.32/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
AMD has not revealed details of what SAM does. Basically, there is nothing new on hardware side, there is GPU and it can access system RAM over PCIe bus. This has been the case since the very beginning of PCIe GPUs (and AGP before that). Best educated guess is that SAM is some sort of software/firmware/API solution that does traffic management or QoS to prioritize certain traffic.
1,547 (0.73/day)
London, UK
I was under the impression SAM is an older inferior feature being revamped for superior gains. I guess we're all in the same boat with the becoming (not in your boat lol, yours and Zachs technical know-how is definitely more advanced) but SAM does seem interesting or like phanbuey put it "marketing nonsense".
3,504 (1.84/day)
I agree that the stealth is bare minimum and just to work, but it’s not about CPU price. It’s about power draw. All 3600, 3700X, 5600X are 65W TDP parts. 3600X is a 95W TDP (88W PPT vs 125W PPT).
Yes CPU access to VRAM is old but the difference from SAM is that up until now CPU could/can access only a 256MB part of VRAM. Now AMD is giving full access to entire VRAM. And I suspect that PCI-E 4.0 is a requirement for such operation that can involve large amount of data back and forth for the CPU alone...
They said it... “Full CPU access to VRAM” and there is a video that explains it on AMD channel.
If it’s marketing nonsense we will see. It’s not up to us to decide, especially when we don’t know the specifics...
1,374 (0.36/day)
Display(s) PG348Q
Case Core X71
If you don't know what you're doing, you can overheat under any condition. Such as auto voltages. A properly tuned 5600X, at STOCK settings, will not impact your gaming experience anywhere as bad as you're making it out to be.
Of course the cooler with the heatpipes will perform better, I have MULTIPLE of them and I use those effectively in numerous rigs. The main problem with the big Wraith is noise under heavier loads. Your link is also with Pinnacle Ridge counterparts...
the cooler comes with TIM pre-applied, it's a slap on solution and it DOES work, even at %100 load:
