Velaryon1007
- Jul 19, 2020
- 3 (0.00/day)
Hello everyone,
Recently got a Helios 300 (2020) with the 10750H and RTX 2060 that will arrive next thursday. I want to have everything planned beforehand, as I will have very little time to configure it at home before going away with it (and I prefer not to tinker with this kind of things on the move). I always prefer to keep the temps as low as possible, moreso if speaking about laptops. Also, the more runtime I can squeeze out of it if using battery for office work, the better.
I plan to go for the full pack, Undervolt + Underclock, and if temps are not low enough I will repaste it, but as a last resort.
For purely gaming, the 10750H doesn't need to be using turbo the whole time, so what frequency do you think that could be acceptable? 3/3.5Ghz? What's the best way to achieve this (extending battery life as much as possible), adding a frequency limit and letting it draw the power that it chooses, or adding a power limit and letting it adjust the frequency accordingly? It's not going to be used for benchmarking or anything, only gaming, so as long as I don't loose a lot of FPS i have no problem tuning down it's performance. Or would I just be okay disabling turbo and forgetting about it?
Regarding Undervolt, I've seen that it is recommended to undervolt the cache half the mV of the core undervolt, am I right? P. ex., -150mV core and -75mV cache. Already aware of the undervolting limitations of some 10th-gen laptops, but I loose nothing for trying it.
Many thanks for your help!
A.
A.
