108 degrees centigrade?!?
9,019 (1.40/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
Please have a look at the attached picture of Speedfan.
(I know that I have to add 15 degrees to the core temperatures due to the tJunc of my proc being 100) That's not the problem.
Can anyone tell me what on earth is running at 108 degrees centigrade inside there?:twitch:
455 (0.07/day)
Hereford, England
Processor Intel Core i5 750
Motherboard Maximus III Formula P55
Cooling Ultima 90i
Memory 4GB Kingston HyperX
Video Card(s) PNY GTX465 @ GTX470 w/ 1280MB vRAM
Storage OCZ Vertex 2E 60GB + 2x1TB Samsung F1
Display(s) Samsung 245B
Case Black Cosmos S
Audio Device(s) Creative Audigy 2ZS
Power Supply Antec NeoHE 550W
Software 7 Ultimate 64bit, OSX
That's a bug in speedfan I get it all the time, just an error reading the temperature probe or something... I dunno what AUX is supposed to be (motherboard temp?) but its always at 123C or something for me...
9,019 (1.40/day)
Processor i9 9900k
Keyboard Motospeed
I was guessing my motherboard temperature was system, and that's a reasonable 35 degrees.
Sooo, you really sure it's just a bug?
682 (0.11/day)
Barcelona, Catalonia, Spain
System Name The Phoenix (rev. 3.0)
Processor Intel Core i9 9900K @ 4.9GHz (1.18V)
Motherboard ASUS TUF Z390 PRO-GAMING
Cooling Custom Full Loop w/EKWB & Swiftech components
Memory 32GB Corsair Vengeance RGB Pro 3200MHz (C15)
Video Card(s) MSI GTX 1080 SeaHawk X EK @ 2.15GHz/5.5GHz
Storage Samsung 970 EVO+ (2x500GB) + Toshiba X300 (4TB)
Display(s) LG 29UM65-P (2560x1080 @ 75 Hz)
Case Thermaltake Core V51
Audio Device(s) Razer Kraken 7.1 & Scarlett 2i4 w/M-AUDIO BX5-D2
Power Supply Corsair RM750 (ver. 2019)
Mouse Logitech G700s
Keyboard Razer Blackwidow Chroma V2
Software MacOS 10.13.6 "High Sierra" & Windows 10 Pro x64
On some boards, that temp sensor is a "dead" one, if it always marks the same don't worry about it ... i also have a TMPIN3 (or AUX one) .. normally is 42-44ºC, when doing stuff at 100% load reaches 127ºC, i supposed it was the northbridge and i was worried about it ... but i touched the heatpipes and if that were at 127ºC i should burn my fingers ... and i didn't, still marking the same when doing stuff ... but i won't worry cause it's obvious it's not a good reading of that sensor, 127ºC should heat all the MoBo or the surroundings ... and it's not that hot never ... so don't worry. Most sure is a dead sensor that always marks the same, i've read it on other pages too :)
KBD
2,477 (0.38/day)
The Rotten Big Apple
Processor Intel e8600 @ 4.9 Ghz
Motherboard DFI Lanparty DK X48-T2RSB Plus
Cooling Water
Memory 2GB (2 x 1GB) of Buffalo Firestix DDR2-1066
Video Card(s) MSI Radeon HD 4870 1GB OC (820/950) & tweaking
Storage 2x 74GB Velociraptors in RAID 0; 320 GB Barracuda 7200.10
Display(s) 22" Mitsubishi Diamond Pro 2070SB
Case Silverstone TJ09-BW
Audio Device(s) Creative X-Fi Titanium Fatal1ty Profesional
Power Supply Ultra X3 800W
Software Windows XP Pro w/ SP3
9,019 (1.40/day)
Processor i9 9900k
Keyboard Motospeed
Well something's certainly whacky. The 'bad' news is that it does change. It varies between 102 - 108.
Then I started TAT to see what happens under load, and it went down...:confused: the higher my cpu temperature the lower it went. And I mean really down it jumped from 106 to 58...55... and reached 48 and remained in that area for the duration of the TAT.
After stopping TAT it goes up to over 100 degrees again.
So, there is some sensor somewhere. But it makes no sense for something to cool down the more the pc is loaded isn't it? :wtf:
BlackIce
19 (0.00/day)
System Name Antec 1200
Processor Intel® Core™ 2 Extreme QX9650
Motherboard Asus Rampage Extreme
Cooling all watercooled by zalman
Memory Adata 2 x 4GT Dual-kit DDR3 1600MHz (PC-12800), Extreme Edition X series VERSIO 2, EPP
Video Card(s) 2 x ati 4870 x2 crossfire
Storage 6 x Hitachi Deskstar 7K1000 total 6 TB
Display(s) Samsung SyncMaster 245B
Case Antec 1200
Audio Device(s) asus xonar D2/PM
Power Supply antec quatro 1000 watt
Software vista 64 bit ultimate
Benchmark Scores 28650
speedfan
I am not so fan of speedfan because its not so accurate as everest those temps are much better than from speedfan :cool:
682 (0.11/day)
For me works the opposite way, and certainly it's not meant to cool while you're forcing the stuff ... so i'm pretty sure it's a big sensor bug or a sensor that gets the "sum" readings of other ones, in almost all ASUS MoBo's there is an issue like that, cause we have different mobo's and processors and that issue is there ... btw, i noticed that temp sensor when i plug any USB devices that requires power, bumps 10ºC or 15ºC more ... try it and see if also goes down as when you're working hard with the CPU, and tell me please, i will worry a bit less :laugh:
12,453 (1.91/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
It's definately a bug. On my Gigabyte DS3 board, Speedfan read the AUX as 146c...LOL. Not a chance in hell that anything in my system could be running that hot.
47,380 (7.52/day)
Speedfan is notorious for a lot of things like off-beat readings, system-hangups, etc. If I were to trust it, my northbridge is on a polar expedition at -20 C.
682 (0.11/day)
He's true, any electrical device working more than 100ºC constantly should ruin the plastics of the MoBo.
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Why not just go with Asus Probe....seems with speedfan even the coretemps dont even come close to TAT's 60*c.
9,019 (1.40/day)
Processor i9 9900k
Keyboard Motospeed
Bingo... plugging in my photo-camera into USB makes that temp drop to 86 deg then to 55 deg...
Nice. My camera keeps my pc cool! :laugh:
I don't 'go' with Speedfan actually. I use it just for the S.M.A.R.T. function. I was just very curious what that temperature might be representing, since all the other temperatures in my case show clearly what they're reading, even though erroneous. (Btw Asus Probe gives me wrong core temperatures to, I only use coretemp 0.95 for my cores)
Solaris17
Super Dainty Moderator
27,171 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
speed fan detects my 250gig sata drive as 200ºC lol ok....but ya its a big bug i mean if you think of it...if your NB or w/e thats supposed to be reading was really at 14ºC your computer would fail after about an hour...or your heatsink would start to glow..one or the other...but regardless if your HS started to glow im pretty sure your pc would fail right after regardless.
4,994 (0.70/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
You can get rid of them...
You can also rename each sensor. Click it, and then again and it will let you edit the names.
imperialreign
7,043 (1.10/day)
Sector ZZ₉ Plural Z Alpha
System Name УльтраФиолет
Processor Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved)
Motherboard ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB
Cooling Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler
Memory Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T
Video Card(s) Quadfire: (2) Sapphire HD5970
Storage (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA
Display(s) Samsung Syncmaster T240 24" (16:10)
Case Cooler Master Stacker 830
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro PCI-E x1
Power Supply Kingwin Mach1 1200W modular
Software Windows XP Home SP3; Vista Ultimate x64 SP2
Benchmark Scores 3m06: 20270 here: http://hwbot.org/user.do?userId=12313
I've found on some boards that the AUX reading is typically a temp sensor that wasn't implimented on the board, but BIOS still contains some reference to it, hence why it's displayed. I've never seen the AUX reading to look anywhere near correct, and other programs like Everest will still display the same sensor, but usually with a completely different reading that's still incorrect.
Sh00t1st
371 (0.05/day)
Austin,Texas
System Name Battlefield 3
Processor Phenom II x3 715 heka unlocked to x4 3.3ghz
Motherboard GIGABYTE ga-ma785g-ud3h
Cooling arctic cooling freezer 64 pro
Memory 4 gig ddr2
Video Card(s) saphire 5770
Storage 60gb mushkin ssd,120 and 160 gig ide
Display(s) 1 19" crt, 2 17" crt
Case 30 dollar gaming case with fan grills removed
Power Supply 450 corsair
Software windows 7
Benchmark Scores Plays battlefield 3 well enough that i was ranked 1st globally in vehicles for november and december
my older rig the soltek in my spec list, had 2 phantom temps hehe, one of them was always above 100c the other was extremely negative and fluctuated alot. good ol speedfan. now my friend c4pta1ntr1ps had a pos 50 dollar board that had about 5 fantom temps it was hilarious.
Kursah
Super Moderator
14,730 (2.21/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
On my current board my AUX reads like -9C or something like that, before that my last MB had an AUX that read 123C...I wouldn't worry too much about it if there's no description for it, just something some programs detect that's not actually reading or sending a value that should be read. As long as CPU, MEM, GPU, NB, MB, PWM temps are fine, then for the most part I'm content!
:toast:
aximbigfan
847 (0.13/day)
St. Louis, MO
System Name QUAD1
Processor Intel Core i7 920
Motherboard Asus P6T SE
Cooling XIGMATEK HDT-S963
Memory OCZ 3 X 1GB Triple Channel
Video Card(s) HIS Radeon HD4670 IceQ
Storage Seagate 250GB 7200RPM SATA
Display(s) Acer AL1916W 19" Widescreen LCD
Case CM Storm Scout
Power Supply Corsair 520 Watt
On a side note, I have used SF for... years... Now, and have never had ANY problems what so ever with it. It does try to read a device on my server (Inspiron 6000), but other than that, all ok.
any better ones around?
Chris
