1080ti stuck on low clock
1 (0.03/day)
System Name Windows 11
Processor Intel i7-7700K
Motherboard Asus Z270F
Cooling BeQuiet Dark Rock Pro 3
Memory 32GB Corsair 3200MHz
Video Card(s) Asus 1080ti
Power Supply Corsair RM750i
Hey guys,
for past few months I've been struggling with my ASUS 1080ti - it's been stuck on low GPU clock and it randomly fixes itself after rebooting - firstly it happened when I was using dual-monitor setup, once I changed to 1 monitor the issue disappeared and right now it came back even on 1 monitor.
Attaching details from GpuZ while GPU is in-use (running game with 3/4FPS at max with 100% GPU utilization)
Any ideas what to do? I've already reinstalled the drivers using DDU and right now I think it's more of an hardware-issue - would be grateful for any leads. Thanks!
  • GPU-Z Sensor Log.txt
7,368 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
The does like that on unstable OC. Well it is an old card...
For the lulz, can you do afterburner and there is a OC scanner. Run it for fun, if it scans for errors even at default clocks.
633 (0.11/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
It's got the power limit bug. This is usually a hardware failure, but it can also be caused by updating the drivers while precision, afterburner, or something similar is running.
Uninstall Precision, Afterburner, or anything similar, reinstall the drivers using the Clean Install option in the advanced install option list, reboot, and try again.
If the power limit is still bugged, look for a repair shop.
41,171 (6.56/day)
Probably time to replace that gpu or get it repaired...
13,778 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Strip it and bake at 200C for a few minutes with a weight on the core.
Suggestion only, all risks are at the discretion of the end user.
5,918 (4.40/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
Baking this card won't fix it, I've seen this problem before. From the behavior and the reported limit reason of "Pwr", I bet the core shunt resistor blew open. 1080 Ti cards seem prone to this issue as they age.
The fix is basically reinstalling another shunt resistor or doing a shunt mod to fully uncap the power. It's basically the same procedure. Either way, it'll need to be serviced by a technician if OP doesn't know how to do this.
1,817 (0.40/day)
Romania
Don't bake a relative modern and good GPU. Take it to a repair shop, and see how much it would cost to fix it. And then see what your second hand market is selling at. Then make a decision.
3,143 (1.54/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Odd problem, I can only assume it has maybe degraded and its protecting itself.,
My 1080ti had a weird issue that would happen when playing division 2, it would "occasionally" suddenly lose performance, however the clock speed would stay high, just a massive drop in performance and the power load would plummet. I assumed at the time some cores got disabled but now I have since learnt about clock skips, that may have happened instead, like your issue a reboot always reverted the behaviour, but clearly not the same exact issue though.
A way to test if its in anyway silicon instability, is to apply an under clock (ideally for VRAM also) and then see if the behaviour stops.
