- Jun 7, 2020
- 241 (0.13/day)
System Name | Yin/Yang |
Processor | Ryzen 7 3700x |
Motherboard | msi mag x570 tomahawk |
Cooling | CoolerMaster ML240V2 / asiahorse fs9002 120mm fans |
Memory | 2 x 16gb g.skill trident z neo 3600 |
Video Card(s) | msi gaming X 2070 super 8gb |
Storage | 1tb sabrent rocket nvme / 1tb samsung evo 860 sata ssd / 3tb Toshiba hdd |
Display(s) | lg ultragear 2560x1440 144hz 1ms 27"ips |
Case | nzxt h510i |
Audio Device(s) | logitech g635 / creative sound blaster |
Power Supply | evga supernova 750ga 80 plus gold |
Mouse | logitech g402 hyperion fury |
Keyboard | corsair k55 |
Let me briefly explain the machine in question before i get into a few questions and begin to seek advice/direction:
- AsRock Z97e-itx/ac motherboard (broken pciex16 slot)
- Intel i7 4790k 4ghz cpu (4th gen haswell chip socket 1150 LGA ) / Noctua NH-U14S
- MSI Rx580 Armor OC 8gb gpu
- Fractal Design Nano S case (mini itx)
- 8gb Patriot DDR3 1600mhz RAM (single channel 1x8gb stick)
- Corsair SF600 PSU
- Samsung EVO 860 1TB SSD / Toshiba 3TB HDD
Ok, so i discovered the one and only pciex16 slot on this mini itx board is not working which really has me me scratching my head on what to do next. My goal is to get this machine up and running capable of mid-level 1080p gaming as cheaply and efficiently as possible. Normally I would say no big deal just replace the board/add a ram stick and you got a working/quality gaming system. In this case however, given the older 4th gen chip socket and build form factor the options appear to be extremely limited. Most manufacturers have stopped producing SFF boards that support this particular socket type. ( the motherboard in the machine currently is selling for 200-300$ used and $400-500 new if you can even find it which is just absurd ). Although this is an aging chip it's still fairly bad ass and capable of what I need it do in this situation. I'm not willing to by used a used board off of personal sellers on ebay and pay over priced shipping, and wait longer than usual on a part that may or may not work. I'm open to the idea of buying a used board from a certified repair/refurbished seller that back their product but i can't seem to find a reasonable deal going that route either. It seems as though I'm stuck between biting the bullet and buying an obnoxiously over-priced refurbished board with rapidly dating memory support / or replacing the chip/board/case/ram which is of course less efficient and more costly. Any advice/direction would be appreciated. what would you gurus do in this situation given the circumstances? obviously nobody wants to spend more money than necessary to accomplish their goal but at the same time I'm starting to feel as though I'd pretty much be pissing into the wind if I drag this chip along for the ride (even though I'd like to). Perhaps there's a cheaper alternative than rebuilding half the system that i have not wrapped my head around or maybe there's a reliable/reasonable motherboard source for this chip/case that I haven't managed to find.
I looked into the pci-e slot with a magnifying glass to try to identify the problem and it seems as though there is either a tiny little piece of metal in there or one of the pins is distorted causing it to appear shinier than the rest of the pins. Since the motherboard is pretty much useless to this machine without a pcie 3.0x16 slot i briefly entertained the idea in my mind of pulling the plastic protective covering off and investigating a little further or attempting a surgery, but then again I think my chance of success would be minimal and I wouldn't want to risk damaging the gpu after the fact
- Corsair SF600 PSU
