12400f Gear 1 not stable
80 (0.47/day)
Processor 12400f
Motherboard Msi b760 p
Cooling Oem
Memory Viper 2x8 3600 cl17
Video Card(s) Msi rx 6700 xt mech
Storage Pny 256 m2, Kioxia Sata ssd 480
Display(s) Iiyama 2470hsu b6
Case Fury Shobo
Audio Device(s) On board, Microlab Fc 330
Power Supply Msi a650bn
Mouse Logitech g203
Keyboard Logitech
Patriot ddr4 2x8gb 3600 cl17 is not stable in gear 1. I've tried to turn xmp off and select speed and gear 1 manually but still same effect. Occt gives hundred of errors. Re4 rw
remake crashes within a min. Gear 2 no problems.
Should i rise voltage on ram? By how much...
Thanks guys.
431 (2.17/day)
12400f has locked IMC voltage (900mv iirc, maybe even 875mv, it's super low aynway). rising ram voltage won't help a thing. try changing to 3200 c16/3000 c15 manually.
80 (0.47/day)
Processor 12400f
Cooling Oem
Case Fury Shobo
Mouse Logitech g203
Keyboard Logitech
I switch to 3200 but....timing stayed the same...cl17. Im running now occt
no errors yet...do you know which timings i could put in manually? for cl16 or maybe below?
2,993 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
my locked ADL Chips all do XMP @ 3466.
80 (0.47/day)
Processor 12400f
Cooling Oem
Case Fury Shobo
Mouse Logitech g203
Keyboard Logitech
I did 3466 now :) just launched occt...
No errors...yet. 3466 cl 16 18 18 38.
You read all those people on the internet...mine works 3600 gear one...right :banghead:
431 (2.17/day)
people have successfully run 3733 on 12400/12500/12700 with no errors, it's a silicon lottery, just like a core overclock on K-series.
80 (0.47/day)
Processor 12400f
Cooling Oem
Case Fury Shobo
Mouse Logitech g203
Keyboard Logitech
Re4 remake
people have successfully run 3733 on 12400f with no errors, it's a silicon lottery, just like a core overclock.
usually the same people do 75 mpg in their 2.0 tdi :)
Ps. Re 4 remake 2-6 fps improvment
