12600k with z790
80 (4.21/day)
Sorry to bother you guys but opening this topic cause I couldnt get a good answer about my ssetup.
Currently using b660 mobo with 12400 f but I had some saved money to upgrade to 12600k with 4070 ti super but when I search forums everyone says go b690 ddr4 instead of z790 ddr4
What is the real diffrence ?
There is also a price diffrence in my country betweenn b and z 690 around 100-150 €
Thank you for your time
1,422 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
pretty sure z790 is ddr5 as i have a asus tuf z790 board and it uses ddr5.
edit: Had a look there is z790 that support ddr4 so make sure one you are getting does else if you are gonna use same memory
ir_cow
4,647 (0.78/day)
USA
DDR4 Z790 MBs exist, but not many as Z690. Also Z790 for DDR4 can have better support for higher frequency memory.
I would say if your sticking to 3200-3600 speed, that aspect won't matter what you pick. But for PCIe slots, m.2, USB, etc will change for B and Z series.
1,911 (1.31/day)
Alaska USA
What B660 board do you currently own and what country are you located?
1,911 (1.31/day)
Alaska USA
Currently using MSI B660m-A and I live in Turkey
That board has sufficient VRM's to handle a 12600K / 12600KF. The only reason you would want a Z series board for those cpu's is if you needed more PCIe lanes. Just make sure you have a decent cpu cooler.
80 (4.21/day)
I've managed to find a really cheap z690 mobo and d12600k price iss less thten 250$ for both. Also currently ussing Noctua NH d15 cooler with ddr4 cl 16 3200 ssticks
80 (4.21/day)
This 2 I can find best other than that prices going up like 150 $ in my country
Other options
7,365 (4.94/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
If you are buying another motherboard and RAM kit, why not just go DDR5? It doesn't make sense to put any money on this platform otherwise.
7,365 (4.94/day)
São Paulo, Brazil
Already bought them ages ago can't return them now
No need to spend, then. You will get nothing out of a 12400F on a Z790 board that you don't already get on the B660. That chip is locked, and upgrading to Z790 without DDR5 would make your machine largely unsuitable for a high end Raptor Lake down the line.
You should probably just keep that money in this case and save for a complete platform swap including CPU down the road.
80 (4.21/day)
Think I put wron info for title I am usingn b660+ 12400f atm
what I bought was z690 + 12600k
also whenn I tesst my kitss they are crappy d die corsairs
7,090 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Hi, you should post which motherboard model # you intend to purchase so we can assist you.
I would say do a Z series motherboard but can't really offer advice unless I know which models you are talking about. There are Z series which use DDR4. You don't really save much money doing B series over Z series. If you already had the B series you should just put the 12600K into it and return the Z.
80 (4.21/day)
I think I made a mistake and put wrong title as Z790. My setup is 12600k with msi z690 tomahawk wifi ddr4. Currently trying to pick rams and I am sttuck with;
XPG ADATA DDR4 32GB 3600-18 K2 Spectrix D35G RGB​
Kingston HyperX FURY RGB 32 GB (2x16) 3600 MHz CL18 HX436C18FB4AK2​
G.Skill Ripjaws V 3200 MHz 32 GB (2x 16 GB)
Kingston Fury Beast 32 GB (2x16) 3600 MHz CL18 KF436C18BBK2/32​
G.Skill Ripjaws V 32 GB (2x16) 3600 MHz CL18 F4-3600C18D-32GVK​
these are the besst options I can get. Other kitss are like 150$ more expenssive in my country.
1,911 (1.31/day)
Alaska USA
