128GB RAM on X99 platform with 5820K? No problem!
5,717 (0.95/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Before my attempt many people told me this is impossible. Quoting from Intel's ARK website claiming that Haswell-E series can only support up to 64GB of RAM. However there are already evidence that this can be done.
So first here is today's focus. GSKill DDR4-3000 128GB quad channel kit specifically for X99 platform.
Out with the old:
In with the new. The GSkill sets sit lower than the ADATA sets. So I was able to lower the fans of D15 to the point they can blow onto the RAM heatsink.
Now full inserted ALL EIGHT sticks!
I made sure to clear the CMOS settings before firing it up. Otherwise the board will probably be unable to recognize the new RAM modules. BAM! It works right off the bat!
I was able to get it run at DDR4-3200 with 14-14-14-35 timing. Pretty impressive. However it would need 1.4V for DRAM to get it stable! Too high for my liking.
In the end I decided to give up 100BCLK and used default XMP settings for daily usage. 125BCLK will cost me the lovely feature of adaptive vcore, but at least I can still use offset mode for power saving.
Stability test passed without a problem. 4hrs of ASUS Realbench with RAM limit set to 64GB, 4 hrs of AIDA64 stress on all system components. 4hrs on Google linux mint memory test as well.
Some information and basic benchmarking
Overall I am very satifsied with the awesome quality of the GSkill memory. I used GSkill DDR2-1000 8GB kit on my old QX9650 platform for almost 8 yrs. This 128GB kit will serve me well in the next 8 yrs.
5,717 (0.95/day)
I believe my 5820K's IMC quality is superb. Handling 128GB RAM at 3000MHz speed with low timing is just awesome.
5,731 (1.09/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
That's hardware pr0n right there... Nice looking rams and very sexy looking with all 8 sticks in there, congrats man, I am ever so slightly jealous ;) :toast:
theonedub
habe fidem
8,027 (1.43/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Load up those genetics programs and prove to the doubters how much RAM they can effectively use :toast:
DNA methylation, CpG islands, snRNPs, non-coding RNA- almost makes me want to crack open my old genetics textbooks :laugh:
5,717 (0.95/day)
Yeah I was fapping my e-pen last night installing this. lol
Seriously speaking these babes gonna cut down the amount of time I need to assemble contig reads probably in half at least. I am excited. Next week I will get two full reads of raw human genome and I will do assembly on both of them. Can't wait to see it blast through it.
My next stage aim is setting up 4 virtual machines, each with access to 30GB of RAM. That way I will have my personal super computing cluster at home. Money money money!
5,717 (0.95/day)
These programs can chew through 1TB of RAM. I saw it on the super computing clusters. It was fu*cking amazing.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.51/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The program attached to this post can easily consume terabytes worth of memory if the grid is sufficiently large enough and the number of possible paths is sufficiently deep enough. 10x10 can take it up to 16-18 GiB on occassion.
Processors do have a maximum supported memory amount (e.g. 40-bits) but Intel/AMD generally doesn't advertise it. If higher density sticks of memory don't work, it is usually the motherboard BIOS/firmware to blame.
Frick
Fishfaced Nincompoop
19,246 (2.84/day)
PiteĂĄ
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
You now have more RAM than I have storage space in my laptop. That's pretty surreal.
cadaveca
My name is Dave
17,233 (2.56/day)
The X99 platform launched with a max 64 GB, but subsequent micro-code updates (brought about by ASUS/G.Skill working with Intel) increased that ability up to 128GB. This same micro-code should be present in nearly any X99 board's BIOS at this point. If you can run 2666 MHz on 100 BCLK (you could not at launch, or 2800, or 3000), then you should be good to go. When the platform launched, you had 2133 MHz, 2400 MHz, and then 3200 MHz as the only working dividers on 100 BCLK, and the rest required 125 BCLK or greater. Today is a different story with most boards (there are still a few stragglers who have not got proper updates).
5,717 (0.95/day)
Strange enough for me. DDR4-2666 will not boot on these sticks with 100BCLK. Probably because selecting DDR4-2666 the timing will automatically adjust to 11-11-11-34
DDR4-3000 is rock solid with XMP settings.
DDR4-3200 can boot on 100BCLK but require very high VCCSA and DRAM Voltage to stay stable.
cadaveca
My name is Dave
17,233 (2.56/day)
Because you have a Sabertooth, and not an ROG board, I do not find that surprising. But you can run 3000 on 100 BCLK? Then the microcode update is present. 2666 used to be 2133 divider w/ 125 BCLK and 3000 was 2400 divider on 125.
Early 3000 MHz quad sets (such as the C15 sticks I reviewed) had different XMP profiles than newer sets, and the older sticks used 125 BCLK.
But now that we are nearly into 2 years after the platform launched (iirc I had my first X99 samples in late june, early july 2014), a lot has changed with X99. We had the USB 3.1 updates to many boards, etc...
ASUS and G.Skill were the first to be showing 128 GB running, iirc, around a year ago now, so you should never have any problems with those brands combo'd up. My ASUS X99 DELUXE can run pretty much any divider on 100 BCLK without any issues at all (it's currently running those 3000 C15 modules w/100 BCLK)
qubit
Overclocked quantum bit
17,865 (2.91/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Wow 128 gigs! :rockout:
It's great to see that the rig can take double what it's rated for. How much did all that RAM cost you then?
5,717 (0.95/day)
It was $700. I had a newegg gift card and a Chase promotion rebate too good to pass.
1,901 (0.33/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
DROLLING!
so clean, I wanted to ask won't that big a load of ram put undue stress on the CPU or A CPU? What cooling are you using on the CPU? Very nice RIG!!!
5,717 (0.95/day)
DROLLING!
Thanks!
It surely is putting a lot of stress on the IMC.
Using Noctua D15 to cool it. Pretty good temp actually. Right now CPU is clocked at 4.25GHz with 1.19V vcore, load line calibration at level 3.
Aquinus
Resident Wat-man
13,157 (2.85/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
In defense of Intel, 64GB is probably what is officially supported however, the ark page does say and I'll quote; "Max Memory Size (dependent on memory type)". Just as my 3820 can only support 64GB but, can run 128GB if and only if I used Intelligent Memory DDR3 DIMMs (which support was added for on the latest BIOS update for my P9X79 Deluxe.) So I could run 128GB of DDR3 but, it would cost an arm and a leg.
Either way, that's a great find though. Thanks for sharing.
5,717 (0.95/day)
This will show you why I need 128GB RAM. Hell if possible I would to have more.
Human genome size is 3 billion base pair. One 10X coverage raw sequence run usually takes 2~3 days to assemble on those Xeon clusters. With my old 32GB RAM sometime it would even crash. 128GB RAM is barely the entrance requirement for such job.
5,717 (0.95/day)
A different type of assembler.
5,448 (1.06/day)
People are kinda stupid, at least most of them :)
Mobo BIOS updates won't mention 16GB stick updates for nothing :)
This is similar to the P55 case, when 8GB DIMMS came out and actually allowed 32GB setups in boards to be available.
5,717 (0.95/day)
And people used to tell me that my i7-q720 only supports up to 8GB of RAM. Until I installed a 16GB kit on my wife's laptop.
2,388 (0.64/day)
Shenandoah Valley, Virginia USA
System Name Home Brewed
Processor i9-7900X and i7-8700K
Motherboard ASUS ROG Rampage VI Extreme & ASUS Prime Z-370 A
Cooling Corsair 280mm AIO & Thermaltake Water 3.0
Memory 64GB DDR4-3000 GSKill RipJaws-V & 32GB DDR4-3466 GEIL Potenza
Video Card(s) 2X-GTX-1080 SLI & 2 GTX-1070Ti 8GB G1 Gaming in SLI
Storage Both have 2TB HDDs for storage, 480GB SSDs for OS, and 240GB SSDs for Steam Games
Display(s) ACER 28" B286HK 4K & Samsung 32" 1080P
Case NZXT Source 540 & Rosewill Rise Chassis
Power Supply Corsair RM1000 & Corsair RM850
Mouse Generic
Keyboard Razer Blackwidow Tournament & Corsair K90
Software Win-10 Professional
Benchmark Scores yes
128GB of RAM is a lofty goal for most of us.
My X99 build has 64GB waiting for when I can afford a CPU. I imagine I'll probably take half of it out and use it in another PC someday.
cdawall
where the hell are my stars
27,680 (4.17/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
I didn't realize people didn't know this worked. I have built 3 rigs like this at work already with anything from the bottom of the barrel asrock boards and up.
13,791 (1.89/day)
You can also fill so much RAM by using 7zip with LZMA2 ultra preset and 1536 MB dictionary. It'll munch away over 100 GB of RAM with 12 threads on 5820K :D
21,232 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Fun fact, many X58 boards can support up to 48GBs of DDR3, if you can find those somewhat rare 8GB sticks...
Aquinus
Resident Wat-man
13,157 (2.85/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
