12VHPWR has a higher number of failures in a single gen than 6/8 pin does in 17 years
3,202 (1.06/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
The gold nugget of this video though is this chart illustrating the total number of people who experiences issues with 6/8 pin vs 12VHPWR:
I'm surprised GN didn't do more to illustrate why it's extremely bad that 12VHPWR already has a higher total number of failure instances. 6 / 8 pin has been around for 17 years while 12VHPWR has only been around for 1 GPU generation and yet the number of failures already exceeds that of 6/8-pin. If one were to extrapolate this data into a failure rate, 12VHPWR would be several magnitudes worse.
That's before you even consider that the question is narrowly enough worded so as to exclude 12V2X6 issues. Even if we assume that they reduce the failure rate of the connector by ensuring it has to be properly mated, the failure rate is still not nearly as good as the 6/8-pin due to the lower safety tolerances and the 25cm straight cable requirement of the specs.
IMO this kind of increase in failure rate due to a power connector is absolutely unacceptable. More than 17 years worth of failures now happen in a single year thanks to this new connector. IMO GN did not go nearly far enough in pushing from improvements or replacements to the connector.
108 (2.16/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
I'm sure it happens, but I've never seen a case of catastrophic failure for either connector that wasn't related to user error in some way.
3,202 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
For sure there are user failures in both instances but the fact would remain that one connector is vastly more resistant to user error while the other is not. I still see a lot of people complaining about the lack of clicking in their 12VHPWR / 12V2X6 connector and the mating force required to correctly install the new connector, which has just been an issue since day one and is bad design.
108 (2.16/day)
Texas, USA
Personally, I'd like to see pigtails on the cards themselves, and use big fat conductors and connectors. Something like this
4577n25multinegative_right_positive_front_standard15_1626368510_575@halfx_637619474404459450.png
4577n25multipositive_right_negative_front_standard15_1626370634_646@halfx_637619495751048898.png
but I doubt that is going to happen. A lot of us use power supplies you could weld with, and tiny wires for the conductors (ever seen welding leads....they aren't tiny).
It is bound to cause problems at some point. You are probably right to seek a better design.
rtwjunkie
PC Gaming Enthusiast
13,946 (2.36/day)
Louisiana
Processor Core i9-9900k
I see you are referring to the exhaustive study and 1 hr 12 minute video from Gamer’s Nexus?
The majority of problems stemmed from angled connectors, and of those the highest number were from 2 brands. I think also the problems were nearly all from aftermarket connectors, not ones that actually came with ATX-compliant PSU’s.
It’s not so much a big deal.
3,202 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
The video was done in collaboration with industry experts and sources and it was also fact checked by experts as well. I'm saying this because you appear to be sarcastic.
Well yes "you think", because nothing of the sort is stated in the video. Seems rather hypocritical to rebut the lengths GN goes to provide objective information but then having nothing to counter it except personal opinion and then coming to a conclusion that it isn't an issue based merely on that.
  • Like
Reactions: Jun
freeagent
8,250 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
It really is not that hard to click it into place.. you just push until you hear the click, not until you hear your PCB snap. Maybe it is an issue with the cable itself? Maybe A-Brand PSU maker has a better cable than B brand?
Just grasping at straws here.
Not gonna lie, it is nicer to deal and route 1 cable instead of 2 or 3.
1,376 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
in terms of same power draw specs, its 1 cable vs 4. I wonder what failure rate of 2x6 pin if you pulled 300watts through each to match that 12pin.
364 (2.60/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
A connector that does not actually feel smaller than a PCIe 8-pin would have made that easier. I remember being shocked by how little it is, for something supposed to carry 12V/600W, hanging off a beefy cable.
It is not as if people don't still have to deal with huge legacy connectors elsewhere, despite attempts like ATX12VO.
freeagent
8,250 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Indeed..
But as long as it is clicked into place it should be fine. Running my card all out and the cable and connector are fine temperature wise.
I don't know.. maybe I am just good with my hands? Even my first try plugging it in was not a problem at all, heard the click and I was set. Once its in, you can pull on it, do whatever.. within reason.
3,375 (1.17/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Indeed..
Or just buy sub 300W GPU, cable will never melt, problem solved.
But then there would be nothing to rage about :roll:
3,202 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
You can see on the Nvidia reddit quite a few people are pointing out that they don't get any click at all. One of the complaints were that people weren't getting the clicking. Combine that with some cards obscuring the card side connector and it was not a good recipie.
Lack of safety tolerances and lack of an actual enforcement mechanism to ensure connectors meet the standard are two factors cited in the video.
If the cable were the issue, I'd assume it would have manifested by now. After all you had people professionally testing to see if they can reproduce this issue and the cable was one of the variables controlled. They tried different adapters, PSU, insertion methods, ect and the only thing that made the issue reproducible was not fully slotting the connector and bending the wires to the side (as if you had your PC side panel on).
It could help airflow too. IMO though not worth additional failures. I'd much prefer something like what ASUS showed with the power connector on the mobo. Zero cables in that instance.
  • Like
Reactions: Jun
2,709 (4.58/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
It'll still be both fugly and unnecessary because SURPRISE, a single 8-pin is more than fine for sub-300 W GPUs. Of course if we're talking quality plugs and quality PSUs in general.
Cotton candy is a better engineer than those invented 12VHPWR.
3,375 (1.17/day)
Software win11
Where are those 300W GPU with single 8pin? do you know what you are talking about?
rtwjunkie
13,946 (2.36/day)
Louisiana
You assume that which does not exist. I’m not being sarcastic at all. You seem to be worked up. You ok?
Nothing of the sort, huh? The primary focus of rhe video was with angled connectors that aren’t OEM. You seem worked up. I’ll ask again…you ok? Is this personal for you?
7,025 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Most of the problem was the CableMod cables.
2,709 (4.58/day)
Russian Wild West
They are nowhere because manufacturers don't want their wares blow your sorry parody of a PSU up because almost no PSU comes with AWG16 cables that actually can withstand it.
So if having AWG16 was a standard and most people could afford such PSUs and the vast majority PSU manufacturers were at least relatively sound then we'd have 6-pin GPUs like RTX 4070 (sub 200W) and 8-pin GPUs like RTX 4070 Ti Super (sub 300 W) as well as 6+8 pin GPUs like 4090 (sub 500 W). At about seventeen hundred percent safety level.
But alas. They smoke everything they can find on the black market and then come up with the most moronic connector this globe has ever seen and blame users for damages. Innovations must come calculated, not ejaculated.
3,375 (1.17/day)
Software win11
So it's PSU manufacturers fault for making poor quality 8pin cable, but somehow it's Nvidia fault for poor quality 12pin cable :roll:.
BTW it's a design from PCI-SIG consortium, if anything send your hate mails to them
2,709 (4.58/day)
Russian Wild West
Nvidia fault
I heard it's not their invention but I got no proof on hand. Anyway, they adopted it so they're also responsible.
And this design is really very poor. I've seen 10 y.o. kids coming up with smarter stuff than that. And they ain't even attending engineering classes.
Wires should be thick, there should be no way you can plug it incorrectly (unless you really try) and there should be 1+ kW abuse capacity in cables rated for 600 W. Bending also should never have been an issue. Enforcing AWG16 so singular old school 6-pins suddenly become suitable for enthusiast segment gaming GPUs would've been a gajillion magnitudes better.
3,375 (1.17/day)
Software win11
Everything you said is just pure hyperpole that there is no point discussing
2,184 (1.27/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
3,407 (1.64/day)
UK, Midlands
System Name Main PC
Processor 13700k
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I would have liked GN to have a look at the cable situation, as the recall as it turns out was just the adaptors not the cables. Of course many people get the two mixed up as cablemod sell right angled cables still which have had no recall, I brought one but decided to not use it in the end. I havent seen reports of burnt out connectors on those cables, but is people reporting stability issues that got resolved either by using the Nvidia adaptor or changing to a cable supplied by their PSU vendor.
GN very briefly mentions the cables in the video, that they dont have the PCB component, but otherwise its all about the right angled and 180 adaptors.
