140mm Fan Question
292 (0.16/day)
Elsewhere, USA
System Name Regular PC | Server HP Z440
Processor 9700k | E5-2698v3
Motherboard Gigabyte Z390 Gaming X-CF | Stock mobo
Cooling Scythe Mugen 5 rev. B | Stock HS
Memory 32 GB (8x4) | 112 GB (8x2 + 16x6)
Video Card(s) RTX 2070 Super | K4000
Storage 970 EVO+ 1TB | 860 1TB x2
Display(s) XV340CK x2, 1080p x2
Power Supply Corsair RM750x | Corsair RM750e
Software ZorinOS Pro | Proxmox
Good evening everyone,
I'm in the market for 4x 140mm fans and dont really know where to begin. I've always bought cheap and put up with noise, but for my next build, I seek advice. I'm looking for good air flow and no rgb. What has worked out for you all?
freeagent
9,591 (4.11/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I have a few Thermalright TL-B14. They are pretty decent. I would recommend..
Edit:
That is what the top of my case looks like when I am using an air cooler
FreedomEclipse
~Technological Technocrat~
24,391 (3.75/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Arctic P14 MAX
43,431 (6.76/day)
You can turn off rgb individually fyi. Anyways you can research cfm and dba and static pressure values for the likes of Thermalright, Thermal Take, Scythe, Nideq, Delta, Sunon, Bitfenix, Corsair, Lian-Li, Aerocool, Antec, Arctic, Deepcool, Gelid, BeQuiet, Xigmatek. If the case front has a lot of obstruction then you will want a high static pressure fan.
835 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply Seasonic Prime TX-1600 ATX | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
How much do you want to spend , do you care about RGB , for rads / case ? example I have 12 Noctua a14 500 rpm to 3000 rpm , at 30 dollars a pop , on sale too , so your system spec's might not need top tier fans today , later down the road that can changes , buy a 5 pack of fans no thrills RGB , 40 dollars range ,
ARCTIC P14 Max (5 Pack) - PC Fans, High-Performance 140mm Case Fan, PWM controlled 400–2800 rpm, Optimised for static pressure, 0dB mode - Black​
116 (0.49/day)
System Name Fedora Linux
Motherboard MSI X570-A Pro
Cooling 360 Arctic Liquid Freezer 2
Memory 64 GiB Crucial Ballistix DDR4-3200
Video Card(s) 16 GiB ASRock RX 7800XT PG
Storage Plenty
Display(s) 40" UWQHD cheap LC-Power 144Hz
Case BeQuiet! Silent Base 802 Mesh Front
Power Supply 750W Seasonic Focus GX Platinum
Keyboard Cherry MX Board 3.0S Blue Switches
if you have enough money and don't wanna care about buying new for a long time (6-year warranty, very well built), get Noctuas. NF-A14x25 G2 PWM
Otherwise, go with the Arctic. Just be aware that you could get a bad one in the mix, I had that already. Really annoying noise, not "loud" in the dbA-sense, but an annoying parasitic noise growing with RPM. Then again you get 5 P14 Max for 1 NF-A14 G2, so... you know. Price-wise the Noctuas are very bad.
695 (3.74/day)
The arctic 5 pieces pack of P14 are decent affordable. I was kinda happy when making my own fan curve for low humming noise.
5,277 (3.73/day)
Colorado, U.S.A.
How about the Noctua redux series to keep the price down?
2,590 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
I am using Noctua 140mm iPPC PWM, 12 @ 2000RPM and 12 @ 3000 RPM on my rads.
Not quiet, not cheap, but perform great.
dgianstefani
TPU Proofreader
5,226 (2.02/day)
Swansea, Wales
System Name Silent/X1 Yoga
Benchmark Scores Legendary
5,277 (3.73/day)
Colorado, U.S.A.
For me noise is an issue, so I prefer several larger fans that run slow.
Noctua's
NF-A14x25 G2 LS-PWM
runs slow (maybe too slow)
2,590 (0.38/day)
Software Win11PRO
Noctua's
NF-A14x25 G2 LS-PWM
I have seen the 2000RPM iPPC go slightly below 800RPM. At that speed they are reasonably quiet, although, 12 of them still are very audible.
14,039 (6.35/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Be quiet (the brand). I've heard good things about Noctua as well, but brown/beige is a big no for me.
5,277 (3.73/day)
Colorado, U.S.A.
43,431 (6.76/day)
