17 13620H + phase change pad = murder fuel for my cpu.
dreyvis
4 (4.00/day)
Brand new pc specialist Elimina Pro gaming laptop with rtx 4070, also phase change thermal pad, and the cpu is constantly throttling at very low wattage as well as usages. I believe the screenshots speak for themselves. So obviously my question is how do fix the thermal throttling?
PCSPECIALIST are garbage at trouble shooting the problem, I'm still in the 14 days so they're giving me the bums rush. I'm willing to kiss my warranty goodbye if anyone knows a fix other than open it up and put some thermal paste in there.
2,241 (0.68/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Without question send it back after documenting every reason and instance. Demand full refund. Move on.
8,975 (4.04/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Your cooler is broken, not mounted properly, or the fans aren't connected.
If PCSpecialist are fobbing you off after the evidence you've posted here, it's time to invoke your UK consumer rights - distance selling regulations. Do not open the laptop, that harms both your warranty and your consumer rights.
If it's not working as sold, the regulations have you covered.
If it's not working and you've f*cked with it, you don't have a leg to stand on.
dreyvis
4 (4.00/day)
Thank you for responding, I'm leaning that way myself, I'm gather very odd telemetry in xtu and occt. Quite funny really so I'll post more screenshots for entertainment purposes. Saves thing is I saw a lenovo legion with comprable specs for a little less, its gone now
603 (2.79/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
So what is the problem? Send it back.
Get a Sager or a Eurocom
8,975 (4.04/day)
Case Veddha T2
Mouse MX Anywhere 2
I'm possibly out of date but aren't both of those also just the exact same rebranded Clevo whitebooks that PCSpecialist are selling? I've bought 50+ Clevo whitebooks from various sources, including PCS and the Sager/Eurocom/Schenker/XMG branded Clevos were always crazy expensive in the UK.
PCS screwed up the cooler mounting after installing the CPU, that's all that's happened here.
dreyvis
4 (4.00/day)
I was wondering if the thermal pad is the cause, I didn't do my due diligence on phase changing pads. Apparently the have to be kept at around 35 to 45 degrees to be conductive, so it looks like they just pump extra watts into the cpu to...get this....warm it up. THE ONE THING YOU CANT DO TO AN INTEL. Naturally I am vexed by my oversight.
603 (2.79/day)
Texas, USA
Yes, they are just Clevos
The difference is that they stand by their stuff and don't have monkeys putting them together.
779 (1.14/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
That's not correct, PT 7950 and other pads will happily work with GPU/CPU's at much higher temps, seems like they fucked up the thermal pad installation as you shouldn't be seeing such high temps and throttling with thermal pads, send it back or go rogue and tear it down and install your own
dreyvis
4 (4.00/day)
My gpu pad seems to be working fine, and yeah, I'll most likley be requesting they take it back. If there's another fix I'd be open to hearing it, it is a nice machine with a nice screen. Now I'm getting facinated by the weird things I'm finding. I started the thread because it's also interesting to see a comfortablly mid range gaming laptop "operate" with fucked up thermals.
I've only used it for a very short time, but I've screen capped a lot of odd readings in xtu, so I'll post the weirdo stuff here in case anyone else finds it interesting too. :)
