2700x - snapped pin, ghetto repair and a lapjob!
Mussels
Freshwater Moderator
58,413 (7.97/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Long story short: I lost a pin off my 2700x to some pin goblin, and bought a 3700x.
Then i thought... lets try dumb shit to fix this thing.
Broken pin, which controlled the RAM slots. One of 4 slots worked at 2133Mhz, not fully stable but enough to reach windows.
Edit: Missed some photos!
How i fixed the missing pin - i cut the wire out of a spare SATA cable and dropped it into the mobo socket
The SATA cable wire is inside the socket to the top left of the piece of cardboard
Dirty girl needs a good cleaning! that conductonaut has been through hell on a bunch of coolers
4.3Ghz boost (nooooice)
58C max temps in LinpackXtreme benchmark (remember, 10C offset for the other reading)
996 (0.29/day)
System Name The Banshee
Cooling Asus ROG Strix LC 240
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
At least the solder failed for the pin and not the pad, shouldn't be too hard to stick it back on.
27,359 (6.61/day)
Might have missed it, have you tried soldering the pin back on?
Some rosin flux, tweezers, a fine tip soldering iron with some careful work should do the trick. I've done it a few times, successfully. The key is to stay relaxed, take your time and remember that there is no rush. If it doesn't work the first time, clean up and try again.
@Mussels I remember you saying you have no idea where the pin went. Have you looked for a donor pin from another, less valuable AM4 or even AM3/AM2(can't remember if they would fit, but it's worth a look) CPU?
sneekypeet
not-so supermod
29,540 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I had luck in the past with gold plated craft wire. Just snip a bit a tad longer than the socket height, insert CPU, see if pin makes contact by looking to see if RAM comes back.
This was back in the 939 days, but I don't see any reason why it shouldn't still work.
6,016 (2.89/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
This is 2020, the stupid pin design should be obsolete. I don't know why AMD won't do it. 3 decades of broken/bent pins isn't enough?
What's the alternative? Bent pins on socket?
hat
Enthusiast
21,745 (3.32/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Nice work on the lapping. I did my 2600k recently, it was a fun project.
19,371 (3.57/day)
Wooooooow... well done!
Did I miss a mention of any temperature drop?
Or, it could be a socket full of them which are more easily moved/destroyed. :)
996 (0.29/day)
Mouse Evga Torq X3
PGA has pins on both the cpu and in the socket so your even more likely to damage a PGA socket than an LGA one especially if your cpu(s) have had their pins re-straightened.
Toothless
Tech, Games, and TPU!
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
This wasn't the kind of lapjob I was thinking of, still satisfying.
Mussels
58,413 (7.97/day)
Oystralia
had around a 20C drop, the CPU would flatline at 85 Tctl/75C TDie vs the 68/78 now - its boosting higher due to the lower temps, and running at lower auto fan speeds so its hard to say exactly how much better it is
the pin itself is long gone, it vanished when the CPU was removed to see why my system decided not to POST any more. At a guess the pin fell off in the socket, and fell out into carpet when i was diagnosing.
edit: woops, forgot to show how i ghetto fixed the missing pin. in first post now.
2,207 (0.81/day)
If the pin is not soldered down you may possibly get HR which will make the computer unstable, do random reset or corrupt files. It may seem to work but there is no telling how good a contact the pin is making. Vibration may unsettle it, ie if your playing music with the speakers nearby. Low frequency may unsettle it, ie deep bass.
2,350 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
And to what alternative? LGA? Same problems just on the mb. Had this been LGA he'd been screwed.
Regeneration
NGOHQ.COM
3,116 (0.45/day)
Intel MB socket pins design is slightly better but far from being perfect.
Thick rounded socket pins (disc shaped, just like Lego but smaller and with shorter gaps between) will put an end to this bent/broken pins nonsense once and for all.
Sure the processor will be wider, but this will also improve thermal transfer and provide space for additional cores.
5,533 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
hmmm they could go BGA
2,698 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Agreed - The entire board and all CPUs you'd have for it would be useless, at least with the pins on the CPU it's only the CPU itself affected and frankly there are less incidents with it too that I've ever seen.
BTW I have a board (775 Gigabyte) coming with damaged pins in the socket, if I can't fix it I'll just rob parts from it to fix another one I have with blown MOSFETs.
4,840 (1.54/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
The pins on the older CPU’s are longer than the pins for Ryzen. I was surprised how short they are when I first removed the CPU from the clamshell package.
2,698 (0.68/day)
Alabama
Memory C.R.S.
Older CPU pins are also larger in diameter based on the socket it goes to, you'd have to use the right socket/chip to make it work if harvesting a pin from a donor chip.
2,207 (0.81/day)
As it turns out, you can convert PGA to BGA. Just de-solder all the pins & replace with balls. Not so sure if it will match the solder pads if you de-solder the socket. You could also leave it "as is" after removing the pins & sand it down to the pads to reveal the copper. Now you have LGA.
This is just crazy modding thou, but I do have such a modding planned. It's coming to "ghetto thread" soon here on TPU.
27,359 (6.61/day)
If you have soldering equipment, I would a least try to solder it on, just for the peace of mind.
They should still fit in the socket IIRC. The socket itself should be deep enough. I don't currently have any for comparison so that is only a hypothesis.
EDIT; Nevermind you were right. The pins are not just longer, they have a larger diameter as well.
Still a cheap donor AM4 CPU would do the trick.
2,207 (0.81/day)
That's right, take parts from old dead boards to fix other boards, that's what I do. But I also don't always fit the same MOSFETS back as I sometime feel it's wasting my time. So I head to Mouser & buy even better MOSFETS & change the lot & crank up the power by changing the resistors.
3,204 (1.67/day)
Memory Micron DDR4-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1
Power Supply Corsair RM750x
Mouse Logitech M575
Maybe putting the CPU on a card that pops into a PCIe backplane?
