3.5 Fan Controller for multiple San Ace Fans
727 (0.12/day)
O'fallon Mo.
Processor Intel I7 4820k EK Supremacy Nickel Waterblock
Motherboard Asus Rasmpage IV Extreme
Cooling Alphacool UT60 560 Radiator
Memory Kingston Hyper X 16gb 2400
Video Card(s) MSI GTX 580 Heatkiller Waterblock - EK Backplate
Storage SanDisk Ultra Plus 256GB
Display(s) LG 24" Flatron
Case Silerstone TJ11
Audio Device(s) Sound Blaster Recon 3Di
Power Supply XFX Pro 1000 Platimum
Software Windows 7 Ultimate 64
Guys,
I was wondering if there is such a thing as a 3.5 fan controller that can run 2 San Ace H101 per channel? i beleive they are .6 amps per fan
THX
:toast:
crazyeyesreaper
Not a Moderator
9,819 (1.69/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
727 (0.12/day)
O'fallon Mo.
not sure if 12 w a channel is enough.
looking to fill the 3.5 slot on my TJ07 with a fan controller.
Any more suggestions please? :]
727 (0.12/day)
O'fallon Mo.
Help !!!!!!!!!!!!
any ideas????????????
727 (0.12/day)
O'fallon Mo.
never mind guys :] I dismantled my 5.25 sunbeam rheobus extreme and painted the knobs and panel flat black and looks good. I don't mind it in my case now
43,618 (6.44/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I want to see a pic! :D I was going to suggest a piece of acrylic, you can paint the backside any color you want and it will look good.
727 (0.12/day)
O'fallon Mo.
have to get batteries for my wifes camera first :]
i am thinking of removing the leds .i gues they can just be pulled out eh?
EDIT
removed the leds. yeaaa. didn't like those things.
what i did was dismantle the rheobus extreme.pulled off knobs unscrewed from board.. sanded the metal part-cleaned with acetone then spray painted with the same acrylic flat black paint i used on the inside of case. light coats so would not look gunked up.went ahead and sprayed the knobs also and came out like i wanted. just flat black matches front of TJ07.
727 (0.12/day)
O'fallon Mo.
here it is erocker sory it took so long.actually going to sell it.:toast:
727 (0.12/day)
O'fallon Mo.
sold it and thinking about getting another rheobus extreme and replacing the blue leds with red leds. any one know what the led specs are that i would need?
thx
